Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Electronics
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-20-2005   #136 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Send a message via AIM to SODJAZERO Send a message via Yahoo to SODJAZERO
Ok i was able to reset my safc.
Here is the next problem i am running into. When i am on HI throttle the car cuts out in the 3g and 5g rpm range. At first i thought it was because my safc was misconfigured. So today when i reset it and put the settings back. Then i made several pulls and the a/f gauge indicated that it was running rich and the car was performing normaly.
Then i drove round to a couple of places ie target, and went to get something to eat. On the way back home I stepped on it just to see that every thing was still ok. Well it wasnt, after resetting the safc, the problem still presist.
Has anyone else came across this problem? Really its kinda weird. For example, even tho the setting shows HI35% for 4600 rpm or 3200, its spiradic but it will cut out, or die out for a second, or the engine wont get any fuel or it will run lean. Let just say it cuts out for a second, then it starts working normaly through the rest of the rpm range while on high throttle. This ONLY happens on HI, i really cant detect this happening on low throttle.
This is really getting frustrating. Help needed.
__________________
"when I was younger I used to faint at the sight of blood, now that I'm older I noticed it ain't at the sight of blood, now the sight of blood equals the very sight of love, menstrual cycles feelin' like you right at your height of drugs" - TECH N9NE
_____________________________________________
183whp 175tq @ 7psi
Fs: Sony Ericcson W600i Brand New In Box 220 Shipped, price drop
SODJAZERO is offline   Reply With Quote
Sponsored Links
Old 02-21-2005   #137 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
I've heard the best throttle position for our cars is 25% narrow 80% wide.
I have a question. What happens when you reset the ecu? Is it a good idea to reset the vafc as well and wait for the ecu to adjust before putting the vafc settings back in? Or does it even matter?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 02-22-2005   #138 (permalink)
xproductionz
xproductionz's Avatar
xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
wait for the ecu to adjust to your car settings first before changing any settings would be prefered
xproductionz is offline   Reply With Quote
Old 02-23-2005   #139 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
Ive tryed both methods, resetting the ecu and ive also reset the safc, but problem still presist.
__________________
183whp 175tq @ 7psi
Old 03-06-2005   #140 (permalink)
parditty
parditty's Avatar
parditty has a little shameless behaviour in the past
Send a message via AIM to parditty
Thanxs For All The Help ;)
I just wanted to say to the 6 people I Instant Messaged over the week, THANK YOU!. I just installed my VAFC-II this morning. It's running good right now, I love to see the RED light come-on.. sikes me out..
The only thing is when I first got it installed I did the initial setup. But never setup when vtec should kick in just so I could drive it around to play with the monitor functions. And sure enough that ORANGE CHECK ENGINE LIGHT CAME ON! I think im gonna take off my negative battery cable tommorow and see if that fixes the check engine problem,.. We'll see though any suggestions?
thanxs again!
steve (AIM: snoughboarder)
parditty is offline   Reply With Quote
Old 03-06-2005   #141 (permalink)
gearbox
Super Moderator
Well if you have all the wires hooked up, the cel shouldn't come on at all. I have the vtec set to stock which is all stars ****. If you follow everything in the first post you shouldn't have a problem.
__________________
www.lubecontrol.com
Member 1025782
Old 03-06-2005   #142 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
im getting this code, any ideas?
P1298 Electrical Load Detector Circuit High Input
__________________
183whp 175tq @ 7psi
Old 03-06-2005   #143 (permalink)
gearbox
Super Moderator
Well the ELD senses electrical load on the alternator and turns it off when not needed. There must be something drawing constant current and preventing the ELD from shutting off the alternator like it should. Either you wired something from a fuse that you shouldn't have, or a fuse is blown. Or something else.
__________________
www.lubecontrol.com
Member 1025782
Old 03-06-2005   #144 (permalink)
xproductionz
u might also have wired the vtec or fuel wires wrong.. which is sending a voltage to something its not suppsed to
Old 03-06-2005   #145 (permalink)
parditty
parditty's Avatar
I got another Q guys.... For some reason It only does this every once in a while, while im driving, It wont let me go over 4000 rpm's and when i do it putters like it's not getting the fuel or somthing.. any help would greatly be appreciated it
Old 03-06-2005   #146 (permalink)
gearbox
Super Moderator
Well it does that when the check engine light comes on. So something wasn't wired up properly. See the first post for details.
__________________
www.lubecontrol.com
Member 1025782
Old 03-06-2005   #147 (permalink)
82801BA
Super Member
82801BA's Avatar
82801BA is an unknown quantity at this point
Send a message via ICQ to 82801BA Send a message via AIM to 82801BA Send a message via MSN to 82801BA Send a message via Yahoo to 82801BA
I had it once before, fuel cut off at 4000, but no CEL, after I went through a puddal. Well, never happened again since then.
__________________
Dynaudio 3-way is the worst system for tuning, but it's the best sound I've ever heard of....Finally, done tuning for staging....
82801BA is offline   Reply With Quote
Old 03-07-2005   #148 (permalink)
parditty
parditty's Avatar
GEARBOX & XPRODUCTIONZ..
I was looking at my installation and there are two wires left over there is a light blue wire and a blue wire. I was reading in step 4 of your install that the blue wire is supposed to go to the blue wire with a black strip on it? I don't see that wire anywhere on my ecu harness... any help?
AIM: snoughboarder
Old 03-07-2005   #149 (permalink)
parditty
parditty's Avatar
ya know what never mind, I was looking back at the first forum and saw the ecu diagram.. I 'll try that when I get home tonight.. thnxs
Old 03-07-2005   #150 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
The safc is no longer in my car and its still coming up with p1298. Ive reset the ecu several times
__________________
183whp 175tq @ 7psi
Tags
17 , 2002 , 96 , civic , connect , diagram , install , manuel , safest , setup , sohc , tach , vafc , vafc2 , vafcii , wires , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Reset Your SRS Light
VAFC II Full Installation Info
VTEC Light (with Pics)
Air/Fuel Gauge Install
Installing a Tach
Reverse Indiglo Gauges
Push Button Ignition
DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Replace Stock With Aftermarket Horn
A'PEXi VAFC Install #2
Site Supporters
aluminum radiator
Honda car spoilers
