Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles
7th Gen Honda Civic Do It Yourself Articles Look here for anything and everything you want to do yourself for your Civic and save money!
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-02-2008   #1 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
CLASSIC DIY: ATF fluid change
ORIGINALLY POSTED BY VOICEOFID
first of all, i like to thank JmD_1901 for comming by and helping me on all the work and stuff, you the man!
this is a diy to change the fluid, not overhaul, over haul require flushing the whole system. this change only changes most of the atf, it does nothing to the atf that was inside your torque converter
ATF should be changed every 48000 miles or 48 months, under regular conditions. and it should be changed every 24000 miles, or 24 months in severe conditions (a lot of stop/go traffic, pizza delivery, hot weather conditions etc...)
Materials:
at least 2 clean shop rags. heck, make it 4
3/8 inch drive socket wrench, no sockets needed
3.1 quarts of ATF
something to catch old ATF
jack stands
relieable jack
shop light
1. turn on the car
2. warm it up till the radiator fan comes on
3. shut it off
4. keep the vehicle on a flat surface
5. go under the tranny and locate the bolt (might have to jack it up to see and such..)
remove the tranny drain bolt, it's the only bolt with a gasket and square shape drive, it's hard to see, it's right next to the sub frame, and a 3/8th socket wrench fits right into the square drive
6. remove the bolt, it requires a little bit of muscle
7. catch the atf (it maybe hot) fluid, make sure you have a clean towel around to clean up any mess. and make sure you have something to catch the fluid with
8. while the fluid is draining, look at the bolt you just removed, it has a magnet at the end, clean all that nasty shavings off of it
9. after all fluid has been emptied, put the bolt back in, and clean around the area
10. torque the bolt down to 36lbs
11. refill the transmission with new atf, with 3 quarts at first, and check the level when hot, then add more as necessary
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Sponsored Links
Tags
2001 , 2006 , 7th , 8th , atf , change , check , civic , diy , fliud , fluid , honda , quarts , replace , transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
CLASSIC DIY: brake pads and rotors install
CLASSIC DIY: Alternator and battery FAQ
CLASSIC DIY: replacing door lock assembly and actuator
CLASSIC DIY: fuel filter replacement
CLASSIC DIY: double neon angel eyes
CLASSIC DIY: DX/LX head swap to EX vtec
CLASSIC DIY: Booty call!
CLASSIC DIY: 04 taillight conversion
CLASSIC DIY: vtec light
CLASSIC DIY: 98-01 Accord trunk opener on 7thgen civic
Site Supporters
aluminum radiator
Honda car spoilers
