Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Engine
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-14-2004   #1 (permalink)
Forum Bot
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
DIY: Valve Cover Painting
DIY Wire Cover - Official Thread
When i popped the hood of my new car and saw the plain, black plastic wire cover, i knew i had some work to do.. so i went to my local shop and got some professional engine paint (up to 500 degrees F) and some primer and got to work.. overall, i got about 20 bucks in stuff, and my cover came out great..
1. Removed wire cover by twisting plastic screws about 1/8th of a turn in either direction and lifting.
2. Cleaned very well.
3. Applied 3-5 coats (all coats were very thin) of primer and let set.
4. When primer dried, i used painting tape (the kind that comes of very easily as not to harm what's underneath) and an exact-o knife to very carefully mask off the Honda and VTEC letters on the cover, as well as the indentations at the bottom.
5. Next, I applied 4-6 Coats of red paint to the cover, and allowed to dry for 3 hours.
6. I removed the tape and masked off the rest of the areas, allowing me to paint all areas not painted red black w/ 4-6 more coats.
7. Finally, I allowed everything to dry overnight, and clear coated my cover with another 5 thin coats of paint.
8. the Finished product: a professional looking red valve cover with black lettering for the price of 20 bucks + a few hours of my time.. takes a lot of patience to do a good job.
Forum Bot is offline   Reply With Quote
Sponsored Links
Tags
2009 , 8th , black , civic , code , cover , diy , engine , h22a , honda , k20 , paint , painted , painting , red , valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY - DX/LX head swap to EX Vtec
Stafford Fabrications Turbo Installation
DIY: Ingalls "Stiffy" Engine Damper & Review
DIY: Installing AEM CAI
DIY: Timing Belt Replacement
DIY: Fuel Filter Replacement
DIY: Valve Clearance Adjustment
Adjust the throttle cable
DIY: Oil Change
K20 Swap in the 7th Gen Civic
Site Supporters
aluminum radiator
Honda car spoilers
