Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Audio
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-13-2005   #1 (permalink)
LayinLo
Senior Member
LayinLo's Avatar
LayinLo is an unknown quantity at this point
Less Glare Head Unit Install (DIY)
There is not a good thread that contains all this info with pics, so I thought I'd save everyone some time and throw in some pics. Much props to Popcornplaya, cuz I followed his DIY really close with a few changes.
The pics are from my 2001 Ex, 5 speed, Coupe
For this install you'll need to get:
Metra parts #99-7865 (double DIN dash kit)
Metra parts # 88-00-9000 (universal pocket)
Tools:
screwdriver (phillips and flat)
5/16 socket (not necessary but helps)
Time:
15 minutes to 1 hour depending on experience
Step 1: Remove the cigarette lighter and fog light switch plate. I just stuck my thumb in and pulled out. Shouldn't be very hard.
Now unclip the wiring harnesses.
Step 2: Remove the two (2) screws holding the AC controls and Radio in the dash. This is where the 5/16 socket will help you to break the screw loose. After the first time these screws will come off with a screw driver very easily.
Step 3: Removing the AC controls and Radio
You can use a flat head screw driver to gently break the clips loose on your dash. Be careful not to gouge your dash.
Now unhook all the wiring harnesses from the back of the AC controls and Radio.
ID:	55539   Click image for larger version
ID:	55540   Click image for larger version
ID:	55541   Click image for larger version
ID:	55542   Click image for larger version
__________________
"Is this your car?"
"Yeah. Insight. The Cadillac of Hybrids."
"Seems kinda small for a guy your size."
"Small price to pay for the environment. 57 mpg."
"But what about speed?"
"Martin, If your important, people will wait."
--Be Cool--
LayinLo is offline   Reply With Quote
Sponsored Links
Old 06-13-2005   #2 (permalink)
LayinLo
Senior Member
LayinLo's Avatar
Next take your whole AC unit and radio inside. Why work in the heat or cold when you can be comfortable inside, right?
Step 1: Take the knobs off the AC. They just pull right off.
Step 2: Unscrew the back of the AC controls. There are three screws.
Step 3: Mount your aftermarket radio in the bottom slot. I took the radio bracket off too. It has four (4) screws around the outside edges.
Most Pioneer, Alpine, and Eclipse mount right up to the side ISO holes. Screw it in tight.
ID:	55544   Click image for larger version
ID:	55545   Click image for larger version
ID:	55546   Click image for larger version
__________________
"Is this your car?"
--Be Cool--
Old 06-13-2005   #3 (permalink)
LayinLo
Senior Member
LayinLo's Avatar
Next we are going to mount the pocket. This is the Metra 88-00-9000 universal pocket. It comes with directions for Toyota, Nissan, Volvo, etc. but no Honda directions. I used the Toyota mounting brackets.
Step 1: Screw the bracket into the side of the pocket with the supplied screws.
Step 2: Now mount the pocket to the stock metal bracket (with supplied screws) where the radio used to be.
The pocket will only have 1 screw slot that fits. So, I took and screwed in the extra screws to give the pocket some stability. Now the pocket rests on the screw I just screwed in the side.
Step 3: Mount the stock bracket back up the the AC control and Radio panel from the dash. Wiggle it a little to get it back to the stock holes if the fitment is tight.
Step 4: Put it all back together in reverse order.
Remount your AC control with the three (3) screws you took off.
Put your knobs back on.
Go back outside and plug all the AC harnesses up and the radio harness.
Slide it all back into the dash.
Screw in the two (2) screws at the bottom of the AC/radio bracket.
Plug up the fog light and cigarette lighter plug.
Push the plate back on.
Go inside and show your mom/GF/friends how handy you are!!!
Now go enjoy a cold !!!!!
ID:	55548   Click image for larger version
ID:	55549   Click image for larger version
ID:	55550   Click image for larger version
__________________
"Is this your car?"
--Be Cool--
Old 06-13-2005   #4 (permalink)
PunkingCivic
I need TP for my bunghole
PunkingCivic's Avatar
PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of PunkingCivic has much to be proud of
Send a message via AIM to PunkingCivic
set this to derek and have him add it to the diy section
PunkingCivic is offline   Reply With Quote
Old 06-13-2005   #5 (permalink)
LayinLo
Senior Member
LayinLo's Avatar
And the final product:
__________________
"Is this your car?"
--Be Cool--
Old 06-13-2005   #6 (permalink)
bluestreak
Diamond Member
bluestreak's Avatar
bluestreak is an unknown quantity at this point
nice job, great DIY
__________________
modding any 7th gen to be fast is dumb in my opinion,
modding a 7th gen automatic to be fast is worst
they're econoboxes and are all about getting MPG
That's like buying a mustang and modding it to get better MPG?
bluestreak is offline   Reply With Quote
Old 06-13-2005   #7 (permalink)
PennyKnotOff
Post Master General
PennyKnotOff's Avatar
PennyKnotOff is just really nice PennyKnotOff is just really nice PennyKnotOff is just really nice PennyKnotOff is just really nice PennyKnotOff is just really nice
Send a message via AIM to PennyKnotOff Send a message via Yahoo to PennyKnotOff
Definitely gotta give this a try. Good job
__________________
7thGen.MT.C.
Parts forsale: Axle back exhaust, skunk2 shift knob, K&N SRI, HID kit, 04-05 tails, Lip kit...
http://www.civicforums.com/forums/68...uff-added.html
PennyKnotOff is offline   Reply With Quote
Old 06-13-2005   #8 (permalink)
PunkingCivic
I cannot find the part #: Metra parts #99-7865 (double DIN dash kit)
http://www.metraonline.com
Old 06-13-2005   #9 (permalink)
S2KREY
formerly 2k1CivicRacer
S2KREY's Avatar
S2KREY is on a distinguished road
Send a message via AIM to S2KREY
good diy... ill prolly try this later on in the week
S2KREY is offline   Reply With Quote
Old 06-13-2005   #10 (permalink)
AggressiveAdam
Platinum Member
AggressiveAdam's Avatar
AggressiveAdam is on a distinguished road
I did this to my car, it does reduce the glare signifigantly and also makes the deck easier to reach.
Excellent mod.
Also if you have a pop out screen its farther away from the heating vents so thats a major +
AggressiveAdam is offline   Reply With Quote
Old 06-13-2005   #11 (permalink)
TuRtLE714
Ultimate Member
TuRtLE714's Avatar
TuRtLE714 will become famous soon enough TuRtLE714 will become famous soon enough
Send a message via AIM to TuRtLE714
nioce! gonna do this when i get some free time
__________________
- TuRtLe
"Bukkake!"
TuRtLE714 is offline   Reply With Quote
Old 06-13-2005   #12 (permalink)
PunkingCivic
where do you get the kit.
Links please!
Old 06-13-2005   #13 (permalink)
LayinLo
Senior Member
LayinLo's Avatar
Auto Toys
Try the link above.
__________________
"Is this your car?"
--Be Cool--
Old 06-13-2005   #14 (permalink)
thomusvoo
Newbie Member
thomusvoo's Avatar
thomusvoo is on a distinguished road
nice nice
very useful
+1 rep for you
thomusvoo is offline   Reply With Quote
Old 06-13-2005   #15 (permalink)
LayinLo
Senior Member
LayinLo's Avatar
'preciate it thomus!
__________________
"Is this your car?"
--Be Cool--
Tags
06 , 2002 , 7th , 97 , civic , diy , gen , head , headunit , honda , install , installation , kit , si , unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Stock headunit and Ipod Hookup Question Fern I.C.E. & Electrical 19 04-16-2007 03:36 AM
installing front components Unleaded I.C.E. & Electrical 8 09-19-2005 11:21 PM
Honda Civic Stereo Install Kit DIY tabo Honda Civic DIYs and Civic Tech Chat 9 02-23-2003 08:14 PM
Installing HU?????? ZSKCivic01 I.C.E. & Electrical 5 11-17-2002 12:13 AM
display problems pimpcivic I.C.E. & Electrical 4 09-12-2002 12:39 AM
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install (version 2)
Removing Door Panel and Adding New Speakers
Removing the factory headunit in a 7th Gen Honda Civic
Building a Custom Sub Trunk for your 7th Gen Civic
Installing Rear Speakers in a Sedan
Amp Wiring: 2k1 Civic Coupe
DIY: Custom Trunk II !with access to spare tire! thanks to diskreet
Site Supporters
aluminum radiator
Honda car spoilers
