Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles
7th Gen Honda Civic Do It Yourself Articles Look here for anything and everything you want to do yourself for your Civic and save money!
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-02-2008   #1 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
CLASSIC DIY: vtec light
I did not make this up, nor am I the first one to try it, I am simply the first one to type it up and take pictures. 'cwick187' already has one installed.
There are probably circuits for wiring this all over the net, I took the one that was posted a few days ago, changed it a little bit and wired it in.
This is so easy, if you can't do it, I'll personally come over to your house and beat you.
You need:
Wire
Tap Splices
1 5mm LED (pick a color)
A resistor (330, 470, 680, 1K OHM, you pick)
1 5mm LED Snap-in Holder
Radio Shack makes it one stop shopping, you can get out for less than $10.
Here goes... RTFM and find the page that tells you how to remove the glove box to get access to the cabin microfilters. Take everything out of the glove box and do it.
Then you will see a shiny silver box with a lot of wires going to it... that's the ECU. On the middle plug (it's white) you should see a green wire with a yellow stripe in the top center pin. That's the VTEC wire. You need to put a tap splice on it.... trace it back a few inches (there is only 1 green/yellow stripe wire) and put the tap in place. The other wire you need to find is a suitable ground. I used the ground I ran from the engine block for my other gauges, but any ground will work (the Cig lighter is convient).
Figure out where you want the LED to be. I wouldn't put it somewhere high in the car, it'll be on more than you think. Put it somewhere you can see out of the corner of your eye. I mounted mine with the rest of my gauges in the lower center console. Drill a 1/4" hole and put the LED holder in (no need to glue)... be careful where you pick, you need to be able to get to it from behind.
Time to set the LED up. You need to put the resistor in series with the ground lead of the LED (for those who don't speak electronics, you need to hook up one resistor lead to the shorter lead on the LED and the other end to the wire you grounded). I used heat shrink tubing, but soldering also works. I wouldn't use electrical tape. Wire the other lead from the LED to the wire you tapped into the ECU with. Boom.... done. You'll be surprised where VTEC really does engage.
Notes:
1: There are choices for resistors... you only need one, the higher the number, the dimmer the light. I used a 680 OHM and it's still visible in daylight.
2: This does not void your warranty. You are not doing anything to the ECU but monitoring a signal. It's the same as having a Honda Tech sit there with a diagnostic probe on the wire all day.
3. If anyone asks or tries to install this on an LX or DX, I will come to your house and personally beat you.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Sponsored Links
Tags
2003 , box , cabin , civic , cover , diy , dx , filter , glove , honda , hook , light , lx , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
CLASSIC DIY: brake pads and rotors install
CLASSIC DIY: Alternator and battery FAQ
CLASSIC DIY: replacing door lock assembly and actuator
CLASSIC DIY: fuel filter replacement
CLASSIC DIY: double neon angel eyes
CLASSIC DIY: DX/LX head swap to EX vtec
CLASSIC DIY: Booty call!
CLASSIC DIY: 04 taillight conversion
CLASSIC DIY: 98-01 Accord trunk opener on 7thgen civic
Site Supporters
aluminum radiator
Honda car spoilers
