Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Engine
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-25-2006   #1 (permalink)
supermex
supermex's Avatar
supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all
DIY:AEM UEGO wide band system
Thre should be a gauge, 02 sensor, and two harnesess.
Raise trhe car and secure it with stands, you'll need to remove the jsck from the middle to work on the down pipe.
I went to the muffler shop in advance to get the 02 sensor bong welded into the pipe then I placed a temporary bolt to take the car home.
I placed the 02 sensor as shown.
This is going to be a large picture.
Plug in the sensor side of the harness then route the long wire thru a safe place around the engine towards the passenger side of the car.
Now is time to look on the inside of the car, right underneath the glove compartment pull the bottom panel off then pull the carper towards you exposing a grommet on the fire wall.
Run a small wire coat hangger thru the hole, tape the other end the run the wire thru.
I have a column mounted gauge cluster so I ran both end wires to it.
One of the harness goes straight from the 02 sensor the other goes to the positive power and ground.
Two additional wires are only optional for other uses in conjuction with the AEM ECU and are not needed.
Plug the booth harnesses on the back of the gauge as shown.
The face of the gauge can be changed to suit your gauges colors.
The install is relatively easy but you must know basic electric and mechanical functions , here is a copy of the wireing skematic provided
The check and clean up connections and panels, turn the ignition key on then the gauge will begun moving and dflickering for about 3 seconds then after you start the car it will start giving very acurate read out.
Good product very acurate and easy to install.
__________________
MY SHOW CAR IS FASTER THAN MY JDM CAR...FOR NOW
NX & AEM sponsored car.
2004 HONDA TUNING featured car.
1st Place at NOPI Nationals 2006
1st Place Funk Master Flex 2007
1st Place HIN's Night Shift 2007
434.3 hp 352 Lbs torque @ 21 Psi fully build D17A1
CARS WEBSITE
DRIVEN!
supermex is offline   Reply With Quote
Sponsored Links
Old 05-25-2006   #2 (permalink)
dj02
Post Master General
dj02's Avatar
dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all
Send a message via AIM to dj02
wouldnt hurt we dont have one.
__________________
-OuTuViT-
"Computer games don't affect kids,
I mean if Pac-Man affected us as kids,
we'd all be running around in darkened rooms,
munching magic pills and listening to repetitive electronic music."
-Kristian Wilson, Nintendo, Inc, 1989
it has been said that sometimes,
something as small as the flutter of a butterflys wing
can ultimatly cause a typoon
half way around the world
-chaos theory
The Edge... there is no honest way to explain it
because the only people who really know where it is
are the ones who have gone over.
-Hunter S. Thompson
dj02 is offline   Reply With Quote
Old 05-25-2006   #3 (permalink)
diskreet
diskreet's Avatar
diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold
Of course write one up. I dont need it but I would love to learn as much about cars as possible! Ill rep you for sure!!!
It will at least help someone, and that is enough for me to write a DIY, so why not you? (I did 3 so far.)
And I never realised it before, but 175+ hp/L is amazing!!!
diskreet is offline   Reply With Quote
Old 05-30-2006   #4 (permalink)
supermex
supermex's Avatar
bump
__________________
CARS WEBSITE
DRIVEN!
Old 05-30-2006   #5 (permalink)
scansel912
Platinum Member
scansel912's Avatar
scansel912 is just really nice scansel912 is just really nice scansel912 is just really nice scansel912 is just really nice
Send a message via AIM to scansel912
Nice DIY
__________________
B18C1 Powered 1992 Honda Civic Si
scansel912 is offline   Reply With Quote
Tags
07 , 93 , aem , civic , diy , gauge , install , o2 , review , sale , sensor , si , uego , wideband , wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Aem UEGO 30-4121 mxcivic Other Honda Civic Parts and Products 0 08-09-2005 09:23 PM
NEW in box AEM UEGO $305.00 SHIPPED jwcardy Honda Civic Parts for Sale 7 07-24-2005 05:55 PM
Wide Band o2 Sensor Location KalliGarri Forced Induction and Swaps 7 03-07-2005 08:31 PM
Fs: Aem Uego Wideband Gauge Type jwcardy Honda Civic Parts for Sale 9 10-24-2004 06:42 PM
wide band o2? with gauge jturbolx Other Honda Civic Parts and Products 9 10-08-2004 10:00 PM
User Login
Our Partners
used new
Top 10 Threads
DIY - DX/LX head swap to EX Vtec
Stafford Fabrications Turbo Installation
DIY: Ingalls "Stiffy" Engine Damper & Review
DIY: Installing AEM CAI
DIY: Timing Belt Replacement
DIY: Fuel Filter Replacement
DIY: Valve Clearance Adjustment
Adjust the throttle cable
DIY: Oil Change
K20 Swap in the 7th Gen Civic
Site Supporters
aluminum radiator
Honda car spoilers
