Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Engine
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-14-2004   #1 (permalink)
Forum Bot
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
Adjust the throttle cable
The throttle cable is one of the easiest ways to get a little more response out of our cars.
Honda keeps extra slack in the cable for 'granny' drivers so they don't rear end people! The rest of us on the other hand WANT that extra jump off the line! Here is how...
  1. First get a set of wrenches to fit the two nuts.
  2. Then loosen the locknut enough to when you pull the cable, their is about half as much slack.
  3. Next, tighten the adjusting nut so the cable stays put.
  4. Your all set! All you need to do is make sure the car does not idle any higher once warm.
Enjoy the added throttle response!
Forum Bot is offline   Reply With Quote
Sponsored Links
Tags
1998 , 2000 , adjust , adjusting , adjustment , automatic , cable , cables , car , civic , h22a , honda , hondas , throttle , tighten , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY - DX/LX head swap to EX Vtec
Stafford Fabrications Turbo Installation
DIY: Ingalls "Stiffy" Engine Damper & Review
DIY: Installing AEM CAI
DIY: Timing Belt Replacement
DIY: Fuel Filter Replacement
DIY: Valve Clearance Adjustment
DIY: Oil Change
K20 Swap in the 7th Gen Civic
Site Supporters
aluminum radiator
Honda car spoilers
