Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Electronics
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-17-2004   #1 (permalink)
Forum Bot
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
Post Replace Stock With Aftermarket Horn
What you will need: Replacment Horn, Knowledge of how to remove Front Bumper. Phillips Head Screwdriver, Flathead Screwdriver (or prying tool), Socket Wrench, 10mm Socket
Time Needed: 30 mins. 15 mins with bumper removal knowledge.
Are you frustrated with the wimpy horn on your car? Sounds too wussy for Rush Hour traffic? Well here's a relatively Cheap and easy upgrade you can perform.
Alright, as long as you know how to remove the front bumper (check out my other How-To for the bumper) this will be a relatively quick swap of the horn. Begin by removing the bumper, the horn is located on the driver's side behind the lower bumper.
Removed Bumper
1.
Alright, I'm assuming you've removed your front bumper now. If you look carefully on the driver side of the car beside the windshield washer fluid tank you'll see the horn.
A closeup of where the Horn is.
2.
Here's a closeup of where the horn is located. See it? It's that black round speaker like thing between the radiator and the windshield washer fluid tank.
The Actual Horn And The Mount Arm
3.
You'll find that the horn is fastend to the chassis via mount arm. It's held on by a 10mm bolt, simply undo the bolt and you've got the horn in your hands.
FIAAM Freeway Blaster Horn
4.
Here's the horn I decided to replace my stock one with. It's a FIAMM Freeway Blaster Series Horn. Simulates a Big Rig Sound emitting a 132 decibel blast.
*NOTE* This is simply the horn I used, you can of course choose whatever horn you'd like, even air horns (although there'll be a few more steps to do to get those working, eg. relay, compressor etc.), just make sure your horn sounds when it gets 12v power to it. Also remember to check the amperage draw of the horn, to make sure your fuse can take it.
OEM Horn Un-bolted
5.
Alright you should have the OEM horn unbolted off the mount arm now. You'll notice a mini-harness plug that powers the horn which is grounded through the mount bracket itself.
Snipped
6.
Unless you somehow managed to find a horn that would directly plug into the harness, you'll have to cut the end off the OEM.
Terminal Crimped On to the End.
7.
Next for my particular horn, I crimped on a connecter to the end of the wire I just snipped. This will allow me to connect this to my FIAMM horn.
OEM Horn
8.
Here's the OEM horn. It Puts out a wimpy 110 decibels. Seeing that humans can only hear up to 120 dbs, it was never meant to deafen the guy who just cut you off. My FIAMM at 132 should do a great job of that.
Aftermarket Horn Mounted
9.
Here I have my aftermarket horn connected and mounted. It hooks up the same way, the wire I had connected a terminal to provides the 12v to the horn, whilst it is grounded through the mounting bracket. So that's it folks! Reverse the process and put back on your bumper (be sure to test before) and you're set!
*NOTE* you'll notice that I used the mounting bracket from the aftermarket horn, you may find that your horn fits better with the OEM mount bracket.
Mounting Location For Horn
10.
Alright here on the passenger side you'll notice there's room for a second horn. Once again I purchased a second FIAMM Freeway Blaster Series Horn, This time the High Note Instead of the Low Note
*note* - you may find that both horns mount better backwards (for these particular horns) the pictures show how you would normally mount them.
Second Horn Mounted
11.
Alright Here's the Pic of the High Note horn mounted in the open space on the passenger side. This will be the side that provides the most room, especially if you intend on installing an air horn.
You'll notice there is no windshield washer fluid tank on this side and there are already threaded holes for you to simply bolt a compressor for the air horn to. However you may also notice that you will have no room if you have a Cold Air Intake Installed.
Both Horns
12.
Here is both horns mounted, High Note On the Passenger side, whilst the low note I have mounted on the right. You'll notice that I had to wire the second horn under and across the radiator.
That's it folks! Have Fun, and by the way...i'm running both horns on without the need of replacing the stock fuse.
Forum Bot is offline   Reply With Quote
Sponsored Links
Tags
2003 , 2004 , 2005 , 96 , aftermarker , aftermarket , air , alarm , civic , honda , horn , install , plug , replace , viper
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Reset Your SRS Light
VAFC II Full Installation Info
VTEC Light (with Pics)
Air/Fuel Gauge Install
Installing a Tach
Push Button Ignition
Reverse Indiglo Gauges
Alarm, Remote Start and Audio Wiring Chart
DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Installing Oil Gauges
Site Supporters
aluminum radiator
Honda car spoilers
