Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Audio
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-05-2004   #1 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
DIY: Head unit install (version 2)
As this was long overdue, I decided to make a head unit install DIY for the 03-04 Civic. This may apply to other years as well, but AFAIK, it is only for the 03-04. This DIY was created using an 04 LX coupe.
1) Stick your hand under the trim ring and pull
2) The ring comes off easily
3) Stick your finger in the location shown and pull up HARD. It can be very stiff but it does come out. There is a hole there to stick your finger in and make it easier.
4) The console piece does come off but it can be a pain in the ass sometimes. If it seems stuck in one part, look very closely to where the clip is (the console piece will be cut out a little just above it), stick a very small screwdriver and try to push the clip out. It will come out eventually so be persistent.
5) Use a phillips head screwdriver to remove the 2 screws located near the cup holders on either side of the console
6) Stick your hand under the "horseshoe shaped piece" as shown and pull it out. It is simply held in by clips, 2 on each side. Pull the sides out first and then pull the entire piece out by pulling up and back. Unplug the cigarette lighter and set this piece aside.
7) This is what your dash should now look like, and you can start taking the head unit out.
8) Remove these 2 screws to allow you to take the panel containing your HVAC controls, hazard light and head unit to come out. You can use either a very short phillips head screwdriver or an 8mm socket and ratchet. I highly recommend the ratchet. One screw is in the center and one is towards the right, but they are up underneath the dash and you may have to get under there at a wierd angle to see them, but they are very easy to get out using a ratchet.
9) Stick your hand behind the metal bar that you just took the screws out of and push it kind of up and forward. The top of this bar is part of the panel containing the head unit and the bottom half is part of the car. Push on the bar so that the head unit pops out. It may be stiff if it hasn't been removed before but it does come out.
That's all there is to it, and reassembly is the exact opposite of disassembly.
If you get stuck, of course feel free to post in the topic.
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Sponsored Links
Old 10-10-2004   #2 (permalink)
lkm
Super Member
lkm lkm lkm lkm lkm lkm lkm lkm lkm lkm lkm
this one rocks
lkm is offline   Reply With Quote
Old 10-12-2004   #3 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
2slow2run is an unknown quantity at this point
god daym its so much harder on the sedan then the coupe
thank goodnesss i got a coupe but thankx for the update on the sedan
2slow2run is offline   Reply With Quote
Old 10-12-2004   #4 (permalink)
MegaHurtz
MegaHurtz's Avatar
Actually this was done with a coupe
__________________
Old 10-13-2004   #5 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
o auto
Old 10-23-2004   #6 (permalink)
JP375
Super Member
JP375's Avatar
JP375 is an unknown quantity at this point
Does everything lock in place nice when you reassemble it? I hate to take it all apart only to find that it is loose and ill fitting once it is put back together. Do the clips you mention have to be replaced once the part is removed? I ran into this on my old car once. The door panel clips were meant to be replaced once they were undone.
JP375 is offline   Reply With Quote
Old 10-24-2004   #7 (permalink)
MegaHurtz
MegaHurtz's Avatar
Yeah it all locks in
And no they don't have to be replaced. Sometimes they pop off and you cant find them, but if you have MOST of the clips, 1 or 2 don't matter. I stole a few odd clips from around my car when I needed them, but I eventually went to Honda and bought a whole bunch of em
__________________
Old 10-26-2004   #8 (permalink)
85gp4
Senior Member
85gp4's Avatar
85gp4 is an unknown quantity at this point
I just replaced my stock head unit this past weekend and it wasn't as hard as the pictures look. Hell, I did mine BEFORE I found this post. Very good post by the way... Everything just snaps back together.
85gp4 is offline   Reply With Quote
Old 10-26-2004   #9 (permalink)
MegaHurtz
MegaHurtz's Avatar
It's not hard at all, just requires some dynamic thinking I suppose you could say
__________________
Old 10-27-2004   #10 (permalink)
Adamb123
Member
Adamb123 is an unknown quantity at this point
Hi, when you do an install for an HU how do you know which wires go to which part of your Deck?
If I have an alarm/keyless entry do I need to go out and buy an extra part for it?
Adamb123 is offline   Reply With Quote
Old 10-28-2004   #11 (permalink)
MegaHurtz
MegaHurtz's Avatar
You get an aftermarket wiring harness and wire it to your deck wiring harness based on the colors and then you just plug it in. Simple.
No, alarm or keyless do not require any extra parts
__________________
Old 10-29-2004   #12 (permalink)
coop
coop's Avatar
coop is a jewel in the rough coop is a jewel in the rough coop is a jewel in the rough
Must be a redesign - the 01 coupe didn't require any of the center console to come out....good job btw!
coop is offline   Reply With Quote
Old 10-31-2004   #13 (permalink)
MegaHurtz
MegaHurtz's Avatar
It is a little different than the 01 yes that is why I made the new DIY... and thanks
__________________
Old 10-31-2004   #14 (permalink)
JP375
Super Member
JP375's Avatar
This helps me quite a bit. Have installed rear speakers? Or doors, with the tweeter pods?
Old 10-31-2004   #15 (permalink)
MegaHurtz
MegaHurtz's Avatar
Done both, I just followed the DIY's that are on this site
__________________
Tags
2000 , 2003 , 2004 , 7897 , civic , diy , doesnt , fit , head , install , metra , unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Removing Door Panel and Adding New Speakers
Removing the factory headunit in a 7th Gen Honda Civic
Building a Custom Sub Trunk for your 7th Gen Civic
Less Glare Head Unit Install (DIY)
Installing Rear Speakers in a Sedan
Amp Wiring: 2k1 Civic Coupe
DIY: Custom Trunk II !with access to spare tire! thanks to diskreet
Site Supporters
aluminum radiator
Honda car spoilers
