Electronics Post your electronic questions here!
Vtec idles high while in neutral
Old 03-09-2016
VtecFletch's Avatar
VtecFletch is an unknown quantity at this point
I swapped a d17a1 from my manual car for a d17a2 that has an auto trans. wiring harness. I have the ecm from the d17a2 in the car. Hooked up the 02 sensors and had it flashed at the dealer and its running great except when I pull it out of gear and coast to a stop light. Rpms settle to idle speed then increase to 1000 to 1100 until I stop. Anyone know why and how to fix this nuisance?
Old 03-10-2016
Re: Vtec idles high while in neutral
You have a PCM for an automatic trans installed into a manual trans car?
You probably need the correct PCM first.
PCM reset, then idle relearn?
Old 03-19-2016
XXWoodmanXX's Avatar
XXWoodmanXX is an unknown quantity at this point
Before a PCM swap, I'd just try the idle re-learn first, and see if that resolves it?
LilNic13
SOHC D17Ax non-VTEC - VTEC Engine Swaps
16
11-05-2018 10:45 AM
thisguy357
11-30-2015 08:57 PM
steve6
11-22-2015 08:18 PM
PunX
09-23-2015 10:45 PM
1stcivic
11-18-2001 09:17 PM
Quick Reply: Vtec idles high while in neutral
