Ultimate 7th gen diy index - Honda Civic Forum
Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Generation Civic > 7th Gen Do It Yourself Articles
7th Gen Do It Yourself Articles Look here for anything and everything you want to do yourself for your Civic and save money!
LinkBack Thread Tools Search this Thread
Old 12-22-2011   #1
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner's Avatar
Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all Gunner is a name known to all
PM me photogunner clueless dont have usnsami
Send a message via ICQ to Gunner Send a message via AIM to Gunner Send a message via Yahoo to Gunner Send a message via Skype™ to Gunner
Index of all the DIY articles for 7th gen. Will update as needed.
Audio
Removing Door Panel and Adding New Speakers
DIY: Head unit install
DIY: Head unit install (version 2)
DIY: Custom Trunk II !with access to spare tire! thanks to diskreet
Less Glare Head Unit Install (DIY)
Building a Custom Sub Trunk for your 7th Gen Civic
Installing Rear Speakers in a Sedan
Amp Wiring: 2k1 Civic Coupe
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: No More Trunk Rattle!
DIY: Rear Speaker Install: Coupe, w/o ripping interior apart
DIY: Rear Speaker Install for Coupe
DIY: EP3 component speaker install w/ pics
Full DIY 7" Monitor and Head Unit Relocation
Brakes
DIY: Brake pad replacement (the correct way)
DIY: Parking Brake Adjustment
DIY: Stainless Steel Braided Brake Lines
Rotor and Brake Pad Install
DIY caliper painting
DIY Drum Brake Shoe Replacement
DIY: Brake Pads and Rotor Install *Updated*
DIY: Front brake pad install (7th gen) without clamp!
http://www.civicforums.com/forums/18...?highlight=diy
CLASSIC DIY: brake pads and rotors install
Electrical
DIY. Check for spark / Car won't Start.
VAFC II Full Installation Info
DIY: Radar Detector Hardwire
Carputer D.I.Y.
DIY: 01-03 to 04-05 Gauge Cluster Swap
DIY Alternator High Output Upgrade
DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Installing Oil Gauges
Air/Fuel Gauge Install
Replace Stock With Aftermarket Horn
Video DIY: LED Lx 4dr Dome & Map Light Install
DIY LED Gauge swap
DIY: replacing power window motor assembly on my civic coupe
DIY 04/05 tail light conversion (with factory parts)
DIY cluster swap 2003 - 2004 dx also available for other models
CLASSIC DIY: vtec light
DIY: Wire oem fog lights to ignition
DIY: ground wire upgrade and HVS part II (pics)
DIY Bridge Motorsport Ground Kit + Review
DIY: Converting primary o2 sensor from narrow to wide band for KPRO USE ONLY
2001-2003 Honda Civic ECU Wiring
DIY: Check odometer on disconnected Cluster
CLASSIC DIY: 2001-2003 civic ecu wiring
DIY: How to bypass the clutch for remote start WITHOUT bypassing safety features($10)
DIY: Alternator Replacement
Lighting
DIY: EBAY FOG LIGHTS w/ EBAY BUTTON
DIY Ebay Fog Light Install - 05 EX Sedan
DIY Fog light Installation
DIY: aiming headlights the easy way!
DIY: Disable DRL's
DIY LED Gauge swap
DIY: Cruise Control FIX w/ LED tail/brake lights
DIY: TYC projector retrofit 2010
DIY : Double Neon Angel Lights
DIY: blue glow needles!
DIY Change your ignition switch light color. PROGRESS PICS ADDED!!!
Detailed smoked out taillights DIY w/ pictures
DIY:01-03 Headlight Aim Adjustment 56K WARNING
DIY: Complete 04 taillight conversion!
Diy: Headlight Install
DIY Auto Headlight Turnoff?
DIY: Blue LED gauge and dash lights
DIY: Modifying Mini-Graphite Shrouds for LEDs
Mini DIY- Install Aftermarket LED Taillights (01-05)
DIY - DX/LX head swap to EX Vtec
DIY: forgotten tune-up mods
The ultimate DX/LX header/exhaust DIY and FAQ
DIY: Removing Power Steering
DIY: Oil Change
DIY: Throttle-Body Heater Bypass
CLASSIC DIY: DX/LX head swap to EX vtec
Timing Belt DIY 2
Stage 1 Cams
DIY: Valve Clearance Adjustment
A/c Compressor DIY
CLASSIC DIY: fuel filter replacement
DIY Mechanical O2 simulator
Power Steering Pump Rebuild DIY
DIY polyurethane motor mounts
DIY: Spark Plug Change VIDEO
DIY: SRS Codes and reading them
DIY: Crank pulley bolt tool......$6 bucks
DIY Weapon-R Secret Fixing loose temp sensor...
DIY: HOOD struts & Aluminum Spark Plug Cover
DIY - Valve spring/retainer/valve removal - VIDEO
CLASSIC DIY: VafcII complete fix
DIY: Timing Belt Replacement
Found a DIY for the d16y8 Intake Manifold swap
DIY: Ingalls "Stiffy" Engine Damper & Review
DIY: EM2 - D17 to K20 wiring swap and general info
SRS Light and Paperclip DIY
DIY - DC Sports 4-1 header install w/ pics
Page two being made right now...
__________________
Nobody is hurt. Hurt is in the mind. If you can walk, you can run.
- Vince Lombardi
Last edited by GolNat; 04-20-2015 at 04:53 PM. Reason: Updated: 4/20/15 added stuff
Gunner is offline   Reply With Quote
Old 12-22-2011   #2
Gunner's Avatar
Lightbulb Re: Ultimate 7th gen diy index
Transmission
DIY Auto-to-Manual Transmission Swap
DIY: Clutch pedal adjustment
DIY: ATF Change
DIY: Auto transmission cooler (pics added)
DIY clutch install
DIY: Manual Transmission Flush/Replacement
Em2 Civic AXLE Removal DIY 1st one made
DIY: Change your Transmission Oil
7th gen DIY ATF change>
CLASSIC DIY: ATF fluid change
Interior
http://www.civicforums.com/forums/11...tallation.html
Video DIY: Sedan Front Door Panel Removal
http://www.civicforums.com/forums/11...?highlight=diy
DIY: Change the color of your door panels with suede!!
DIY: Replacing door lock Assembly and Actuator (UPDATED WITH PICS ON POST 27)
DIY LED Gauge swap
Diy: How to mold a screen (or anything for that matter)
DIY: Cleaning Automotive Floor Mats (Video)
DIY: REAR EP3 Seats in EM2
DIY: Aluminum Door Sills
DIY: 2003 Center Console Removal
DIY: sedan door panel removal
DIY Dash Removal: 01 Civic
DIY: Replace your lock actuator
DIY: Trunk Shocks
DIY: Custom Pedals
Suspension
Do It Yourself Spring Install - Detailed Info & Pics
Need DIY for Boring out Camber holes on struts
Front Upper Strut bolt question (for all diy'ers)
DIY Alignment
DIY: Energy Suspension Sway Bar Bushings
DIY: New hardware for Spoon Sports strut bars.
http://www.civicforums.com/forums/44...?highlight=diy
DIY: repair Lower Control Arm broken bushings
Koni Struts Installation
http://www.civicforums.com/forums/11...-sway-bar.html
Exterior
CLASSIC DIY: car washing and waxing info
DIY: Painting Your M3 Mirrors
Diy: Fuel Door Fix
DIY: Modifying a OEM bumper to look aftermerket.
DIY: Painting door guards/door strips /w pics
DIY: M3 Mirror install
DIY: Polyurethane Preping and Painting (Body kits etc.)[/QUOTE]
If i missed any important ones let me know..I will also try to keep this database updated. Thanks..
__________________
- Vince Lombardi
Last edited by GolNat; 04-20-2015 at 04:54 PM. Reason: Updated 4/20/15 Added stuff
Old 12-22-2011   #3
Live for the Twisties
MindBomber's Avatar
MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of
+ a lot of rep.
MindBomber is offline   Reply With Quote
Old 12-22-2011   #4
Super Moderator
sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold
sandro daidoji
Send a message via ICQ to sdaidoji Send a message via Yahoo to sdaidoji
sticky!
the one in the 8th gen too
reps were already given yesterday
__________________
02 Coupe EX
suspension basics, Engine codes - To read, not to ask, Honda swap 101, VTEC head swap, Chassis code?, EX header?, cam?
Quote:
Originally Posted by Poopies View Post
I get the broke thing, but what does being female have to do with anything? We'd help you out if you were a lawn gnome as long as you asked us nicely!
sdaidoji is offline   Reply With Quote
Old 12-22-2011   #5
Speed9117 will become famous soon enough
Awesome list!
I have one more to tack on to the suspension list though. It served me well.
Speed9117 is offline   Reply With Quote
Old 12-27-2011   #6
Gunner's Avatar
Updated..
__________________
- Vince Lombardi
Old 01-04-2012   #7
Gunner's Avatar
Can this get a Sticky?
__________________
- Vince Lombardi
Old 01-21-2012   #8
Whachya lookin at?
BlueEM2's Avatar
BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute
Dont think so WTF is twitter? Pardon? Im so confused... what box? ...
Mine isnt in there!
Ball Joint DIY V.2 - No air hammer necessary
__________________
2007 Ford Edge -- Stock!
2005 Honda Civic EX Coupe, almost stock!
Lower Ball Joint DIY
How to set up TDC during timing belt install
Overheating? Here is why.
Head gasket + timing belt DIY! Incomplete but useful!
With how old this forum is, if everyone searched... Nobody would post any more
BlueEM2 is offline   Reply With Quote
Old 01-21-2012   #9
Kenny the Ricer
Kennykid2002's Avatar
Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute
mrpedo.bear Kennykid2002
Send a message via AIM to Kennykid2002 Send a message via MSN to Kennykid2002 Send a message via Skype™ to Kennykid2002
Dam, Great compilation
+1
__________________
Kennykid2002 is offline   Reply With Quote
Old 03-26-2013   #10
pleasure spiked with pain
GolNat's Avatar
GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all GolNat is a name known to all
Two more for 7 gen:
Kenny's
TFMEX's
GolNat is offline   Reply With Quote
Old 03-27-2013   #11
Gunner's Avatar
^ For some reason I can no longer edit my original post, but thank you for adding more stuff
__________________
- Vince Lombardi
Old 03-27-2013   #12
Kenny the Ricer
It's because the thread's been there too long.
I've added it to the first and second posts.
__________________
Old 03-28-2013   #13
Gunner's Avatar
Thanks boss
__________________
- Vince Lombardi
Old 03-28-2013   #14
Aetoc's Avatar
Aetoc will become famous soon enough Aetoc will become famous soon enough
@automotomods
Didn't see a cam sensor DIY, so here's mine:
DIY TCD Sensor Replacement
__________________
Quote:
Originally Posted by Xiao View Post
"VEGETA, WHAT IS HIS RPM AT?!"
"ITS OVER 9000!!!"
Aetoc is offline   Reply With Quote
Old 04-26-2013   #15
Gunner's Avatar
^^ can you add this for me...
and
CAMO yes there is one (read original post)
__________________
- Vince Lombardi
Old 04-18-2015   #16
GolNat's Avatar
Poopies DIY's need to get added.
__________________
My 01 ES1 Pics
HKS Hi-Power Muffler Sound
**SPC Rear Camber Kit For Sale**
We often miss opportunity because it's dressed in overalls and looks like work”
― Thomas A. Edison
Old 04-19-2015   #17
Modtarded!
Poopies's Avatar
Poopies is a glorious beacon of light Poopies is a glorious beacon of light Poopies is a glorious beacon of light Poopies is a glorious beacon of light Poopies is a glorious beacon of light Poopies is a glorious beacon of light
N/A Poopies--
__________________
2003 Civic EX: 5 speed, 2 door... Ready for takeoff.
Install TRS Halos into your Mini Graphite Shrouds
Quote:
Originally Posted by BlueEM2 View Post
I started it. In the process I farted inside there. So in a week when I go to start it again the fart will probably still be there, waiting to attack. Silently.
Poopies is offline   Reply With Quote
Old 04-19-2015   #18
Administrative Rice. WAT?!
Images: 39
xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of xRiCeBoYx has much to be proud of
joshua.cadavona My Twitter Username Not pro enough for Linkedin Too po' for this isht xRiCeBoYx
Send a message via AIM to xRiCeBoYx
You know you guys can edit the top post yourself, right?
__________________
Quote:
Originally Posted by xRiCeBoYx View Post
You gay Kenny.. so gay.. This coming from a dude that was in the Navy.. hahahahaha..
It will forever be Kenny' fault. He's like the grim reaper to Civics.
xRiCeBoYx is offline   Reply With Quote
Old 04-20-2015   #19
GolNat's Avatar
I couldn't then but now I can.
It was updated.
__________________
My 01 ES1 Pics
― Thomas A. Edison
Old 04-21-2015   #20
Images: 39
__________________
Old 06-15-2015   #21
alex_nyc is an unknown quantity at this point
you have the wrong DIY SRS Reset
this is the correct one?
Reset Your SRS Light
alex_nyc is offline   Reply With Quote
Old 02-23-2016   #22
CLudEx
CLudEx is an unknown quantity at this point
Don't use it Won't get it Don't need it NA NA Not interested
Thank you!!! This is one of the pages i have been looking for!!!! RESPECT the Thread!!! Thanks again
CLudEx is offline   Reply With Quote
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Cold Start Issuses Nalmonte 7th Generation Civic 12 09-28-2015 01:10 PM
Black&Carbon Fiber Colgan Mirror Bra carid Parts and Products 0 09-28-2015 10:13 AM
2007 Honda Civic Ex Coupe 2nd Gear Grinds Michael Durkin Mechanical Problems/Vehicle Issues and Fix-it Forum 3 09-24-2015 12:35 PM
New unopened NSK Timing Idler for 1.7L Donahue Parts for Sale 0 09-08-2015 10:43 AM
Tags
2008 , 7th , change , civic , coupe , dash , door , dx , em2 , engine , gen , install , light , number , part , rattle , speaker , swap , transmission , ultimatesixthgendiyindex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
vBulletin Skin by ForumTemplates.com
