Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles
7th Gen Honda Civic Do It Yourself Articles Look here for anything and everything you want to do yourself for your Civic and save money!
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-01-2008   #1 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
CLASSIC DIY: double neon angel eyes
ORIGINALLY POSTED BY SKIBOARD
this is way brighter then the LED angel lights I donno how long it will last but dam rite it looks good
so here's a DIY
I used four of this Roung Cold Cathode Fan neon lights by Sunbeamtech all had diameter of 80mm and you can find it in the computer store
since computer parts and our car uses same 12v there wont be any problems with converting voltages this kit includes a fan(not needed), neon, switch(not needed) wires, and inverter
I used four of this neons
first take your bumper off and so as your headlight
take your headlight apart and you will have this part on your hand
screw off the original LED angel light
drill a small holes into red dots
cut off four edges of plastic cover to make it round
put the neon ring on, get the wiring out to the back and hold the ring with wires
now you are done with the lowbeam light now for the high beam light,
drill two holes on highbeam/daylight which will be used to hold the rings
put the neon rings without the plastic cover
put back the headlights,seal it and connect it to the inverter
do the wiring and you are ready to rock
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
gearbox is offline   Reply With Quote
Sponsored Links
Tags
12v , 2001 , 2006 , angel , angle , auto , civic , connect , conversion , diy , eyes , honda , lights , neons , ring , wires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
CLASSIC DIY: brake pads and rotors install
CLASSIC DIY: Alternator and battery FAQ
CLASSIC DIY: fuel filter replacement
CLASSIC DIY: replacing door lock assembly and actuator
CLASSIC DIY: DX/LX head swap to EX vtec
CLASSIC DIY: Booty call!
CLASSIC DIY: 04 taillight conversion
CLASSIC DIY: vtec light
CLASSIC DIY: VafcII complete fix
Site Supporters
aluminum radiator
Honda car spoilers
