Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-22-2004   #16 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Well, my needles are white, and AlienX's are clear because he sanded the backs instead of painting.
Bulbs are regular amber color (clear bulbs). The color is gotten by the filter on the back of the gauges.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Sponsored Links
Old 02-22-2004   #17 (permalink)
cosmo
Diamond Member
cosmo's Avatar
cosmo is an unknown quantity at this point
Alright, thanks. I'm thinking of just removing the amber/red (whatever color it is) transparent paint an just letting it stay the color of the stock bulbs until I figure out a color scheme for the new 'vic.
cosmo is offline   Reply With Quote
Old 02-23-2004   #18 (permalink)
gearbox
Super Moderator
Old 02-23-2004   #19 (permalink)
gearbox
Super Moderator
With stock backlight AFTER clearing the gauge faces.
Old 02-23-2004   #20 (permalink)
cosmo
Diamond Member
cosmo's Avatar
That doesn't look too bad just with the stock backlighting actually.
Old 02-23-2004   #21 (permalink)
AlienX
Diamond Member
AlienX's Avatar
AlienX will become famous soon enough
Send a message via ICQ to AlienX Send a message via MSN to AlienX
my needles are kind of white just because of the sanding down. But I also have a bit diffrent guage faces then gear. Its pretty visible in the day time..
AlienX is offline   Reply With Quote
Old 02-25-2004   #22 (permalink)
c-money
Member
c-money's Avatar
c-money is an unknown quantity at this point
hey you guys think that painting the back of the gauge cluster with transparent blue will work??
c-money is offline   Reply With Quote
Old 02-25-2004   #23 (permalink)
Vinnie
Super Member
Vinnie's Avatar
Vinnie should not be trusted Vinnie should not be trusted Vinnie should not be trusted Vinnie should not be trusted
In case anyone was attempting this diy, the wires you want are at the end just like it says in step 9 except the farthest one (red/black) is the power and the one second from the right (red) is the ground.
Vinnie is offline   Reply With Quote
Old 02-25-2004   #24 (permalink)
AlienX
Diamond Member
AlienX's Avatar
Thanks Vinnie, I would have expected the red/black to be ground since black is ground most of the time.. and red is power !! Ill get that edited ASAP
Old 02-25-2004   #25 (permalink)
AlienX
Diamond Member
AlienX's Avatar
c-money, I will try that tomorrow Ill tell u how it comes out.
Old 02-25-2004   #26 (permalink)
VTECnique
Diamond Member
VTECnique's Avatar
VTECnique is an unknown quantity at this point
Send a message via AIM to VTECnique Send a message via Yahoo to VTECnique
damn thats hott! i'm not good with electrical stuff like that. i need to get someone to do it for me.
VTECnique is offline   Reply With Quote
Old 02-26-2004   #27 (permalink)
AlienX
Diamond Member
AlienX's Avatar
VTECnique, gearbox lives in Illinois I think he would be able to help you out...
Old 02-26-2004   #28 (permalink)
AlienX
Diamond Member
AlienX's Avatar
c-money, the transparent blue works, but it doesn't make it look much difference in the day. I just removed it and kept it white..
Old 02-27-2004   #29 (permalink)
Menace303
New Member
Menace303 is an unknown quantity at this point
Can anyone tell me what a resistor is? And is there anyway to install the el wire but still have blue numbers, not green?
Menace303 is offline   Reply With Quote
Old 02-27-2004   #30 (permalink)
AlienX
Diamond Member
AlienX's Avatar
a resistor does exactly what it says..
but if you can't understand that.. Ill put it to simplier terms..
a resistor is an opposition to current which is contrary to voltage.
wait that might be too complicated also
If you have a 12 volt source ( your car ) a resistor will allow u to run a 3 volt LED by resisting current. Thats better
and about the EL cable thing.. Um.. you would have to talk to gearbox about that one. I was thinking if you add a resistor to the power on the EL cable it will make it darker, I know this works for LEDs but I'm not sure if it would have the same effects on EL cables, and the better question, to what extent can you do that.
Tags
blue , calibration , car , civic , clusters , console , dash , diy , gauge , gauges , honda , led , lights , needle , remove
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Blue LED gauge and dash lights
Hyperblinker
Installing Sidemarkers
DIY: EBAY FOG LIGHTS w/ EBAY BUTTON
Sidemarkers from MB SLK Compressor
Installing LED Washers
Bulb guide for 01-03
Aiming 01-03 Coupe Headlights
Brightest Legal Bulb?
brighter bulbs
Site Supporters
aluminum radiator
Honda car spoilers
