Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing > Auto X/Road Racing
Auto X/Road Racing Auto X and Road Course Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-21-2005   #1 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
DIY Race Car (ok fine... track day car)
So maybe this isn't a DIY... and maybe it isn't really a concrete answer either, but I've learned enough now to try and pass some of this stuff on.
This pile of information is directed at anyone who wants to take their 7th gen out on a race track for a little track day lapping fun. I find that there's no better way to have fun than to take this thing out and beat the snot out of it lap after lap, the problem is the car isn't always up to it. I've had all sorts of sensors and what not hooked up and aimed at the car on the track, so I've figured out lots of stuff about what needs to be put in, whats useless and what falls into the general "nice to have" category.
First things first.... You will find that most track day FAQs say you need nothing but a car, a helmet and someone to drive it. They're right in a sense. You can show up with those 3 things and have a ball. Afterwards... maybe not so much. I call that answer the "sports car answer" where the car has enough balls to take a track punishment and not care. If you haven't noticed... we aren't driving sports cars.... so you need to bring a few more things to bring your Civic up to "bring your sports car" level. First ... get yourself some decient tires. Preferrably of the high performance variety. I have seen people take good all seasons on the track, I'm not sure any of them would do it again. At 80 or 90 MPH, tires get hot, cornering on the limit only makes they hotter. You don't want to overheat tires and have them come apart or chunk up on the track. Its not safe for you and its not safe for others on the track. Expect to pound your tires pretty good. Show up with at least 1/2 tread, you'll probably leave with more than enough to get home, but better safe than sorry on cording a shoulder. It may be wise to even pick up a second set of rims and put your race track tires on. This prevents the possibility of picking up a nail or something on the highway (BTW, don't ever take a patched or plugged tire on the track).
Now that you got tires, time to take a look at the next thing... brakes.
Some tracks are much harder on brakes than others. Where I usually go (Gingerman), its aweful on brakes. Others are more kind. Either way, don't waste your time with big rotors or 4 pot calipers. They're not necessary. Keep stuff stock sized, just buy the cheapest rotors you can find and pick up some light duty track/autox/HP street pads. Most people will recommend Axxis Ultimates, Hawk HP+, Cobalt Friction GT Sports, or Carbotech Bobcats. I've had Ultimates on the track, the first set wore real well, the second set I tore the lining off the backing in 100 miles of tracking. So mixed results. I have Hawks on the car now, we'll see. Back to the hard on brakes track thing... if you find that you're overheating the brakes (exceeding the max pad temp), which you can usually figure out buy the pads coming apart in pieces or disappearing very fast, the first thing you should probably do is pull the dust shields off. They're pretty useless. Once you've committed the car to track whore status, you'll have enough tire junk marks elsewhere that some brake dust on your suspension is meaningless. So give your brakes some air. Ducting is also a possibility, good luck finding somewhere to route them. As far as the rears... um,yeah. Your shoe options are Honda or Porterfield. I never tried the porterfield shoes, but I did manage to burn up a set of brand new shoes in 1 trip to the track. By burned up, I mean literally. I opened up the drum and got a mountain of white ash-like dust. If you're on a track where you aren't hard on brakes, or just don't want to push as hard as you can, the drums are fine. If you are hard on brakes... maybe try Porterfields, or find yourself a set of Si discs. Its a pain in the neck, but discs cool much better than drums do, which helps. Now that you've messed around with all that, don't forget to dump some high temp brake fluid in. Stock isn't gonna cut it. You'll boil it in 2 laps. ATE Superblue/Type200 works well, Motul 600 will probably work better but you gotta change it more often. I use ATE, never had a problem. Bleeding after a track day is a good idea.
Cooling wise, you're golden. Honda has greatly overdone the radiator, I've never broken 210 on the track. Waterwetter is good, but not needed, you can run stock coolant in the stock system and be fine.
Oil on the otherhand... there's a bit of a problem. There's not enough of it, and there's not enough air to cool it off. Result is the oil keeps getting hotter and hotter. If you're running synthetic, you *may* be ok, but make sure you change it afterwards. If you're running dino juice, no guarantees, you may be picking up pistons off the track. When I say hot, I mean it, I've had oil over 270 on the track, which is a good 40 degrees more than you want it at a maximum. This is where the whole econobox thing really plays in. You're gonna be banging the redline for 15-20 minutes straight... the car isn't made to do that. Don't feel bad though, even people with K20A2s are having oil temp issues. Solution is an air-oil cooler. It looks like a small radiator, you can build one thats as expensive or as cheap as you want. The most important thing is to just make sure you get oil through it in suffecient quantity it doesn't throw your oil pressure through the roof. I recommend the use of -10 AN or equivelant sized rubber lines to and from the cooler. It keeps a lot of oil moving, which is what you want, and it keeps the pressure safe because you're not really changing the size of the ports the oil is running through. If you're not sure whether or not you need one, buy an oil temp sensor and mount it IN THE OIL PAN. Take the car out and measure it, if you're going over 230 or so, you probably want to invest in one. Don't forget to account for the outside temp... if its 90 out, you'll run hotter than if its 65. Its an easy way to not spin your bearings. Once I put the cooler on (my system is speced out in a thread somewhere), I brought the oil temps down to 215, which is about perfect, I'm also running 5.5 qts of oil now.
Point of good news is there doesn't seem to be a way to starve the pickup. Plan on the engine eating a little oil on the track (consequence of running flat out), and VTEC historically has a tendency to consume some, I dont know why. Bring a quart to the track.
Thats really about it. There's not much to getting the car ready to survive, now comes the other part... the fun part, making it go FAST.
Rule 1: Horsepower doesn't rule the road course. Write that down. Put it under your pillow and learn it by osmosis. Say it as you brush your teeth at night, I don't care how you get it in your head, just get it there. Straights are there to get you set for the next corner. So forget about turbos (they're actually not wise for a road course car anyways unless you build it REALLY well), swaps aren't necessary or any of that crap. Thats right, I found a use for your D17. What does make the car go fast is your ability to know the line of the track and hit it. This unfortunately isn't something that is intuitive. It takes time to learn, luckily most tracks are established enough to have nice black "lanes" in the corners to follow. You just gotta learn the track. No 2 corners are the same, neither are their setups or exits. There's late apexes, early apexes, double apexes, chicanes, esses, increasing radius, decreasing radius, on and on..... Practice makes it better.
Rule 2: Use the brake markers. Those are the sticks or signs before a corner. Don't plan on having the luxury that Michael Schumacher has on Sunday with big signs that spell out 200, 100, 50. Sticks may be all you get, they will be evenly spaced, but no guarantees on the distance. 50 yds is pretty standard though. How early you go depends on how hard you hit the brakes and how severe the corner is. Just remember, the harder you push the brake pedal, the faster they disappear. Unless you're running someone down for the lead (which you're not, this is a track day, not a race) you don't need to go as late as you can every time.
Rule 3: Mirrors are good, but don't live in them. Use your mirrors... all 3 of them. Don't constantly look in them though. Concentrate on the track, but if you get some time in a straight section, check them and let faster cars by. A fast car is defined as someone who is up your rear through a set of corners. Let them by in whatever was announced as the passing zones (these will be given in the drivers meeting in the morning). I don't really define a higher horsepower car to be a "faster car" if all they can do is pull on me in a straight line because I know 2 corners later I'll be back on his ass. Nothing will piss someone off more than not being let by when there is an opportunity to do so. Do it safely, wave them by and let them pass on the left. Ease over and take your foot off the gas, do not touch the brakes. Random braking makes people behind you nervous and you could cause a pileup... not good.
Rule 4: Don't race your friends. This goes back to its a track day, not a race. Its stupid, you'll probably get thrown out, especially if you make it look obvious. There's nothing wrong with following or lapping in groups, I do it all the time. Its great for working on lines if you talk someone who knows the track into running with you, but if you're gonna do it, keep your place in line, don't keep leapfrogging back and forth, you're looking for a disaster as soon as egos come on.
Rule 5: Don't be a hero. There will come a time, I've done it, as has everyone else who's ever set tire on the track, where you will push too hard and lose control in some way. Remain calm. Thats the most important thing. Trying to save it may actually make the situation worse. If you go into a corner too hot and the car won't turn and running off the track is inevitable, go straight off the track, try and keep the wheel centered. Track infield isn't the smoothest stuff... turned wheels aren't necessarily good. Get the car back under control, and safely re-enter the track. Pit immediately and get the car looked over for damage. Its uncommon, but you also don't want to drop any junk on the track. If you feel the rear start to come out, be gentile with your corrections. It doesn't take much at speed to overcorrect and throw the rear end out the other way. Sometimes there's just nothing you can do and it snaps around. Should you spin out, chances are, the car will die. Just so you know. When oil goes up the engine wall or fuel comes off the pickup, it tends to stall the car. It should restart. You may get a CEL. If you do, reset the computer, it should go away unless you broke something. This is also reason number one why you shouldn't ride someone's ass. Watch NASCAR on sunday and see what happens when one car loses control. If you ever have to pull off the track due to a problem, STAY IN THE CAR. The exception is if the car is on fire. If you get out of the car, they have to red flag the whole track, that pisses everyone off. If you have any control over it (sometimes you don't), pull off the track as far as you can, and in a spot where you're not in danger of being hit (on the outside of a corner near the exit is NOT a smart place). Best is to pull yourself off near a worker station, and if possible, put the worker station between the track and your car. Wait for assistance.
Ok, so we've gone from the car, to driving, now its time for a little Voodoo. The suspension. I can't tune your car, niether can anyone else really. You can take suggestions, you can do your homework and all that other stuff and still end up messing with it. Can you take a completely stock suspension on a track, sure, absolutely. Its it fun? Sure is. Believe me, race tracks are fun. I'd do it on a Power Wheels if I had to. There's something about being allowed to go as fast as you possibly can and not getting in trouble for it. Now, there's of course ways to increase the magnitude of the fun. As we've established before, HP won't always make you faster, so there's gotta be another way to go faster.... make it hold the road. You really can do any sort of upgrading you want. Depending on how trackish you want to make the car vs. making it streetable. New shocks will make a huge difference from a reaction standpoint. Just the firmer damping with help greatly. You can run progressive springs on the track, lots of people do it, the problem you stand the chance to run is them not being stiff enough and you hit the bumpstops. There's no easy solution to that. Next step up would be a straight rate racing spring. Ground Controls or something of the sort. You can go to full coilovers. Necessary? No. You actually won't see too many club racers running threaded body coils. Some of it is due to rules, some of it is just because there's no need. Your alignment will also make a huge difference. To do it right, use a tire pyrometer and go for even temps all the way across. For the casual tracker, throw out the stock alignment specs. Go for something like -1.75 to -2.25 in the front and -1 to -1.7 in the rear. Forget tire wear. If you're going on a track and you care, go home and go back to bed. Sway bars.... don't forget you're going fast. Oversteer can get you in trouble. If you've got a 19, I'd say you're safe. 22mm bars make sure you ease up to it first. Find out just how hard you can go. Believe me, 22mm bars on the track are fun as all get out, but they're definitely not forgiving to courageous manuvers, so be careful.
If you're just starting out, I do not advise the use of R-compound tires. In fact, I ban you from using them. The stocker you go out there, the more you gotta control the car and the less the car controls itself. It'll make you a better driver down the road. Roll cages and racing buckets are unnecessary for track days, don't bother. JDM does not make you faster. Put your money where it's needed. Plan on having to fix things afterwards. I guarantee you'll find something you don't like or isn't up to snuff. Spend money on brake pads but not brake rotors. Buy good tires, but not forged Volk wheels. Plan on trashing everything. Leave your bodykit at home or find a way to tape it over. Track junk will hit your car and leave marks. While most of it is just rubber chunks and will come off, every once in a while someone will kick a stone up and there's not much you can do. Thats why you'll see most people tape headlights. It keeps the scuffs on them down and if they shatter, all the pieces stay put. I guess this is also a good time to mention that while track days are classified as driving schools, the nature of it being a closed environment speed event usually voids your insurance for the day.
While you're not actually racing, you're still theoretically racing yourself. You'll have laps that you know went better than others, the more and more you get those kinds of laps, the more consistency you're developing. Thats good. It means you're getting better. If you're consistent and right, you'll find yourself running faster than some of those cars you thought were "fast" and you're well on your way to learning why the driver makes the car go.
Have fun.
Any of you other guys can feel free to add to this if I missed something or your experience says otherwise.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Sponsored Links
Old 05-21-2005   #2 (permalink)
bgoetz
bgoetz's Avatar
bgoetz is an unknown quantity at this point
it is a fvcking book LOL JK
bgoetz is offline   Reply With Quote
Old 05-21-2005   #3 (permalink)
xam
snooty patooty partier
xam's Avatar
xam has a spectacular aura about xam has a spectacular aura about xam has a spectacular aura about
Send a message via AIM to xam Send a message via MSN to xam Send a message via Yahoo to xam
cliff notes? lol
__________________
xam is offline   Reply With Quote
Old 05-21-2005   #4 (permalink)
DaddyFatSacks
Super Member
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Good post boiler maker, as usual. Very informative. Any tips for actually driving the car, some thing things that work good in the Civic?
__________________
Eternal Blue Pearl EX coupe 01" manual - AEM sri, RS*R ExMag stainless cat-back, Energy MM's, Revo SS w/ Type-R boot and ARC knob, Neuspeed strut bar (chrome), Tenzo tie bar, RSX-S rear sway, Progress springs, full SPC camber kit, Brembo rotors, AXXIS pads, Motul fluid, and 16" Rota Slipstreams (Polished) w/ 205/50/16 Nitto Neo-Gen's.
DaddyFatSacks is offline   Reply With Quote
Old 05-21-2005   #5 (permalink)
Boilermaker1
Jap-Euro Fusion
hmm... standard front wheel drive rules apply. Be smooth, enter turns later than you think, drive with both feet. If the car starts to push, put your foot down, don't let off. Its pretty well-mannered out there. I'm trying to think if it has any real quirks, it really doesnt. Don't do anything sudden, be smooth and you'll go faster. Just watch your revs. If you're entering a corner at a point where you downshift to something above 5000 RPMs, you shouldn't have downshifted. A smart old guy once told me that if you're that close to a higher gear, find a way to run the higher gear (i.e. find a line that lets you run faster). Gear shifting wastes time, especially if you downshift to enter, then upshift the exit, there's no point. And don't ever shift mid corner, you'll throw the car out of control, just ride the rev-limiter until you can get the wheels straight.
Old 05-26-2005   #6 (permalink)
ojay
Diamond Member
ojay's Avatar
ojay is on a distinguished road
Send a message via AIM to ojay
finally got around to reading it. good post as always. track days aren't cheap, eh? i'll probably have to hold out on one for awhile
__________________
7thgen heroes: DC5@EM2, icebergslim, Mirage/DelSolid, HondaLuver, Zzyzx, Boilermaker1, robbclark1, Hawk, JUNCiViC, bobbyd/danase
-ojay!
ojay is offline   Reply With Quote
Old 06-11-2005   #7 (permalink)
PoorCollegeBoy
Stolen digital camera = no ninja picture for me
PoorCollegeBoy's Avatar
PoorCollegeBoy is a jewel in the rough PoorCollegeBoy is a jewel in the rough PoorCollegeBoy is a jewel in the rough
Send a message via AIM to PoorCollegeBoy
Thanks for all the info. I just had my first autox last week, and had a blast. Our cars seem to be pretty decent at autox, and I look forward to beating cars that cost twice as much in the future.
PoorCollegeBoy is offline   Reply With Quote
Old 06-14-2005   #8 (permalink)
P40vic
Member
P40vic is an unknown quantity at this point
Awesome post Boilermaker. Lots of great tips, even if we aren't tracking (autox does have simplicity going for it). Now I can see why you made the suspension choices you did, I'll bet it rocks on the track.
I've changed my mind on camber plates for the moment, want to stay with stock spring diameter and top hats for the daily ride. Came up with an STS legal camber bolt solution that should be slip proof but it's requires a few additional machined parts. Gotta find some donor struts for Konis to get started...
Hey Greg-should be another fun event this weekend. I've never been to a tour before but the Denver tour next month is right in our backyard and there will be 3 days of runs. Too good to miss!
P40vic is offline   Reply With Quote
Old 06-14-2005   #9 (permalink)
xam
xam's Avatar
finally got time to read it. w00t. A+ post b.m.
__________________
Old 08-24-2005   #10 (permalink)
Pn0ybOiLiKehOy
Diamond Member
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
sorry to bring back a post from the dead, but how did u manage to run 5.5 quarts of oil? just keep adding? and is it safe for driving home?
Pn0ybOiLiKehOy is offline   Reply With Quote
Old 08-24-2005   #11 (permalink)
Boilermaker1
Jap-Euro Fusion
Oil cooler
1/2 quart in the grid, its a filter for a Ford 302 ci V8 (1/2 a quart) and 12' of -10 AN line
__________________
2002 Civic
Old 08-24-2005   #12 (permalink)
Pn0ybOiLiKehOy
Diamond Member
ooh..got ya
Old 09-14-2005   #13 (permalink)
01redJDM
01redJDM's Avatar
01redJDM is on a distinguished road
Quote:
Oil cooler
I wonder if I can use the oil cooler off my friend's 325i ? btw very nice post, can u also make some wheel/tire suggestions? I already have summer and winter wheels/tires and I want to get a set of light wheels with good tires just for track... will factory alloy wheels off a Honda or acura EL do the job?
can u also make some suggestions for coilovers? are Teins any good for track? or I'm better off going with springs and shocks?
Also, I have 130000km on my rotors, and am taking my car to a full day track next month, u think I should change them when I'm doing the pads this weekend? What kind of rotors should I get, just oem off the dealer or something else?
I have a D17, what kind of oil should I use? I changed it yesterday and put Castrol GTX, does Syntetic do any good?
Thanks alot man
01redJDM is offline   Reply With Quote
Old 09-14-2005   #14 (permalink)
TheSmuggler
TheSmuggler's Avatar
TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned
Send a message via AIM to TheSmuggler
This almost makes me want to go to the track! But then I realize that I'd have to wave by the kids on their huffies on the left...
__________________
JDM'ing it since 1985
HighwayStar - /super highway/stunt driving/transport service/fast delivery/
RoadPirate - /live forever/interstate commander/highway hijack/
PerfectWorks
TheSmuggler is offline   Reply With Quote
Old 09-14-2005   #15 (permalink)
Boilermaker1
Jap-Euro Fusion
Thanks alot man
Never seen a BMW cooler, don't know. I'm sure anything works if you plumb it up right.
Any wheels work wider is better, any summer tires work. I was happy with Kumho MXs on the track.
If its 'JDM' and suspension related, its probably not track worthy unless you can't afford it, buy Konis
get new rotors, rule of thumb is less than 1/2 pads when you start warrants new pads, I use the shittiest rotors I can find, usually autozone. I throw them out once a year anyways.bed the pads real well and get them very broken in. a couple hundred miles probably won't cut it, you need 1000+. Unbroken in pads and rotors will cause the pads to disintegrate under high heat 9/10 of the time. Just changing pads does not solve this problem. I would not take honda front pads on the track either. Axxis ultimates, Hawk HP+ or Cobalt GT sports are where I'd go.
Use synthetic, it won't help the overheat, but it won't break down as fast and gum up your engine either.
Lastly, do not modify stuff just because you're going to go out on the track and definitely do not make 400 changes within a month of going. You'll end up with a car you don't know how to drive and you'll have no idea how to make it right... then you're magnifying the problem by going flat out. If you're going in 1 month, I wouldn't change anything on the car besides the mantenance stuff to make the car track ready. Leave everything else alone.
__________________
2002 Civic
Tags
build , car , cars , civic , day , denver , diy , forum , lapping , make , plugged , race , racecar , stock , tire , touring , track
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
first track day ? Tomola Auto X/Road Racing 22 03-21-2005 10:52 PM
1st Open Track event. Zzyzx Auto X/Road Racing 16 09-28-2004 02:17 PM
Nice Horsey.... Boilermaker1 General Automotive Discussion 44 07-27-2003 09:27 PM
Insurance and Drag Racing CarbonFly General Automotive Discussion 11 04-28-2003 11:17 PM
Poll: Show or Go! Subrage General Automotive Discussion 54 04-02-2002 11:32 AM
User Login
Our Partners
used new
Top 10 Threads
IMPORTANT!! AutoX FAQ & Suspension Tuning 101!
Cheap light rims.
battery relocating
AutoX discussion
Super cheap deal on 15" & 17" Konig wheels
EP3 Set-up?
Auto X bad for my car?
AutoCross
Top 10 Autocross driving tips....
Site Supporters
aluminum radiator
Honda car spoilers
