DIY 04/05 tail light conversion (with factory parts)
Old 09-28-2010
sam68's Avatar
sam68 is an unknown quantity at this point
Hey guys this is my first DIY and I know there is already one on the tail light conversion but I wanted to do one with factory parts. This is to convert 01-03 Coupe tails to 04-05 I borrowed a few pictures from Gearbox hope that is ok so here goes. I printed out the price of the parts from Majestic Honda and took it to my local dealer and they matched their prices, or just order from Majestic. Anyway hope this helps some people out, I had a hard time figuring out which parts to order especially the pigtails (I got the wrong ones the first time).
Parts needed:
1. 04/05 tails
2. Two factory turn signal sockets part # 33304-S30-003 $6.50 each
3. One pack of connectors (they come in packs of 5 so only order 1 pack) part # 04321-SH2-307 $4 per pack again only one pack needed
4. One pack of Pigtails (they come in packs of 10 you will only need 4 of them) part # 04320-SDN-A00 $8.00
5. Two new signal bulbs Part # 33303-SL4-003
Steps
1. Pull the plastic screws holding the trunk carpet and peal it back so that you can get to the backside of the tail lights.
2. Remove all four sockets from the tail light housing.
3. Remove the four nuts holding your old tail lights in and gently pull the lights out, watch the plastic tabs do not break them.
4. Now bolt in your new tail lights, you may have to trim the foam piece if you are reusing it like I did just take your time and only cut it where you need to it's pretty obvious when you look at it.
5. Only three Socket/bulbs are used in the new tails, the one all the way to the right wont be used it's the side marker, remove the socket/bulb from the connector and zip-tie old connector to the harness, I put the old socket/bulb back in the old tails for safe keeping.
6. Plug in the reverse light & the brake lights into their respective sockets. In the picture the top socket brown with blue connector is the brake/running lights, and the reverse lights are the dark gray socket with the green connector, it's the bottom right in the picture. The new turn socket Light gray socket & Connector (completed in this picture) is bottom left, and the connector hanging is the old side signal connector (not used in the new tails).
7. Now unplug the black connector from the large signal socket and clip it off about an inch from the connector so you can reuse it if you ever want to put your stock tails back in.
8. Ok it's time to put your new connectors together. Take the new connector and install the new pigtails into them (two each).
Now simply push the connector into the new socket and install the bulb
9. Use wire connectors or solder the wires to the harness. I chose to use connectors so that I could easily put my stock tails back in down the road either way will work.
This is what your final connection will look like.
10. almost done just plug your signal socket into the tail light, button everything back up and your done.
Here is the finished product looks much better IMO.
File Type: jpg
Old 05-25-2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Re: DIY 04/05 tail light conversion (with factory parts)
Very good DIY.
Old 09-12-2015
rallyeredem0's Avatar
rallyeredem0 is an unknown quantity at this point
doing this next weekend
Old 10-18-2016
trellex's Avatar
trellex is an unknown quantity at this point
This seems wayyy too easy. I'll be doing this very soon! Cheers!
Old 07-30-2017
Alfa beast's Avatar
Alfa beast is an unknown quantity at this point
The pictures not showing
Old 07-30-2017
Received 1,144 Likes on 799 Posts
Its because photobucket sucks now
Poopies
04-20-2017 11:36 PM
Erndog81
10-31-2015 03:01 PM
shaejb15
04-12-2015 11:38 AM
1028CiViC
Bolt-on Engine Performance
11-18-2001 05:02 PM
Quick Reply: DIY 04/05 tail light conversion (with factory parts)
