Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing > Auto X/Road Racing
Auto X/Road Racing Auto X and Road Course Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-19-2004   #1 (permalink)
Narc
Senior Member
Narc is an unknown quantity at this point
Tire psi?
Ill be participating in 12 soloII events this year and was wondering for those that share in the same madness, what psi do you run your tires on?
im thinking 45psi in front, and 40psi in rear.
__________________
FRIENDS DON'T LET FRIENDS DRIVE STOCK.
Narc is offline   Reply With Quote
Sponsored Links
Old 04-19-2004   #2 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
what size/type/model tire?
Zzyzx is offline   Reply With Quote
Old 04-19-2004   #3 (permalink)
Pharoh
Bobaganoosh!
Pharoh's Avatar
Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of
Send a message via AIM to Pharoh Send a message via MSN to Pharoh
Quote:
Check his profile...Dunlop Racing Series Tires 205/40
I think that 40-45 is too much for those personally. Seems that they would likely slip alot with that much pressure given that when they heat the air will want to expand even farther.
Pharoh is offline   Reply With Quote
Old 04-19-2004   #4 (permalink)
kjgracing
Hail to the king baby
kjgracing's Avatar
kjgracing will become famous soon enough kjgracing will become famous soon enough
run chalk along the tire tread and sidewall a bit.
if you see the chalk being rubben off from hard cornering,
add more tire pressure.
kjgracing is offline   Reply With Quote
Old 04-19-2004   #5 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
205/40-17
When I was runnig street tires for autocross (also 205/40-17), I ran the fronts at 45-48 and the rears at 35-38 depending on the course. A friend of mine running on Much Higher profile tires then mine ran his at 50 Front and 40-45 rear.
Old 04-19-2004   #6 (permalink)
Pharoh
Bobaganoosh!
Pharoh's Avatar
205/40-17
That's fuggin nutts! I can't imagine the tire holding a hard corner at that pressure. My Exalto's will hold up to 52 but I only run them at normal pressure right now.
Old 04-19-2004   #7 (permalink)
S2000man01
O RLY
S2000man01's Avatar
S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold
Send a message via AIM to S2000man01
moving to auto x road racing forum
S2000man01 is offline   Reply With Quote
Old 04-19-2004   #8 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Quote:
Thats assuming you're running for hours on the highway and the tire really heats up. You can probably pump them up to 55 or so and have no problem. Its not like the bead will blow off. (Tire Rack uses between 80 and 100 PSI in over a short interval to seat it, then backs it off)
Used to run my 215/45 yokos at about 43/37, now i'm running my 205/50/15 Kumhos at 39/36. Once my alignment gets redone, I may be able to get it down lower in the front. Put in as much as you need to keep it rolling over. If you're running that many events, get off 17" rims unless you like buying lots of expensive tires.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 04-19-2004   #9 (permalink)
macrossranma
Ultimate Member
macrossranma is an unknown quantity at this point
Send a message via ICQ to macrossranma
Narc, you are not mad, i joined 3 series, pitl, regional and hada, did u go to hada open house? I didnt go cuz it was raining, hope my suspension will be fix before season start
macrossranma is offline   Reply With Quote
Old 04-19-2004   #10 (permalink)
Pharoh
Bobaganoosh!
Pharoh's Avatar
Ya, I run a 16" right now. Don't want to go any bigger - I was looking for a mix of form and function when I got the wheels.
Dad works for Michelin = me not worried...
Old 04-20-2004   #11 (permalink)
jiggerachi
Zoom zoom
jiggerachi's Avatar
jiggerachi will become famous soon enough
Sunday I was running my street tires(kumho supra 712s 205/55/15) at 40/38, I was slipping all over the place. Then I backed it down to like 36/34 & was sticking much better. Next event i'll be experimenting with my Azenis
__________________
zoom zoom zoom...
jiggerachi is offline   Reply With Quote
Old 04-20-2004   #12 (permalink)
dscottb01
Member
dscottb01's Avatar
Location: Scott County, KY. Where else? This is my town! Na na na..na..na..
dscottb01 is an unknown quantity at this point
I have heard of people running more than 50psi to keep the sidewalls stiff and it worked for them, however, they were in rear drive cars. I tried 43f and 34r this past weekend at the Ky Speedway on a "blacktop surface" and the grip was good. Rotation was just as I liked it. But then again, I am still running on stock shocks and springs!
__________________
D. Scott B.
04 Civic EX Coupe Rallye Red
409West Speedsports
DATS Racing
Hankook Motorsports
Towery Motorsports
Life is not a straight line, it is a series of turns. How you negotiate them determines in what place you finish!
--My Father
dscottb01 is offline   Reply With Quote
Old 04-20-2004   #13 (permalink)
Narc
Senior Member
Thanks to everyone. Goes to show that there is no such thing as a perfect formula for all cars/tires. Just hafta test and tune as I go.
macrossranma: I did go and sign up with HADA. Ill be going to all their events, as well as all the events at the Hershey centre.
I agree with all that say 17" are too big. They do slow me down, but this is my daily driver and I like the way 17"er look. What can I say, im a lord of the bling!
Old 04-20-2004   #14 (permalink)
Boilermaker1
Jap-Euro Fusion
Mine's a DD, so is Zzyzx's, and I think he'll agree with me, the smartest move was to spend a couple hundred bucks on a 2nd set of race only rims and sticky rubber. We both roll 17s on the street. I know it sounds nuts now if you're just getting started, but wait and see in a few months, you may change your mind.
__________________
2002 Civic
Old 04-20-2004   #15 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
I ran with my 17 for half a season.... then I broke down an bought some 15s and wraped them in some sticky rubber. Not only did it save my street rubber (autocross eats tires) but it made me much faster on course.
set of rota slipstreams in 15X6.5 $400
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
IMPORTANT!! AutoX FAQ & Suspension Tuning 101!
DIY Race Car (ok fine... track day car)
Cheap light rims.
battery relocating
AutoX discussion
Super cheap deal on 15" & 17" Konig wheels
EP3 Set-up?
Auto X bad for my car?
AutoCross
Top 10 Autocross driving tips....
Site Supporters
aluminum radiator
Honda car spoilers
