Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing > Auto X/Road Racing
Auto X/Road Racing Auto X and Road Course Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-28-2004   #1 (permalink)
EternalVTEC
Diamond Member
EternalVTEC is an unknown quantity at this point
Send a message via AIM to EternalVTEC
please help me decide!
Maybe this should be in the Wheel&Tire forum, but i wanted the opinions of autoxers. If im wrong in putting it here, please, move it, ill understand.
Now, Ive finally decided that im going to get a set of Kosei K-1Racing wheels in 16x7.5 and silver. they have a 43 mm offset and are 15 lbs each. They are Gravity Cast/Shot Peened, like most wheels and run $159 each from TireRack.com
now, first question, will i have offset problems with these wheels?
after I decided on those, i chose the 205/50-16 size tires.
my choices are as follows(cant get my MX's Dammit):
Nitto NeoGen
Bridgestone Potenza S-03 Pole Position
Michelin Pilot Sport
Perelli PZero Nero (Y Rated)
Perelli PZero System Asymetrico
BF Goodrich g-Force KDW
or, my failsafe Kumho Ecsta Supra 712
the reason why i posted this question here is because i wanted to know what would work best for autxing and daily driving. i know ive asked this before, but there are a few more choices this time.
Thank You!
__________________
"The whole object of travel is not to set foot on foreign land; it is at last to set foot on one's own country as a foreign land" -- G.K. Chesterton
Contact me about parts for sale(fits coupes and sedans)
In my garage:
2005 Yellow Pearl Harley-Davidson XLH 883C Sportster Custom
2002 Mineral Grey Ford Mustang GT Coupe
Previously In Garage:
2003 VBP Honda Civic Si
2003 Suzuki SV1000S (Silver)
2001 EBP Honda Civic EX Coupe
1984 Honda Shadow VT700
EternalVTEC is offline   Reply With Quote
Sponsored Links
Old 03-28-2004   #2 (permalink)
EternalVTEC
Diamond Member
btw, heres a link to the wheel
http://www.tirerack.com/servlet/Call...filterSpecial=
__________________
In my garage:
Old 03-28-2004   #3 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
The SO3s or the KDWs would be the best options for autocross, but niether will last very long. I don't think you'll have problems, but then again, I'm not sure. I know a 15x7.5 probably won't fit because you'll hit the lower bracket on the strut unless you have a really small offset (probably about 30), but if a 16 is big enough to get above it, then you won't have a problem. Honestly, i'd find a local place that will let you test fit a 16" rim without a tire, then just feel around behind it to see if there's going to be enough room.
Boilermaker1 is offline   Reply With Quote
Old 03-28-2004   #4 (permalink)
EternalVTEC
Diamond Member
my stock wheels have a 45mm offset, im not understanding why it wouldnt fit.. its a plus size 1, and is a tad shorter overall, about .5 inches.
__________________
In my garage:
Old 03-28-2004   #5 (permalink)
EternalVTEC
Diamond Member
unless youre referring to the width of the wheel
__________________
In my garage:
Old 03-28-2004   #6 (permalink)
macrossranma
Ultimate Member
macrossranma is an unknown quantity at this point
Send a message via ICQ to macrossranma
i have 215/45/17 tires on a 17x7.5 offset 45, it fits, but hitting inner fender when on full turn, but now i have visible toe in so things will be better when i have alignment done this week, but i know it will still scrape, and will not be able for autox. but yeah, with 7.5 offset 43mm its too close to the inner fender and it will scrape ALOT at autox
macrossranma is offline   Reply With Quote
Old 03-29-2004   #7 (permalink)
Boilermaker1
Jap-Euro Fusion
I'm referring to the wheel's width and its relation to the lower bracket on the strut. A 15x7.5 would hit the bracket without some sort of spacer or low offset, i don't know if a 16 would, I've only measured it for 15" wheels.
Old 03-31-2004   #8 (permalink)
EternalVTEC
Diamond Member
ill see if i can get a 16x7 to be safe
__________________
In my garage:
Old 03-31-2004   #9 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
15X7 will Fit, 15X7.5.... maybe, but be ready to buy some spacers just in case.
Zzyzx is offline   Reply With Quote
Old 03-31-2004   #10 (permalink)
EternalVTEC
Diamond Member
im getting 16's, not 15's
__________________
In my garage:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
IMPORTANT!! AutoX FAQ & Suspension Tuning 101!
DIY Race Car (ok fine... track day car)
Cheap light rims.
battery relocating
AutoX discussion
Super cheap deal on 15" & 17" Konig wheels
EP3 Set-up?
Auto X bad for my car?
AutoCross
Top 10 Autocross driving tips....
Site Supporters
aluminum radiator
Honda car spoilers
