Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Interior
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-17-2004   #1 (permalink)
Forum Bot
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
Post Schroth Rallye 4 Harness Install
Product: Schroth Rallye 4 Harness
Description:
The Schrothe Rallye 4 is designed for the enthusiast who is looking for a DOT approved 4 point, 2" wide harness with the simplicity of a traditional push button release. It is equipped with Schroth's unique asmŽ system, which reduces the risk of submarining. A quick-release buckle enables you to disconnect the tail strap, allowing occupants easy access to rear seats when the harnessbelt is not in use.
This harnessbelt is designed to mount to the two stock rear seat lap belt anchor points (the 'D' and 'E' points). It MUST be installed with a SCHROTH tested and approved seat which includes most stock seats having a single or dual post adjustable headrest and nearly all aftermarket 'racing' seats.
Where to get the product:
http://www.soloracer.com/rallye4.html
THIS IS THE ONLY STREET LEGAL, 50 STATE/DOT APPROVED HARNESS
Supplies needed:
- Schroth Rallye 4 Harnesses
- 14 mm socket
- 10 mm socket
Step 1:
Begin by removing the rear bench seat to get to the bolt points for the harnesses. The Schroth harness bolts straight to the stock positions. No modification is needed.
Use you 10mm socket to remove the bolt indicated below. Then just pull out the bench seat.
Step 2:
Attach the rear straps to the bolt positions(indicated by the green circles). You can go ahead and attack the driver side rear straps on the other side at this time too.
Use the 14mm socket to undo and redo the bolts for the belts.
Step 3:
Using the 14mm socket again, unbolt your seats so that you may gain access to the stock buckle. Unscrew the buckle from the bracket and place the lapbelt onto it. Re-tighten the buckle back on to the bracket. Bolt your seat back down tight.
Step 4:
Using the 14mm socket, unbolt the rod that holds the stock shoulder belt. Place the other end of the lapbelt on it and re-tighten the bolt.
Step 5:
Attach the rear harness to the front harness by clipping them together.
Step 6:
Adjust the straps so that they are comfortable yet tight at the same time.
RINSE AND REPEAT FOR THE OTHER SIDE
Forum Bot is offline   Reply With Quote
Sponsored Links
Tags
1997 , 2009 , 4point , asm , automatic , civic , harness , harnesses , honda , instal , install , installation , point , rallye , schroth
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Shift Knob/Boot Fix
DIY: 2003 Center Console Removal
DIY: Replacing door lock Assembly and Actuator (UPDATED WITH PICS ON POST 27)
DIY: Dash Removal
How To Paint Trim Pieces
No More Trunk Rattle!
Removing The Rear Deck
DIY: Automatic To Manual Shift Boot And Knob Conversion
Removing The Center Console
Steering wheel removal and MOMO wheel install
Site Supporters
aluminum radiator
Honda car spoilers
