Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing > Auto X/Road Racing
Auto X/Road Racing Auto X and Road Course Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-14-2005   #1 (permalink)
PoorCollegeBoy
Stolen digital camera = no ninja picture for me
PoorCollegeBoy's Avatar
PoorCollegeBoy is a jewel in the rough PoorCollegeBoy is a jewel in the rough PoorCollegeBoy is a jewel in the rough
Send a message via AIM to PoorCollegeBoy
oil temp gauge?
Do any of you guys run oil temp gauges, or any system monitoring gauges for autox or road racing? I was just curious as to whether or not monitoring your temp is important, or if this is more of just a "ricer" mod to look cool. To remove this ad, register today for free or log in if already registered!
PoorCollegeBoy is offline   Reply With Quote
Sponsored Links
Old 07-15-2005   #2 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
YES IT IS
Track day= buy an oil cooler.
If you need one, PM me, I can tell you how to build an oil cooler any way you want... from baller to ghetto fabulous and still make it work well.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 07-15-2005   #3 (permalink)
PoorCollegeBoy
ha ha ha, thank you for the resounding yes... i would definitely be interested in an oil cooler, but I have to get a few more autoxs under my belt before they allow me to do real road racing
Old 07-15-2005   #4 (permalink)
Boilermaker1
Jap-Euro Fusion
Do you need a gauge? Not really. Its honestly a pain in the ass to install, it has to go in the oil pan somewhere.... mine is in the drain bolt, but I had to do it in a machine shop.
Just take my word for it... if you're just autocrossing, you might hit 215 on a hot day, which is perfectly fine. You don't run flat out for long enough to create oil heat to a damaging level. Street driving, unless its really hot, I'd be surprised to see it go north of 200. Its when you start running flat out for an extended period of time that you start seeing the temp climb. In 7 or 8 minutes when it was in the high 60s outside, I hit the number you see on the gauge. Typically trackdays run 15-20 minute sessions. That number actually got up more like 271 later in the day. I put the cooler in and went back a month later, and ran for a good 1/2 hour straight trying to test it out, held steady at 215. Anything over 230 is where you want to start worrying. It starts getting up where I had it, if you're not running synthetic, start shitting bricks, if it is synthetic, change it ASAP, but you might be able to make it to about 300 before problems pop up. Any way you shake it, the higher your oil goes, its taking your water with it.... and you may end up with water overheat problems.
Thats probably more than you wanted to know, but there it is.
__________________
2002 Civic
Old 07-15-2005   #5 (permalink)
PoorCollegeBoy
There is never more than I want to know, thank you very much
Old 12-09-2005   #6 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
so, is there an adapter that will just replace the drain bolt?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 12-11-2005   #7 (permalink)
Boilermaker1
Jap-Euro Fusion
There may be.... I DIYed it.
If you can find an M12x1.5 bolt thats drilled for a sensor, thats all you need, although I'd drill the Honda bolt so you can be sure it seals up.
__________________
2002 Civic
Old 12-11-2005   #8 (permalink)
gearbox
Super Moderator
i found one on ebay that says its a drain plug with sensor. you just replace the stock one and connect the gauge to it or something. says all honda civics
__________________
www.lubecontrol.com
Member 1025782
Old 12-11-2005   #9 (permalink)
Boilermaker1
Jap-Euro Fusion
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
If its that, the first thing i'd do is e-mail the seller and get the thread pitch on the drain bolt. I don't think its something Honda would change, but MAKE SURE its M12x1.5 (play dumb and ask what it is, don't tell him what the pitch should be). If yes, then it should work. I can look around, I used to have a second one, lemme see if I brought it to DC with me.
__________________
2002 Civic
Old 12-11-2005   #10 (permalink)
gearbox
Super Moderator
yup thats the one. if you have it too i'll buy yours.
__________________
www.lubecontrol.com
Member 1025782
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Triple Pod Pillar Michalo187 Other Honda Civic Parts and Products 17 12-25-2004 02:19 PM
voltmeter and .... ironcow Other Honda Civic Parts and Products 7 06-07-2004 01:54 AM
What gauges are recomended for sf kit ? UnOrthodox9546 Forced Induction and Swaps 25 08-14-2003 10:40 AM
EGT Gauge? Boosted2k2 Other Honda Civic Parts and Products 3 04-03-2003 10:58 PM
Someone please answer....might be a dumb question. APS Honda Civic DIYs and Civic Tech Chat 16 08-01-2002 01:04 AM
User Login
Our Partners
used new
Top 10 Threads
IMPORTANT!! AutoX FAQ & Suspension Tuning 101!
DIY Race Car (ok fine... track day car)
Cheap light rims.
battery relocating
AutoX discussion
Super cheap deal on 15" & 17" Konig wheels
EP3 Set-up?
Auto X bad for my car?
AutoCross
Top 10 Autocross driving tips....
Site Supporters
aluminum radiator
Honda car spoilers
