Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Audio
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-07-2004   #1 (permalink)
Forum Bot
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
Removing the factory headunit in a 7th Gen Honda Civic
First thing you need to do is remove the piece of the dash that has the lighter plug and pocket. It is held in using only clips. A good way to remove it us to insert your fingers of your right hand into the pocket palm up and stick your thumb in the lighter plug. Grip and it should pull straight out, it takes a bit of force.
Get down low and you will see two screws towards the right side of the opening. Remove these so you can pull out the part of the dash that houses the radio and AC controls.
To remove this part of the dash, it is best to reach up inside the dash and find something to push this part out enough that you can get your fingers under it. It takes some force to push this out; it is connected with 5 clips. Once it is out, remove all the plugs, and remove the 3 screws that hold the climate controls in. Now you can remove the stock head unit and install your new one.
Forum Bot is offline   Reply With Quote
Sponsored Links
Tags
2001 , 2002 , 2006 , 7th , civic , custom , diy , gen , head , headunit , honda , lx , radio , remove , unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install (version 2)
Removing Door Panel and Adding New Speakers
Building a Custom Sub Trunk for your 7th Gen Civic
Less Glare Head Unit Install (DIY)
Installing Rear Speakers in a Sedan
Amp Wiring: 2k1 Civic Coupe
DIY: Custom Trunk II !with access to spare tire! thanks to diskreet
Site Supporters
aluminum radiator
Honda car spoilers
