Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Electronics
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-21-2004   #1 (permalink)
xproductionz
xproductionz's Avatar
xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
VAFC II Full Installation Info
Contrary to what people say. VAFC2 is the only one that will work on our 7th gen cars running D17 engines and vtec.One day I was doing a head swap into my DX and putting a EX head so i would have vtec capabilities and needed the wiring diagram for our cars.. as i was doing the install i notcied that not all the wires were being connected and used considering APEXI doesnt have the proper diagram for our cars... Which in turn is why i created this full install...With that in mind, while installing the unit i noticed that the manual that came with the thing does not have our car model listed but it does have our engine D17 listed... its listed as EU3 or EU4 in the book which says to use diagram H8-a... this is wrong.. it will get u the right install but not all the wires connected.. yes i know there is another thread that says its missing the VTM wire... but it is also missing another wire.. the TDC wire.. when installing the VAFC2 u should follow diagram H7-b which shows u were to connect the VTM wire and TDC wire.. but DO NOT connect the VTC CAM SIGNAL wire cause we do not have that on our cars... that wire on the ECU is for the Secondary 02 Sensor and not the VTC.. just tape it off and put it to the side cause its the only wire that wont be used.... the diagram also shows where to connect the VTM wire..Basically u are using a combination of diagram H8-a and H7-b to complete the install.. After creating this install guide GEARBOX has also gone back and redid his wiring to connect the rest of the wires.. He also has gone and made a modified version of Diagram H8-a which shows the rest of the connections.... My car runs fine and so does gearbox and hope this helps with everyones install. ~xproductionz
*Here is the updated wire diagram. I don't know what benefit the TDC will give, but it's better to just have it hooked up. Thanks for the info. ~gearbox
The second piece of info you need to install this thing is the vafcII harness color code from the manual. This will show you how to match up the harness wires to the ecu wires. This diagram is ONLY for showing what each color means and whether the wire should be cut or spliced. The diagram above actually tells you where to wire them on the car.
Enjoy, ~gearbox.
Also you should know that the air/fuel ratio most likely cannot be adjusted because the ecu on 03-04 civics will adapt and counter any changes made with the vafcII over time. So I guess it's still useful to monitor engine functions like rpm, voltage, etc. This has yet to be proven with actual dyno results. ~gearbox
Also keep in mind that it hasnt been proven true yet that the ecus on 03-04 actually counter the changes.. but based on a 1 or 2 peoples experiences they say it does.. we will find out soon enough when somone puts the vafc into there car and get it dynoed and then gets it dynoed again like a year later or so. ~xproductionz
INITIAL SETUP PROCEDURE--Very Important!!
Just after the install is done, you need to set certain functions in order for the vafcII to work with your car. As far as I know, these will work for a D17 1.7L SOHC VTEC engine on 2001-2004 civic EX.
If you started the car without performing this setup, you will need to reset the ecu and start over.
After the install, turn the car to the ON position but do not crank the engine. The vafcII display should now be active.
1) Sensor number IN 06 OUT 06
2) Number of cylinders = 4
3) Throttle position = arrow pointing north-east
4) Vtec number = 3
5) hold down accelerator for 10 secs, then release for 10 secs
Turn off the car and remove the key to save settings. It is now safe to start the car for the first time. There should be no check engine light at all.
DO NOT ever adjust any vafcII settings when the engine is running!! All changes including vtec engagement and fuel tuning must be made when the car is on, but engine is off, as described above.
It is strongly recommended that a dyno be used to measure and adjust the air/fuel ratio for your vehicle. The ideal ratio is 14.7:1 which is best for combustion and emissions.
As a general rule, our cars tend to run lean in the lower rpms and rich in the upper rpms, although this is not always true.
Have fun, ~gearbox.
Rule of thumb everyone... If u can... SOLDER the wires together cause based on exerperience i have had it where the connectors they provide come loose.. and it has happened to me on my 98 civic and actually blew my ecu... if u cant do it during the install now then u might want to put that on ur TO-DO-LIST for the future.. ~xproductionz
xproductionz is offline   Reply With Quote
Sponsored Links
Old 08-21-2004   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
What does the TDC wire do? I better double check which wires I hooked up. I hooked up all of them from this wire diagram. What do I need to do differently?
gearbox is online now   Reply With Quote
Old 08-21-2004   #3 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
Send a message via ICQ to Hwoody77 Send a message via AIM to Hwoody77
You don't use the TDC wire, that's for Top Dead Center sensor I believe, and it's only used on i-VTEC engines...which we don't have...
Hwoody77 is offline   Reply With Quote
Old 08-21-2004   #4 (permalink)
gearbox
Super Moderator
Okay, that's what I thought.
Old 08-21-2004   #5 (permalink)
xproductionz
we have the TDC on our cars.. its the wire right below the throttle signal.. pin #26 (green wire).. i put it on cause i didnt want to leave the wires hanging or unconnected.. now u can actually see the TDC on the screen now.. just wanted to have every wire connected except the VTC wire
Old 08-21-2004   #6 (permalink)
gearbox
Super Moderator
What does TDC look like and what does it mean?
Old 08-21-2004   #7 (permalink)
xproductionz
TDC means top dead center.. it tells the VAFC when it hits TDC... its in the manual.. if you still got it... if you look on the ECU its the green wire coming out.. pin #26 right underneath the throttle signal wire.... from ur VAFC it would be the light blue wire.. not the dark blue
Old 08-21-2004   #8 (permalink)
gearbox
Super Moderator
Okay I'm gonna try it and then post a pic and make this thread a sticky.
Old 08-21-2004   #9 (permalink)
xproductionz
thats cool.. i found all this out when i was doing the head swap on my dx and installing the vafc... had to go through a few wiring diagrams to figure it out... .. maybe the DIY head swap should be moved here and made into a sticky too.. lol
Old 08-21-2004   #10 (permalink)
gearbox
Super Moderator
I tried it and now under sensor check there's a "dot" that blinks on and off. Is that what it's supposed to do? I'm guessing it is, since it didn't do that before. Thanks. I'll add it to the diagram.
Old 08-21-2004   #11 (permalink)
xproductionz
yup.. thats whats its supposed to do... the shop told me that even though some people says its only for i-vtec that it helps the VAFC determine what position ur motor is thus making it easier to tune...i'll know for sure when i take my care to the dyno guys and ask them
Old 08-21-2004   #12 (permalink)
gearbox
Super Moderator
Cool thanks again. One thing I noticed was the engine would make some growling nioses when I raised vtec, so maybe it needs this extra sensor input to match vtec engagement with tdc. Maybe. Let us know what happens.
Old 08-21-2004   #13 (permalink)
xproductionz
yea.. did urs get louder too.. thats what mines did and it pulled slightly more when i was running on an abandoned back road.. but only a dyno will tell the story
Old 08-21-2004   #14 (permalink)
gearbox
Super Moderator
Well the engine wasn't too happy sounding starting when vtec should have engaged but didn't. I just set it back to stock engagement since that felt like the best performance.
Old 08-21-2004   #15 (permalink)
xproductionz
have u played with the vtec unmatched setting yet.. that might be why
Tags
17 , 2002 , 96 , civic , connect , diagram , install , manuel , safest , setup , sohc , tach , vafc , vafc2 , vafcii , wires , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Reset Your SRS Light
VTEC Light (with Pics)
Air/Fuel Gauge Install
Installing a Tach
Reverse Indiglo Gauges
Push Button Ignition
DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Replace Stock With Aftermarket Horn
A'PEXi VAFC Install #2
Site Supporters
aluminum radiator
Honda car spoilers
