Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing > Auto X/Road Racing
Auto X/Road Racing Auto X and Road Course Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-21-2004   #1 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
Top 10 Autocross driving tips....
ANDY'S TOP TEN AUTOX DRIVING TIPS
By Andy Hollis
(Andy is a multiple National Solo Champion and an instructor for the Evolution Solo School)
Originally posted on Miata.Net
[Just got back from a weekend of teaching Evolution schools and thought I'd share some stuff that I must have said a thousand times.]
1] Position first, then speed. Positioning the car perfectly is more important than trying to attain the highest potential speed. For example, you will drop more time by correctly positioning the car nearer to slalom cones than you will by adding 1 or 2 MPH in speed. Same with sweepers (tight line). Same with 90-degree turns (use all of the track). Also, position is a prerequisite for speed. If you are not in the correct place, you will not be able go faster. Or at least not for very long!
2] Turn earlier...and less. To go faster, the arc you are running must be bigger. A bigger arc requires less steering. To make a bigger arc that is centered in the same place, the arc must start sooner (turn earlier).
3] Brake earlier...and less. Waiting until the last possible second approaching a turn and then dropping anchor at precisely the correct place so that the desired entry speed is reached exactly as you come to the turn-in point is quite difficult to execute consistently. Especially when you consider that you get no practice runs on the course, and the surface changes on every run, and you aren't likely to be in exactly the same position with the same approach speed on every run, etc. Better to start braking a little earlier to give some margin of error. And by braking less you can either add or subtract braking effort as you close in on the turn-in point. This will make you consistent and smooth.
4] Lift early instead of braking later. Continuing with the philosophy of #3, when you need to reduce speed only a moderate amount, try an early lift of the throttle instead of a later push of the brake. This is less upsetting to the car, is easier to do and thus more consistent, and allows for more precise placement entering the maneuver (remember #1 above).
5] Easier to add speed in a turn than to get rid of it. If you are under the limit, a slight push of the right foot will get you more speed with no additional side effects. On the other hand, if you are too fast and the tires have begun slipping, you can only reduce throttle and wait until the tires turn enough of that excess energy into smoke and heat. Don't use your tires as brakes!
6] Use your right foot to modulate car position in constant radius turns, not the steering wheel. In a steady state turn, once you have established the correct steering input to maintain that arc, lifting the throttle slightly will let the car tuck in closer to the inside cones. Conversely, slightly increasing the throttle will push the car out a bit farther to avoid inside cones. It is much easier to make small corrections in position with slight variations in the tires' slip angle (that's what you are doing with the throttle) than with the steering wheel.
7] Unwind the wheel, then add power. If the car is using all of the tire's tractive capacity to corner, there is none left for additional acceleration. At corner exit, as you unwind the wheel, you make some available. If you do not unwind the wheel, the tire will start to slide and the car will push out (see #6 above).
8] Attack the back. For slaloms (also applicable to most offsets), getting close to the cones is critical for quick times (see #1). To get close, we must move the car less, which means bigger arcs. Bigger arcs come from less steering and require earlier turning (see #2). Now for the fun part... When you go by a slalom cone and start turning the steering wheel back the other way, when does the car start to actually change direction? Answer: When the wheel crosses the center point (Not when you first start turning back!) How long does that take? If you are smooth, it takes .25 - .5 seconds. Now, how long is a typical person's reaction time? Answer: about .5 seconds. Finally, how long does it take to go between slalom cones? Answer: Typically on the order of 1 second. Given all of that, your brain must make the decision to begin turning the steering wheel back the other way just *before* you go by the previous cone!!
Since this is a mental issue, a good visualization technique to get used to this is to think about trying to run over the back side of each slalom cone with the inside rear tire of the car. To hit it with the rear tire (and not the front), the car must be arcing well before the cone and the arc must be shallow. Attack the back!
9] Hands follow the eyes, car follows the hands. 'Nuf said.
10] Scan ahead, don't stare. Keep the eyes moving. Looking ahead does not mean staring ahead. Your eyes must be constantly moving forward and back, and sometimes left and right. Glance forward, glance back. Your brain can only operate on the information you give it.
Bonus Tip: Don't forget the stuff in between the marked maneuvers! Too often we think of a course as series of discrete maneuvers. There is typically more to be gained or lost in the areas that are in between. Pay special attention to the places where there are no cones
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Sponsored Links
Old 01-21-2004   #2 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
want me add that to the Autox FAQ post?
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 01-21-2004   #3 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
I just found it, but it may be a good Idea...
Old 01-22-2004   #4 (permalink)
VTECTypeR
Ultimate Member
VTECTypeR's Avatar
Send a message via AIM to VTECTypeR
Good Info
VTECTypeR is offline   Reply With Quote
Old 01-22-2004   #5 (permalink)
AznSaint
Ultimate Member
AznSaint is an unknown quantity at this point
__________________
rice mobile
AznSaint is offline   Reply With Quote
Old 01-22-2004   #6 (permalink)
Roy
Senior Member
Roy's Avatar
Roy is an unknown quantity at this point
it think it's better put this way... the car goes in the direction your head is pointed. you should be constantly scaning by moving your head, and not just your eyes alone.
Roy is offline   Reply With Quote
Old 01-24-2004   #7 (permalink)
02SilverSiHB
K Motor Lover Baby!
02SilverSiHB's Avatar
02SilverSiHB is an unknown quantity at this point
number 2 is good info for me and number 9 is so true...look ahead!
__________________
K20a2 Powered EP3
02SilverSiHB is offline   Reply With Quote
Tags
1993 , autocross , civic , drive , driving , honda , instruction , k6 , racing , rain , technique , ten , test , tips , tire , top
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
IMPORTANT!! AutoX FAQ & Suspension Tuning 101!
DIY Race Car (ok fine... track day car)
Cheap light rims.
battery relocating
AutoX discussion
Super cheap deal on 15" & 17" Konig wheels
EP3 Set-up?
Auto X bad for my car?
AutoCross
Site Supporters
aluminum radiator
Honda car spoilers
