Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-27-2009   #1 (permalink)
2k5reverb
New Member
2k5reverb's Avatar
2k5reverb is an unknown quantity at this point
Hid on drls?
Hi guys i have a 05 civic and am looking to install an hid kit and was wondering if there is a way to make Daytime Running Lights Run a full power? Since hids will flicker and burn up ballasts because of the lower voltage. To remove this ad, register today for free or log in if already registered!
2k5reverb is offline   Reply With Quote
Sponsored Links
Old 08-27-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Hid on drls?
dont 05 civics use the separate hi beam at reduced power for drl? so i doubt youll have any issues if you put hid in the lo beam spot.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 08-27-2009   #3 (permalink)
2k5reverb
New Member
2k5reverb's Avatar
Re: Hid on drls?
yes the high and low are on seperate bulbs, but i wanted hids in both is that possible without disabling drls?
Old 08-27-2009   #4 (permalink)
gearbox
Super Moderator
Re: Hid on drls?
if you want hid in the hi beam, you must disable drl (factory drl that is). you can wire up your own to work with hid, but having full bright hids in the hi beam is gonna be crazy even during the daytime. your only other option is get one of those turn signal drls that puts the signal on full bright as a drl and also works with the turn signal switch. thats what i have on my 02 and its very nice
__________________
www.lubecontrol.com
Member 1025782
Old 08-27-2009   #5 (permalink)
2k5reverb
New Member
2k5reverb's Avatar
Re: Hid on drls?
Thanks Gearbox ! How would i go about wiring my fog lights as my drls instead of the corner lights ?
Old 08-28-2009   #6 (permalink)
gearbox
Super Moderator
Re: Hid on drls?
fogs may be too dim for drl, but you can try. if you have oem fogs, its just a matter of testing wires at the switch. you have to find the wire that gets hot only when the headlights are on. thats the trigger. you can cut it and attach the switch side to an alternate power source like the battery, that way the switch works all the time even without the park or headlight being on. but you may forget them on, so you could also tap the wire to the 12v socket power wire.
__________________
www.lubecontrol.com
Member 1025782
Old 09-07-2009   #7 (permalink)
liljohnny
New Member
liljohnny is an unknown quantity at this point
Re: Hid on drls?
Quote:
Gearbox, sorry for the newb question but is it a simple fuse pull to disable the drl's in the 02 civic coupe? I'm gonna do a projector retro and I'll need to disable the drl's. Sorry for the threadjack
liljohnny is offline   Reply With Quote
Old 09-07-2009   #8 (permalink)
gearbox
Super Moderator
Re: Hid on drls?
one or two drl fuses to pull out. or you can disable the actual drl module which is next to the hood release lever under the plastic panel.
__________________
www.lubecontrol.com
Member 1025782
Old 09-07-2009   #9 (permalink)
liljohnny
New Member
Re: Hid on drls?
Any how to's??/ Which number fuses to pull?
Thanks
Old 09-07-2009   #10 (permalink)
ADMCivic
Member
ADMCivic's Avatar
ADMCivic is an unknown quantity at this point
Re: Hid on drls?
Under the steering wheel theres a fuse box, open the panel and theres a diagram, on the diagram it will say daytime i think, theres 2 fuses, pull both them out.
ADMCivic is offline   Reply With Quote
Old 09-07-2009   #11 (permalink)
ADMCivic
Member
ADMCivic's Avatar
Re: Hid on drls?
Old 09-07-2009   #12 (permalink)
gearbox
Super Moderator
Re: Hid on drls?
should say which fuses in the manual. mine doesnt say it cause i have usa civic without factory drl.
__________________
www.lubecontrol.com
Member 1025782
Old 09-07-2009   #13 (permalink)
liljohnny
New Member
Re: Hid on drls?
Thanks guys, I'll have a look. Gearbox, any hints on making the retro go smooth? I have a couple 370Z bix projectors I'm gonna try to retro into the stock housings.
Old 09-08-2009   #14 (permalink)
liljohnny
New Member
Re: Hid on drls?
Oh yea, one more newb question, are the sedan and coupe headlights the same in 2002?
Old 09-08-2009   #15 (permalink)
gearbox
Super Moderator
Re: Hid on drls?
just be careful when cutting. you need to be sure the projector can mount securely to the reflector and still keep the stock adjusters. mount it from the front so most of it is in the reflector and not sticking out the back too much. and our housings have a tilt to them when installed so you have to rotate the projector about 5 degrees. you really should do it with the housings on the car to make sure the rotation is flat. sedan and coupe lights are basically the same except for some small differences, and the parking/signal bulb sockets have different connectors.
__________________
www.lubecontrol.com
Member 1025782
Tags
drls , hid , lights
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
