Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing > Auto X/Road Racing
Auto X/Road Racing Auto X and Road Course Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-20-2004   #1 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
alignments..... Yes you need one.
From the Last few weeks of dealing with a Little 89 Si preped for STS and the most recent issue of SportsCar magazine, I'm finally convinced that the proper alignment is probably one of the most important things for performance in the corners. Unfortunatly, I cant say what is the best alignment for us, cause there arnt enough of us messing with it, and proper alignments change with different parts/setups. But, I cant stress this enough, finding the best alignment for your particular set up IS the key to getting every last tenth out of your civic.
so, untill one of us finds a good alignment set up I did some searching around and came up with some settings that other Simmilar cars are running for autocross.
#1 STS Preped Neon.
Alignment (camber) 2.5 to 3 degrees negative in the front. 1.5 to 2 degrees in the rear.
Alignment (toe) Zero toe in the rear and between 1/8" and 1/4" Toe OUT in the front.
#2 STS preped 89 Si
Alignment (camber) 2.5 to 3 degrees negative on the front and 2 at the back
Alignment (toe) 1/8 toe out on the front and 1/16th to 0 toe on the rear.
Toe out on the front and 0 to 1/16th toe in on the back seem the norm, Ive been told that for a street car don't do more then 1/8th inch toe out, or the car will want to wander alot.
Camber seems to be Get as much as you can on the nose Rear, less so.
not much info on caster, but I've been told to try to get as much positve caster as possible within stock specs.
Disclamer: these settings wouldnt be all that frendly to tires.... Toe will eat tires quicker then camber, and from what I've heard you can run up to 2 deg negitive camber with out much extra wear..... not sure if thats true, but then if you were really worried about tire wear you wouldnt be autocrossing.
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Sponsored Links
Old 04-20-2004   #2 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
The problem is that almost all of our cars are DDers. It is hard to run those settings while driving everyday. It is hard to change the front camber because of that stupid steering arm. You drop the camber, you drop the toe. The only way around it is to do your own alignments with tools you can buy from racer mags.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 04-20-2004   #3 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
True, however setting up the car with say 1 to 1.5 Deg negitive camber on the front, and maybe .25 to .5 on the rear, and possibly 1/8th inch toe out on the front, and 0 toe on the rear... Probably would be a good place to start, with Minimum extra tire wear.
Old 04-21-2004   #4 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Rob, you just gotta compromise it, and buy some hard tires for DDing.
Mine right now isn't so great, but I'm gonna get it reset. Probably just the front end since the rear is at -1, 0 toe already. I'm thinking 1.5 or so, no toe and see what that does. I doubt it'll eat tires. The older Civics and Integras had a front camber spec that went to almost -3 deg.
Boilermaker1 is offline   Reply With Quote
Old 04-21-2004   #5 (permalink)
robbclark1
robbclark1's Avatar
well my tires are only around 20k old and still have a lot tread left. their tread wear is only 300. I can't afford to compromise at the moment as much as I want to, especially with me starting school and buying a house. One day I will get there! That will be when I make the civic a full blown race car .
BTW i got my K1's!!! they are powdercoated black, but they are done nicely. Pics are in my galler.
__________________
Suspension FAQ
Autocross FAQ
Old 04-21-2004   #6 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Thats How I'm doing it, My current street tires are a set of Continental All season Performance tires with a tread wear of 400, should last quite a while even with -1.5 deg camber in the front.
Old 04-21-2004   #7 (permalink)
slowvic
Member
slowvic's Avatar
slowvic is an unknown quantity at this point
My car is an alignment whore. I think I've aligned it about 6 times in the past year. I ran 2 degrees negative in the rear and 1 degree up front for about 6 months and the tires wore perfectly even. Recently I've been running -2 up front and -1 in back with no problems. Zero toe makes the front darty and the rear ass happy.
slowvic is offline   Reply With Quote
Old 04-22-2004   #8 (permalink)
dscottb01
Member
dscottb01's Avatar
Location: Scott County, KY. Where else? This is my town! Na na na..na..na..
dscottb01 is an unknown quantity at this point
Quote:
Would this setup work on an 01 EX Coupe? I have been searching for a good setup that works good for everyday driving but lends great help to auto-x with Kuhmo's!
__________________
D. Scott B.
04 Civic EX Coupe Rallye Red
409West Speedsports
DATS Racing
Hankook Motorsports
Towery Motorsports
Life is not a straight line, it is a series of turns. How you negotiate them determines in what place you finish!
--My Father
dscottb01 is offline   Reply With Quote
Old 04-22-2004   #9 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
^^ it would be a start, you may need to tweak the toe settings. Maybe dial in a little toe in on the rear?
Old 04-22-2004   #10 (permalink)
dscottb01
Member
dscottb01's Avatar
I am having the car aligned next week before the event at Ft. Knox. I will give it a try and let you know the results. BTW, how much toe in on the rear would you suggest?
__________________
D. Scott B.
409West Speedsports
DATS Racing
Hankook Motorsports
Towery Motorsports
--My Father
Old 04-22-2004   #11 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
I'd start with a 16th, thats what we are running on our 89 Si.
Old 05-04-2004   #12 (permalink)
Roy
Senior Member
Roy's Avatar
Roy is an unknown quantity at this point
I've been playing with my alignment over the past couple months. Now, bare with me, I do it myself... and I'm one lazy bastard. Trust me, it takes a while to set up the jig right and double and triple check your results. And this is also for a daily driver/wknd. corner carver.
I'm running 1/8th toe OUT -1 deg. FRONT and 1/16 toe OUT -.25 deg. REAR.
Impressions are as follows...
car hooks up great. turn in is quick and responsive... hence the toe out. However, there is still moderate push on mid phase (steady state turns). Hook turns (90 deg.) box, and transitions are impressive.
btw, I have tein SS and a 22mm rear sway bar. With this alignment, I'd figure reducing the front bar would compliment it.
Roy is offline   Reply With Quote
Old 05-04-2004   #13 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
If its pushing mid corner thats an issue with Rollcouple rather then alignment. SO, your probably right, running an 03 16mm front bar should take care of that.
Old 05-04-2004   #14 (permalink)
Roy
Senior Member
Roy's Avatar
Ya, that's "roll center" in race car dynamics. I'm also at the limit of the tires. I'd like to run another set of Azenis or some competition radials. I also believe I'm putting my rear sub frame in bending. I'd like to reinforce that area after I play with damping.
Old 05-04-2004   #15 (permalink)
Roy
Senior Member
Roy's Avatar
Oh, P.S.
That's with 34 psi all four corners.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
IMPORTANT!! AutoX FAQ & Suspension Tuning 101!
DIY Race Car (ok fine... track day car)
Cheap light rims.
battery relocating
AutoX discussion
Super cheap deal on 15" & 17" Konig wheels
EP3 Set-up?
Auto X bad for my car?
AutoCross
Top 10 Autocross driving tips....
Site Supporters
aluminum radiator
Honda car spoilers
