Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Electronics
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-18-2005   #166 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
cor = a/f correction factor. I have mine set to 4mode display with cor, throttle position, rpms, and battery voltage. The correction shows you when the vafc is modifying the air/fuel ratio from stock. All the v-things are for the vtec correction I think? Glad it's working. Now get it tuned on the dyno. To remove this ad, register today for free or log in if already registered!
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Sponsored Links
Old 03-18-2005   #167 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Send a message via AIM to SODJAZERO Send a message via Yahoo to SODJAZERO
Ok fellas i found out what the problem was. The shop that had installed my return fuel line, connected the external pump to the wrong power connection and it was drawing current away from the altenater. Wich inturn was causing the external pump to faid during WOT. (I SURE HOPE I DIDNT DAMAGE A HG DURING ALL THIS) I was getting a p1298 code, wich pointed to the ELD or HIGH ELECTRONIC LOAD DETECTOR. Wich explained why i was only having this problem while on HIGH throttle. It was weird because my power windows were suffering too because of the connection source they used. They should have used a relay straight from the battery to power the pump, instead they used something direclty from the ecu harnes. What this is i dont know, heck i dont even care anymore. So i removed everthing hoses ect wires ect....Went back to stock. The car works fine. So now the moral of the story is, if you decide to do a return line conversion make sure its somewhat like the slp fuel kit, meaning intank pump ect.
Thanks gearbox and xproductions for all of your help.
__________________
"when I was younger I used to faint at the sight of blood, now that I'm older I noticed it ain't at the sight of blood, now the sight of blood equals the very sight of love, menstrual cycles feelin' like you right at your height of drugs" - TECH N9NE
_____________________________________________
183whp 175tq @ 7psi
Fs: Sony Ericcson W600i Brand New In Box 220 Shipped, price drop
SODJAZERO is offline   Reply With Quote
Old 03-19-2005   #168 (permalink)
xproductionz
xproductionz's Avatar
xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
Quote:
Originally Posted by parditty
Im so happy my VAFC II is working now, Got some questions now though. What does COR mean? VAI? & the other v thing? I think its like voc or something? The different displays is what i'm referring too
thanxs
heres the abbreviation for each
prs = intake pressure
thr = throttle position
rev = engine rpm
cor = air correction factor
vti = vtec signal in from ecu (if you have a ex ecu with a signal being sent out from it)
vto = vtec signal out from vafc
cai = vtc cam angle(we dont use these on our cars
bat = battery voltage.(comes in handy when you use the radio in your car alot but dont start the car to charge the battery.. just dont let it fall below 12.0 volts because when mine fell below to 11.9 the cqar didnt have enough juice to start)
and we dont have a VAI on ours so i think you got the CAI and one of the VTI or VTO mixed with it
xproductionz is offline   Reply With Quote
Old 03-19-2005   #169 (permalink)
xproductionz
funy you say that cause the other day i was talking with this one guy that works at another shop didnt know what the hell a D17 was... he was like damn i didnt know they made a D17... he was still stuck on the B and D16 series motors... and when i mentioned K20 he thought i was talking about some kind of gun..lol
Tags
17 , 2002 , 96 , civic , connect , diagram , install , manuel , safest , setup , sohc , tach , vafc , vafc2 , vafcii , wires , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Reset Your SRS Light
VAFC II Full Installation Info
VTEC Light (with Pics)
Air/Fuel Gauge Install
Installing a Tach
Reverse Indiglo Gauges
Push Button Ignition
DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Replace Stock With Aftermarket Horn
A'PEXi VAFC Install #2
Site Supporters
aluminum radiator
Honda car spoilers
