Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Electrical
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-22-2005   #1 (permalink)
eddiechaps
i love my morreale
eddiechaps is a glorious beacon of light eddiechaps is a glorious beacon of light eddiechaps is a glorious beacon of light eddiechaps is a glorious beacon of light eddiechaps is a glorious beacon of light eddiechaps is a glorious beacon of light
Send a message via AIM to eddiechaps Send a message via MSN to eddiechaps
M3 Mirrors with LEDs Install.
M3 Mirror w/ LED Wiring instructions:
I chose to go with alternate signal wiring. This means that when parking lights are on, the mirror signal will also be constantly on. When signal is used, the mirror will flash alternately with front signal.
Now first you will need:
18 Gauge Wire
Electrical tape
10mm socket.
0.8mm socket.(5/16”)
Phillips head screwdriver
M3 Mirrors
How I did this:
Since I have projectors, this may be a little too enxtensive for you. But I found it easier to access my wires this way.
1. Put the window down. Pull the piece on the inside around where the mirror is up as hard as you can it should pop off.
2. Using the 0.8mm socket remove the nuts around the mirror.
3. Then , pull off the rubber piece on the miror. Get some wd-40 and a vise grip. Spray the wd-40 all over the nuts. Then after a fdew moments grip the nut & start to loosen.
4. Attach the mirror to the car. In mine I only used two out of the three bolts since the other one didn’t fit properly.
5. Remove the front bumper cover. Here’s how you do that: http://www.7thgencivic.com/forums/sh...d.php?t=155290
6. Follow the DIY to remove your headlights.
7. Unplug the bulbs from the electrical connectors. Cut the wrap around the turns signal bulb’s wires. (That’s the bulb marked 7443.)
8. Locate the red and green wires & strip/cut them.
9. Put the white wire to the green wire if you want the mirrors to light up blue when on with the headlights & to flash blue/amber when you are turning. (only amber will appear when turning without lights on.) Put the blue wire to the red wire. Ground to ground. If need be use some wire to lengthen each.
10. Double check before you put electrical tape around the connections to make sure the right lights light up.
I had a video of the blinking leds but idk where to upload it to so I can use it on here. Hope this helps people in the future. Reply to this post or PM me if you have any questions.
Final Result:
And at night...
__________________
7thGenNinja #31
DIY: Click here
MySpace
RIP Diana Ham
Quote:
Originally Posted by XxSoVeReiGNxX
amazing! that brings out a sophisticated quality to the greasecovered supertuner known as eddiechaps.
eddiechaps is offline   Reply With Quote
Sponsored Links
Old 02-22-2005   #2 (permalink)
silverem2
silverem2's Avatar
silverem2 is a jewel in the rough silverem2 is a jewel in the rough silverem2 is a jewel in the rough
looks awsome, show us some nighttime pics
silverem2 is offline   Reply With Quote
Old 02-22-2005   #3 (permalink)
QBoi
QBoi's Avatar
QBoi is a glorious beacon of light QBoi is a glorious beacon of light QBoi is a glorious beacon of light QBoi is a glorious beacon of light QBoi is a glorious beacon of light QBoi is a glorious beacon of light
Send a message via AIM to QBoi
Wow nice, I was gonna get some, but the car is gone now. How long did it take you?
__________________
http://www.7thgencivic.com/memberrid...07qboisig1.jpg
EASY HORSEPOWER!
Supah Fly Civic Gurlies Member #69
QBoi is offline   Reply With Quote
Old 02-22-2005   #4 (permalink)
eddiechaps
i love my morreale
about an hour. the tough part was getting the damn wires fed through the fender to the engine bay.
__________________
7thGenNinja #31
DIY: Click here
MySpace
RIP Diana Ham
Old 02-22-2005   #5 (permalink)
QBoi
QBoi's Avatar
Gotta be longer for us inexperienced fools
__________________
EASY HORSEPOWER!
Old 02-22-2005   #6 (permalink)
HappyGilmore
Senior Member
HappyGilmore is an unknown quantity at this point
Is that M3 power mirror or manual?
Good job btw.
HappyGilmore is offline   Reply With Quote
Old 02-22-2005   #7 (permalink)
eddiechaps
i love my morreale
Quote:
i never did wiring like that before.
Quote:
Good job btw.
manual.
__________________
7thGenNinja #31
DIY: Click here
MySpace
RIP Diana Ham
Old 02-22-2005   #8 (permalink)
04vic
Member
04vic is an unknown quantity at this point
what size wire?
04vic is offline   Reply With Quote
Old 02-22-2005   #9 (permalink)
zachgeyer
zachgeyer's Avatar
zachgeyer has a spectacular aura about zachgeyer has a spectacular aura about
Send a message via AIM to zachgeyer
nice never the less
zachgeyer is offline   Reply With Quote
Old 02-22-2005   #10 (permalink)
zachgeyer
zachgeyer's Avatar
ebay?
Old 02-22-2005   #11 (permalink)
eddiechaps
i love my morreale
Quote:
Originally Posted by 04vic
what size wire?
18 gauge
__________________
7thGenNinja #31
DIY: Click here
MySpace
RIP Diana Ham
Old 02-22-2005   #12 (permalink)
eddiechaps
i love my morreale
Quote:
Originally Posted by zachgeyer
ebay?
yes inexpensive too.
__________________
7thGenNinja #31
DIY: Click here
MySpace
RIP Diana Ham
Old 02-22-2005   #13 (permalink)
silverem2
silverem2's Avatar
i guess my nighttime pics didnt get a response.lol
Old 02-22-2005   #14 (permalink)
eddiechaps
i love my morreale
for ati9700pro
__________________
7thGenNinja #31
DIY: Click here
MySpace
RIP Diana Ham
Old 02-22-2005   #15 (permalink)
shmik1
shmik1's Avatar
didn't I hear someone say m3 mirrors suck and u cant see anything? u should take some daytime pics from the outside (like a normal pic of the whole car) do they flow well with the car?
shmik1 is offline   Reply With Quote
Tags
2001 , 2004 , civic , honda , install , installation , installing , instructions , led , m3 , mirror , mirrors , power , style , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
retrofitting mirrors... gh0st Lighting 7 02-04-2005 12:24 PM
WTB Mirrors. Please Help! Ike Honda Civic Parts Wanted 0 11-16-2003 09:02 PM
what kinda paint should i use?!?! 2k1lxcoupe Honda Civic DIYs and Civic Tech Chat 3 08-28-2003 02:58 PM
Andy's M3 Mirrors 01EXtc Other Honda Civic Parts and Products 16 01-22-2002 12:12 PM
User Login
Our Partners
used new
Top 10 Threads
Grounding Kit Install
2001-2003 Honda Civic ECU Wiring
Installing Triple Air Horns /w Dual Compressors
Cruise Control Relocation
Power Locks for DX Owners
M3 power mirror wiring help!!!
Site Supporters
aluminum radiator
Honda car spoilers
