Step 1: Remove your stock hood. Start by detaching the washer nozzle lines from the hood.
Step 2: Place some rags between the hood and the car. This keeps you from scratching the paint.
Step 3: Remove the 4 bolts(2 on each side) with your 10mm socket.
Step 4: Even though the bolts are removed the hood stays attached to the hinges. There is an epoxy type material on the hood. Use a crowbar to pry it off. It's really easy.
Step 5: Remove the Hood.
Step 6: Open the box containing your new hood.
Step 7: Clean up your mess of peanuts.
Step 8: Remove the bubble wrap.
***NOTICE HUGE SCREW UP ON THE HOOD'S CORNER AND CRY FOR A FEW MINUTES***
***GO TO REHAB, GET TREATMENT, GO BACK TO INSTALLING YOUR HOOD***
Step 9: Bolt the new hood onto your car. Shut the hood and use the levelers to make the hood sit evenly on the car.
Step 10: Stand back and enjoy the great job you did on the hood.
Sponsored Links
