DIY: Changing Spark Plugs w/pics (noob version)
#31
Rep Power: 787 Re: DIY: Changing Spark Plugs w/pics (noob version)
yeah the dealer here charges something like $80 for plugs and another 80 or so for labor lol.
#34
OP - Thanks for the post. Changed mine today and this post definitely helped.
Now - I'm thinking of getting a cold air intake - is that easy? Given changing spark plugs / air filters is all i've done myself with my car. It's a 2000-Ex.
#35
I wil fix vBPlaza today
1 Post
Rep Power: 280 Re: DIY: Changing Spark Plugs w/pics (noob version)
#38
Man, thanks a million for the instructions with pics on how to change plugs! The Honda dealership wanted to charge me $216.00 to change them! Highway robbery! So, I got online, searched for how to change plugs honda civic and found your article. I've got 116000 miles on my 06 civic, and it was time to change them, (I commute 110 miles roundtrip 5 days a week). The only problem I had was I had to go buy a long extender for my socket because the extender that came with my rachet set wasn't nearly long enough, went to wal-mart, bought an extender Stanleys (3 different lengths) came in a package for 12 bucks. Took me about 30 minutes, I didn't heed your warning and waited till the engine cooled off, so the 1st one I took out was really really hot.
Again, thanks a million!
Joe
2006 Honda Civic Owner!!!
Joe
#39
Thanks for the simple walk through. I got tired of mediocre service and decided to change the oil and spark plugs myself, for the first time today. What a good way to get to know the vehicle better. I drive it most of the day, daily, and know it well from a driver's perspective. I replaced the old plugs with NGK Iridium X spark plugs, and noticed quite a difference, even if it was just the fact of having fresh spark plugs installed.
Now to figure out an easy way to get an oil filter off of a 2000 Civic VP...
Thanks
Thanks
#40
on the pics where it says, "you will have to disconnect the harness". I still can't figure out how to actually separate the harness from what I call the base - that is secured by the small nut. I don't want to pry it from the base because of damaging it.
Can anyone explain this in detail?
Mike P.
Mike P.
#41
Rep Power: 0 Re: DIY: Changing Spark Plugs w/pics (noob version)
Wow I think it's funny that all of these people didn't know how to change their spark plugs.... I guess this DYI really does help!! If any one wants a lesson on Changing your oil just PM me, i'm sure I can muster up some pictures for ya!
#42
1 Post
Mike P.
Mike P.
#43
Sorry for the thread revival but thanks to the OP for posting this thread. I just got my first car ('02 Civic EX) and I'm in the process of learning how to do my own maintenance since I've always loved fixing things.
I went down to my local Advance Auto Parts and picked up some Bosch Platinum +2 spark plugs. I already had a spark plug socket and an extension so I was all set. Only took me about 15 minutes to swap out my plugs and I couldn't be happier with the result. My engine runs much smoother now. Thanks again!
#46
Whachya lookin at?
Rep Power: 289 Re: DIY: Changing Spark Plugs w/pics (noob version)
^ Your supposed to yes But I bet most have been getting away with not doing it. I do it every time I pull the coil pack off.
#47
Sorry for stepping in... I'm in the process of upgrading my plugs too. I just read about "dielectric grease"... what is that??. I'm lost here?. Do I need to do something to the coils packs before plugging them into the new plugs?... I was going to clean them with a rug, but dielectric grease is something that I have to get?.. thanks!!
#48
Whachya lookin at?
Yes you should still use it. You should apply it to the boot and the ceramic portion of the spark plug.
Dialectic grease is non conductive and seals the plug to the boot or the coil pack, not allowing moisture to get in and helping to eliminate corrosion. Corrosion of the contacts could cause misfires and a rough idle, and you don't want that.
Be sure to get it from an automotive place because automotive dielectric grease is high temp, and there is low temp stuff which you don't want to use.
Hope that helps
Hope that helps
#49
Hope that helps
Hope that helps
#50
nice write up you did a great job and ill be using this info this week im done paying out the butt for tune ups time i learn on my own.
#52
Whachya lookin at?
Yea the point is to SEAL it so you want to make sure there is enough on there. That's why you apply it to the coil as well. Everyone does it differently and I don't think it's too important so that works too. By the boot I mean the coil pack Cornelis.
#53
Rep Power: 232 Re: DIY: Changing Spark Plugs w/pics (noob version)
the only reason i dont apply any to the boot is so that no grease accidentally gets on the spark plugs terminals.
#54
Since there is a boot instead of wires, would it be a good idea for me to get some replacement boots as well?
#55
never use bosch plugs or any other brand except ngk/denso on a honda. i guess he will be back in a month asking why he has multiple cylinder misfires.
#56
EDIT: Nevermind. I found the answer to my question. I'll be getting a set of Iridium IX's (part # 6441) later today.
EDIT 2: Just got some NGK Iridium IX's and put those in. I think they give me a bit more power than the BOSCH Platinum +2's did. I'll probably try selling those BOSCH ones as slightly used. haha
#57
i found something interesting when i searched for ngk plugs nothing came up for my 2004 VP onley DENSO but they came up for the DX i thought the DX and VP had the identical engine i also noticed that DENSO uses a different gap then all the rest they use .035 as opposed to .044 whqts the deal ???
#58
i noticed too. all 01-05 civic engines use the same part numbers for plugs and should be gapped .044 stock. im not sure if that smaller gap is a typo or not. im pretty sure the denso iridium is more than .035 tho. i can check again, i have some spares waiting to go in this summer.
#60
complete garbage. worse than bosch, i wouldnt even use it in my lawn mower.
