97 civic cluster gear indacter lights dont work
Rep Power: 0 97 civic cluster gear indacter lights dont work
hi im new to the forum i have a 97 civic ex and my dash lights work and everything else works but the gear indacater lights on the gauge cluster i checked for loose connections nothing checked and replaced all bulbs and still nothing please help what can i do to fix this? car drives fine no codes or anything it is the only problem i am having. is there anything else i can try please any sujestion will help please.
Re: 97 civic cluster gear indacter lights dont work
NO codes?
Does the shifter interlock work?
Do the back up lights work?
I guess I'd follow the wiring diagram and use a DVOM to verify a signal from each lever position is reaching the appropriate wire at the gauge cluster.
I'd probably check in the shift position bulb connections to see why it is not lighting up, what is missing, either the hot or the ground for a bulb so I can decide which way to chase.
I'd check for correct voltages on the wires at A1 and A2 in the cluster for operating the the shifter indicator dimmer unit inside the cluster.
HTH
HTH
Rep Power: 0 Re: 97 civic cluster gear indacter lights dont work
yes all my other lights work but the gear indacaters on the cluster the gear indacaters on the shifter console even light up and work but not the cluster ones. and as far as i know the shifter interlock does work. is there a way to jump the wires to make them work temporarly?
so what if i start with replacing the circuit bord to it then go from there is it a possibility that the board went bad?
curaze
09-22-2015 08:27 AM
Wiggles
09-08-2015 05:05 PM
