Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-15-2005   #136 (permalink)
Big Rob
I'm taking over!
Big Rob has a little shameless behaviour in the past
Send a message via AIM to Big Rob
So, if I read this right, then el wire is going to look better because it is more even? If that is the case, then why hasn't a diy been made? If I go that route, then I guess that I can make one.
Is this a pretty good deal for el wire?
http://www.xoxide.com/elwire.html
Big Rob is offline   Reply With Quote
Sponsored Links
Old 07-15-2005   #137 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
i paid alot for mine, got 4 packs $80 total 20ft is all you can fit and its plenty bright. There is a diy done by me in lighting forum sticky. Its called DIY: blue glow needles.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 07-25-2005   #138 (permalink)
Whelan
Super Member
Whelan's Avatar
Whelan is an unknown quantity at this point
Send a message via AIM to Whelan
I will be doing my HVAC center console controls, as well as the window controls and the roof/mirror/cruise control lights. I am making them all blue and putting a red light on the Cruise switch instead of the green.
I used 11,000 on my Angel eyes and that was pretty bright. I am not worried about the HU as it will be changed eventually. And my needles will be red.
But my concern is for the odometer on the dash. It will still be that orange color it is now unless someone knows how to change it out?
__________________
You know how life goes, sometimes your the bug, othertimes you the windshield...
Whelan is offline   Reply With Quote
Old 07-25-2005   #139 (permalink)
gearbox
Super Moderator
nah its too hard. You can pull off the light diffuser and try to clear it, but mine broke. Try and scrape the paint off it so its clear instead of using solvents. Without it, you can basically see right through the lcd. If you clear that piece and put it back, then you could try and put leds behind it. I just left mine off. There's no real need to see at night anyway.
__________________
www.lubecontrol.com
Member 1025782
Old 07-25-2005   #140 (permalink)
Whelan
Super Member
Whelan's Avatar
What if I removed the plastic cover that has the orange on it ( I assume that is what it is) Then put a piece of colored film over it?
__________________
Old 07-25-2005   #141 (permalink)
gearbox
Super Moderator
won't work. you will still see whatever kind of lighting you put, like the shape of a bulb. This plastic piece diffuses the light. You have to use the plastic, so try scraping off the orange on it and replace the piece.
__________________
www.lubecontrol.com
Member 1025782
Old 05-15-2007   #142 (permalink)
civicDave
Diamond Member
civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned civicDave should not be questioned
Send a message via AIM to civicDave
Re: DIY: Blue LED gauge and dash lights
A BIG THANK YOU TO:
MetalViper for providing the pictures to update this DIY article.
He will be receiving a CivicForums T-Shirt, you could too if you send me pictures to update a DIY article.
civicDave is offline   Reply With Quote
Tags
blue , calibration , car , civic , clusters , console , dash , diy , gauge , gauges , honda , led , lights , needle , remove
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Hyperblinker
Installing Sidemarkers
DIY: EBAY FOG LIGHTS w/ EBAY BUTTON
Sidemarkers from MB SLK Compressor
Installing LED Washers
Bulb guide for 01-03
Aiming 01-03 Coupe Headlights
Brightest Legal Bulb?
brighter bulbs
Site Supporters
aluminum radiator
Honda car spoilers
