Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Electronics
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-10-2006   #16 (permalink)
Honda_Inspired
Senior Member
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
Hey guys and gals! This morning, after I was released from my govt. class, I rushed home to call Alterstart about the problem and they said it may be a possibility that the brushings need time to "break-in." I then went out and tightened the belt to a .25" deflection (was @ .5") and it seemed to have improved. The battery warning light has only blinked 3 or 4 times during the entire 30 mile trip from home to work. The duration of the "blink" is less than a second. Everything seems to be fine as I have made it to work in one piece and bumping my stereo on loud in the company parking lot. My prognosis - a healthy organ transplant that needs some further evaluation. Will keep ya'll posted.
-Lewis
Honda_Inspired is offline   Reply With Quote
Sponsored Links
Old 11-10-2006   #17 (permalink)
burke420
The World Is Yours!
burke420's Avatar
burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned
Send a message via AIM to burke420
ill elt you know how it install this weekend. i need to wire up the connectors, and go from there...thanks for the help..!
__________________
I MY Honda
Enkei RPF1
Type 1 Racing SPL exhaust
TEIN Hood Damper
Cusco front strut bar
FUNCTION7 LCA
burke420 is offline   Reply With Quote
Old 11-10-2006   #18 (permalink)
Honda_Inspired
Senior Member
Hello again guys and dolls! I just got home from work, stopped by wal-mart and got myself this bad boy for $15 bucks:
^it's a voltmeter that simply plugs into your cigarette lighter - a great alternative to the 52mm voltmeters in which you have to install into a guage pod.
This voltmeter convinced me that there wasn't anything wrong with my alternator. It's just the voltage regulator in my alternator that isn't in sync with my charging system (no big deal - just annoying flick of battery light once in a while). After observing the voltage changes on the voltmeter, I noticed at the point when the battery warning light starts to flicker (for a millisecond), the voltage dropped down to 12.5 volts! This is odd considering the normal voltage is SUPPOSED to be 13.5 when the car's engine is on. But since this is a high output alternator, it rapidly charges the battery full and the voltage regulator kicks in and limits current flowing into the battery so it doesn't overcharge (thus the brief flash of the battery light). So after the voltage regulator kicks in and makes the battery light flash once and turn off, the volts drop down to between 12.5 - 13.0 volts until more load is on demand. Once I turned on my A/C & stereo all the way up, voltage regulator sees this (doesn't flash light this time) and bumps up the voltage from 12.5 volts to a healthy 13.8 volts! Long story short, my efforts in installing a HO alternator wasn't wasted at all
Engine on:
Engine off:
I highly recommend this voltmeter if you actually care about your electrical system - it's a must have! I even sacraficed the plug in which I use to power my radar detector and put this voltmeter in its place.
I'm one happy camper for now
Let's see in the longterm how this high output alternator treats me.
Old 11-11-2006   #19 (permalink)
burke420
The World Is Yours!
burke420's Avatar
nice addition... i am prolly gonna install my alternator tonight, or tomorrow. i got the matertials...just procrastinating right now! hehe but i heard a impala at my local sound shop i talk to, and they installed...2-13W7s with 2-1000 JL amps, one for each sub, a 450/4-mids,highs, TV, light a 200 amp alternator, and they said to ground the alternator to the battery... so ill add this to my install..just lending you any info i recieved.
__________________
I MY Honda
Enkei RPF1
TEIN Hood Damper
FUNCTION7 LCA
Old 11-13-2006   #20 (permalink)
burke420
The World Is Yours!
burke420's Avatar
i onstalled mine, battery light, i gotta get a battery fusr, mine blew, then ill check up on it....update later i will..
__________________
I MY Honda
Enkei RPF1
TEIN Hood Damper
FUNCTION7 LCA
Tags
03 , 05 , 2003 , 2004 , ac , alternator , alternators , belt , civic , deflection , drive , high , honda , output , si , upgrade
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Reset Your SRS Light
VAFC II Full Installation Info
VTEC Light (with Pics)
Air/Fuel Gauge Install
Installing a Tach
Reverse Indiglo Gauges
Push Button Ignition
DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Replace Stock With Aftermarket Horn
A'PEXi VAFC Install #2
Site Supporters
aluminum radiator
Honda car spoilers
