Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-19-2009   #1 (permalink)
HatchisBack89
New Member
HatchisBack89 is an unknown quantity at this point
Retrofit question
Kinda new at this thing but i was reading posts about HID retrofits in stock headlight housings and was curious if it would be possible to use a universal HID projector fog light kit as the projector and housing for the headlight retrofit. Not sure if there is any difference in the refection and refraction design of the fog light projectors and headlight projectors. Thanks in advance for any input.
FYI: Attempting to retrofit headlights on 89 civic hatch.
Just realized i posted this in 7th Gen civic section. Brain not functioning. :-(
Last edited by HatchisBack89; 06-19-2009 at 05:26 AM. Reason: Posted in wrong section
HatchisBack89 is offline   Reply With Quote
Sponsored Links
Old 06-19-2009   #2 (permalink)
MidnightCivic
MidnightCivic's Avatar
MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light
Send a message via Yahoo to MidnightCivic
Re: Retrofit question
hidplanet.com also not sure that would be a good idea since cut off and light output will suck...gearbox just input on this
__________________
Current Mods
• DIY BOH • Progress Rear Sway
• Yellow Fogs • Altezza Grill
• 16 red/black te37 replicas • ep3 side markers
• Hayame Cat Back • K&N fipk intake
• D2's • 04 Smoked Taillights
• Cf Hood • Neuspeed Strut Bar
• Aero Sides • Oem Rear Lip
• Type B Front Lip • D3S Retro Headlights
Future Mods
• CF Trunk
MidnightCivic is offline   Reply With Quote
Old 06-21-2009   #3 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
short answer.....no. i have Blazer 894 projector fogs. they are very wide, but short distance projection. i also have TSX projectors retro'd into TYC housings and the TSX projectors are almost as wide as the fogs, but project 5x further down the road. both combined is sweet and i'll never go back to halogens, but the fogs alone performing as low beam head lights would be horrible.
electric130 is offline   Reply With Quote
Old 06-22-2009   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
yeah like he said, its two completely different optic patterns. lo beam projectors have a bright hotspot at the top of the cutoff, then the brightness falls off as you move down. this is so that you have even light distribution on the ground. brighter light shines further away, and dimmer light shines closer, and this gives you the even spread of light. fog lights do not have this pattern, only a uniform beam of light that will give you bright foreground and hardly any distance.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 06-22-2009   #5 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
I got a set of the blazer fogs to (I got them from you right electric?)
They are a projectors but the distance is short and the beam isnt as intense as what a real headlight HID projector will give you. I think they are just projectors that are similar the projectors in the TYC headlights, meaning they are not HID specific. Agreed electric?
TRIZ is offline   Reply With Quote
Old 06-22-2009   #6 (permalink)
electric130
I.C.E. Mod
yeah, pretty much.
Tags
7th , 8th , civic , diy , fog , forums , gen , headlight , headlights , hid , honda , lighting , lights , projectors , retrofit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
