Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Audio
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-31-2004   #16 (permalink)
JP375
Super Member
JP375's Avatar
JP375 is an unknown quantity at this point
I can't seem to find the DIY for the rear deck of a coupe (found the sedan), could you help a noob out and point me in the right direction? To remove this ad, register today for free or log in if already registered!
JP375 is offline   Reply With Quote
Sponsored Links
Old 10-31-2004   #17 (permalink)
JP375
Super Member
JP375's Avatar
One more thing...what will I need to make a clean install for a Nakamichi CD-400 head unit. Is it just a trim ring that covers the space around the unit? Crutchfield shows the whole bezel with the storage pocket and everything.
http://www.crutchfield.com/S-Jz76wq7...=mounting+kits
I don't want to replace that. I want to keep the stock one with the door over the storage pocket. Does the unit fit with the factory bezel?
Old 11-02-2004   #18 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
Get the Metra #99-7897 mounting kit, it is only half sized
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Old 11-08-2004   #19 (permalink)
Blahman2
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trusted Blahman2 should not be trusted Blahman2 should not be trusted Blahman2 should not be trusted
my 04 doesn't require the center console to be removed.
Blahman2 is offline   Reply With Quote
Old 11-08-2004   #20 (permalink)
MegaHurtz
MegaHurtz's Avatar
pics? what model is yours?
__________________
Old 11-08-2004   #21 (permalink)
Blahman2
EX and I don't have pics. All you need to do is pop the part that has the outlet off and then take the screws out. From your pics looks like you could have done the same. But oh well.
Old 11-09-2004   #22 (permalink)
MegaHurtz
MegaHurtz's Avatar
the part that has the outlet is the big long piece that stretches down the center console, so in actuality i DID do the same... you must have a different setup or something... different parts
__________________
Old 11-09-2004   #23 (permalink)
Blahman2
you have a coupe right?
Old 11-10-2004   #24 (permalink)
MegaHurtz
MegaHurtz's Avatar
affirmative
__________________
Old 11-10-2004   #25 (permalink)
Blahman2
hmm, I don't know why you removed the center console then...
Old 11-11-2004   #26 (permalink)
MegaHurtz
MegaHurtz's Avatar
becuase i had to, like I said, let's see pics of yours
__________________
Old 11-11-2004   #27 (permalink)
MegaHurtz
MegaHurtz's Avatar
i didnt take the center console out, as you can see from the pictures, I only removed 3 pieces that are part of the center console. there is no other way to install the deck other than removing those 3 parts
__________________
Old 11-11-2004   #28 (permalink)
Blahman2
i don't have pics, but maybe I will take it all apart just for you.
Old 11-11-2004   #29 (permalink)
MegaHurtz
MegaHurtz's Avatar
I'd like to see it
__________________
Old 11-11-2004   #30 (permalink)
takumi
Diamond Member
takumi is on a distinguished road
Send a message via AIM to takumi
Me too...
takumi is offline   Reply With Quote
Tags
2000 , 2003 , 2004 , 7897 , civic , diy , doesnt , fit , head , install , metra , unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install (version 2)
Removing Door Panel and Adding New Speakers
Removing the factory headunit in a 7th Gen Honda Civic
Building a Custom Sub Trunk for your 7th Gen Civic
Less Glare Head Unit Install (DIY)
Installing Rear Speakers in a Sedan
Amp Wiring: 2k1 Civic Coupe
DIY: Custom Trunk II !with access to spare tire! thanks to diskreet
Site Supporters
aluminum radiator
Honda car spoilers
