Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Interior
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-21-2004   #46 (permalink)
AR
e-married to daydreamer
AR's Avatar
juh, premium shift knob, stock shift knob? whats the diff?
clear up my confusion.
AR is offline   Reply With Quote
Sponsored Links
Old 03-21-2004   #47 (permalink)
Aaggie77
Member
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
Send a message via AIM to Aaggie77
Try using this. It is $2 spring that I bought at Lowes. It came in a pack of 2. I just removed the center console and placed the spring over the shifter. I am using a leather wrapped short shift knob and the spring pushes the stock boot and ring right up to the knob. Take a look at the after shot in my gallery.
Aaggie77 is offline   Reply With Quote
Old 03-21-2004   #48 (permalink)
civic01vtec
The only job I need is a blowjob
civic01vtec's Avatar
civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned
Send a message via AIM to civic01vtec
^^^ pretty smart idea u got there
__________________
The 2nd Amendment America's original homeland security
'01 Civic EX -- boosted
'99 Chevy 2500 Ext. cab 4x4 with a
454 <--- under 10 mpg
'02 Chevy Trailblazer
civic01vtec is offline   Reply With Quote
Old 03-27-2004   #49 (permalink)
Toaster
Member
Toaster's Avatar
Toaster is on a distinguished road
I tried to email hondawerx with no reply and filled out the order form with the part number no reply yet. I am wondering if my email filtered out the responses. Any ideas?
Update: Received my Skunk2 shifter knob today. Just pulled the boot up and engaged it with the nut below the knob. Seems to hold pretty good. I might not even need the clip. Anyone else tried this?
Toaster is offline   Reply With Quote
Old 04-13-2004   #50 (permalink)
bobbyd
Ultimate Member
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Here is a pic of my boot fix.
bobbyd is offline   Reply With Quote
Old 04-29-2004   #51 (permalink)
REDchirp
Ultimate Member
REDchirp's Avatar
REDchirp should not be trusted REDchirp should not be trusted
Here's a novel one... buy and RSX shift knob... it's lighter... matches the trim pieces on our inside door panels... and it has the OEM clips to hold it up all day long.... lol... I love my RSX-S knob....
__________________
http://server5.uploadit.org/files/REDchirp-REDchirp.jpg
Please dont' sugarcoat it, give me all the bad rep points you can possible give me ...pansies
REDchirp is offline   Reply With Quote
Old 04-29-2004   #52 (permalink)
alloriginal
putang inamo!!!
alloriginal's Avatar
alloriginal is an unknown quantity at this point
Send a message via AIM to alloriginal
I emailed Hondawerx too but no reply. He said he was gonna get back to me but its been a while...
alloriginal is offline   Reply With Quote
Old 04-30-2004   #53 (permalink)
Ershall
Diamond Member
Ershall's Avatar
Ershall is an unknown quantity at this point
Send a message via AIM to Ershall
Something else you can do that you can do with the skunk knob is buy a JDM shift boot (black with red stiching). Once you do that you can mod the shift boot to fit in the aluminum colored ring and bore out the inside of the plastic ring at the top to make it work correctly. This skunk knob comes with a threaded nut that holds the boot top up and I think it will come out looking clean....All I have to confirm is that I can restaple the shift boot to that aluminum-colored ring and then I will install everything. I can take pics and write up a DIY if there is interest.
Ershall is offline   Reply With Quote
Old 05-23-2004   #54 (permalink)
EM2Civic
Senior Member
EM2Civic's Avatar
EM2Civic is an unknown quantity at this point
OR you can cut out the lower part of your stock shift knob, it works for my RAZO shift konb
EM2Civic is offline   Reply With Quote
Tags
08999bak100 , 2003 , 2005 , attach , automatic , boot , civic , conversion , diy , door , honda , knob , manual , shift , shifter , size
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Shift Knob/Boot Fix
DIY: 2003 Center Console Removal
DIY: Replacing door lock Assembly and Actuator (UPDATED WITH PICS ON POST 27)
DIY: Dash Removal
How To Paint Trim Pieces
No More Trunk Rattle!
Removing The Rear Deck
DIY: Automatic To Manual Shift Boot And Knob Conversion
Removing The Center Console
Steering wheel removal and MOMO wheel install
Site Supporters
aluminum radiator
Honda car spoilers
