Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Audio
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-13-2005   #46 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
O.K. the Metra 70-1721 is the correct harness.
I was able to change the headunit (that insert was tight !!)
I can quickly and easily see that will need a mounting kit to take care of some issues with gaps and poor positioning.
Anyone have any suggestions on a good quality kits that they have used that would be compatible with an 05 sedan ??
I looked at the post your HU thread and they all looked great.
CraigW is offline   Reply With Quote
Sponsored Links
Old 03-13-2005   #47 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
metra 99-7897 keeps the stock pocket below
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Old 03-13-2005   #48 (permalink)
Civic_RedLine
im stock now! T.T
Civic_RedLine's Avatar
Civic_RedLine will become famous soon enough
so if you use the metra that lets you keept the oem pocket, do you still need to use that metal peice in the back of the stock unit that holds the oem cd player and pocket?
Civic_RedLine is offline   Reply With Quote
Old 03-14-2005   #49 (permalink)
MegaHurtz
MegaHurtz's Avatar
yes becuase the aftermarket cd player will screw into it the same way the stock did
__________________
Old 03-14-2005   #50 (permalink)
zachgeyer
zachgeyer's Avatar
zachgeyer has a spectacular aura about zachgeyer has a spectacular aura about
Send a message via AIM to zachgeyer
thats nutz still
zachgeyer is offline   Reply With Quote
Old 03-14-2005   #51 (permalink)
Kedaeus_Sendre
New Member
Kedaeus_Sendre is an unknown quantity at this point
A bit of advice for those of us with '04 Civics (5speed)
Do NOT remove the silver trim around your shift knob.. It's un-necessary and you will probably break it as it's attached at the bottom edge (towards the e-brake) with a screw or someshit from underneath the console.. either way it doesn't have to come out and you WILL break it (like i did).
I found it alot easier to remove the entire center console for my job.. I couldn't find enough space for my body underneath the dash, and at the time I was using screwdrivers (USE A SOCKET!!! IMO It's not optional for a first time job) and didn't have the propper clearance to unscrew..
Attempting to unscrew the two screws that hold everything in place (last pic) is a bitch.. and both screws ended up being stripped before I did the smart thing and went back home to grab my socket set. Use an 8mm socket.. The screws are much to tight for a screw driver.
If you want to remove your center console start at the back and move forward..
There are two screws below your arm rest, about 2 inches off the floor (remove)
Open you'r armrest - remove the two screws holding the hinge in place
Get a butter knife and pull up the rubber matt in the bottom of your armrest box.. (It's just sitting in there, no glue or anything) unscrew the screw in the floor of the box.
Now start at the beginning of this (thread) DIY.. it *MIGHT* make your job a bit easier if you are abnormally large or extremely impatient.. or if you just like to take shit apart.
Kedaeus_Sendre is offline   Reply With Quote
Old 03-20-2005   #52 (permalink)
Supermanrider
I dont know what im talking about
Supermanrider's Avatar
Supermanrider is an unknown quantity at this point
thats a good DIY good job
Supermanrider is offline   Reply With Quote
Old 03-29-2005   #53 (permalink)
ihjoon
New Member
ihjoon is an unknown quantity at this point
Send a message via AIM to ihjoon
THANK YOU, i've been lookin for SO long how to do a freaken manual... i broke off my 4.5 volt thing cuz i read the DIY for the 01-03 civic thing. so gay. then i tried some other things, got lost, but thans so much, it finally makes sense!!
ihjoon is offline   Reply With Quote
Old 03-30-2005   #54 (permalink)
gatorsactions
Member
gatorsactions's Avatar
gatorsactions is an unknown quantity at this point
I have an 04 civic coupe with manual trans. Can I remove the ring around the shift boot in the same manner? (i.e., just pop it off)
__________________
CLICK HERE to get your FREE SONY PSP. The process is really simple. Just follow the steps on the site.
gatorsactions is offline   Reply With Quote
Old 03-30-2005   #55 (permalink)
OyD
Diamond Member
OyD's Avatar
OyD is an unknown quantity at this point
You don't need to removet he ring on a manual. I just removed the piece with the ring attached.
OyD is offline   Reply With Quote
Old 04-03-2005   #56 (permalink)
ihjoon
New Member
someone show more detail. PLEASE
Old 04-04-2005   #57 (permalink)
thomusvoo
Newbie Member
thomusvoo's Avatar
thomusvoo is on a distinguished road
what problem are you having?
i can help...
i followed that.
its basiclly good as is.
__________________
SAVE $20 from crutchfield.com on items worth $200 dollars or more
put this code in the "referal code" that is located in the payment page of the checkout form
p43wq-3bbv5-zs800
thomusvoo is offline   Reply With Quote
Old 04-04-2005   #58 (permalink)
MegaHurtz
MegaHurtz's Avatar
how much more detail could you possibly need? I made a 9 step process out of what it really a 4 step process
__________________
Old 04-04-2005   #59 (permalink)
ihjoon
New Member
im a noob, first time..
Old 04-05-2005   #60 (permalink)
04silverlx
New Member
04silverlx's Avatar
04silverlx is an unknown quantity at this point
Thank You for posting this, I got the wiring harness and the faceplate kit and didn't have the instructions on installing, I was going to try to go off the old models instructions and wing what was necessary, but thanks to MegaHurtz I have proper instructions. YAY! My only worry now is connecting the wires but I should be alright if the colors match. (as long as the plug fits the back of my hu)
Hey, can anyone tell this is my first time installing by my self?
Thanks everybody, and coop - the cure is awesome!!!!
04silverlx is offline   Reply With Quote
Tags
2000 , 2003 , 2004 , 7897 , civic , diy , doesnt , fit , head , install , metra , unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install (version 2)
Removing Door Panel and Adding New Speakers
Removing the factory headunit in a 7th Gen Honda Civic
Building a Custom Sub Trunk for your 7th Gen Civic
Less Glare Head Unit Install (DIY)
Installing Rear Speakers in a Sedan
Amp Wiring: 2k1 Civic Coupe
DIY: Custom Trunk II !with access to spare tire! thanks to diskreet
Site Supporters
aluminum radiator
Honda car spoilers
