Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-29-2008   #1 (permalink)
mdawg
Senior Member
mdawg is on a distinguished road
HID on 6th Gen
Alright so I think ima get ready and just purchase the kit that Gearbox recommends from "yourhid". Only problem is they wont be in projectors which means light is going to shoot everywhere. Now there are two options with this...either the 35wat kit Or the 50wat kit. Im afraid that the 35 wat is not going to be bright enough. What do you think and as well do you thing with the 50wat a 6th gen stock headlight can handle the heat? Here are the links (I think my light is a h4)
50wat -
http://cgi.ebay.com/ebaymotors/12V-5...mZ110287147566
35wat -
http://cgi.ebay.com/ebaymotors/Xenon...spagenameZWDVW
__________________
New Ride:
2k1 EM2 Coupe EX 5 Speed
Current Project:
CarPC
Xenarc 700TS 7" Touchscreen
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Custom Built Startup/Shutdown Controller
mdawg is offline   Reply With Quote
Sponsored Links
Old 09-30-2008   #2 (permalink)
01HonderCivic
Don't be a n00b, search ftw
01HonderCivic's Avatar
01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future
Re: HID on 6th Gen
I bought the 50W kit from yourhid, and it works great. You want to buy a relay harness so you don't risk frying your stock harness wiring. Also HID doesn't produce more heat then halogen...Common misconception.
__________________
...Holdin' it down, Oregon style bitches!
01HonderCivic is offline   Reply With Quote
Old 09-30-2008   #3 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Any problems with it being to bright for the other drivers?
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 09-30-2008   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: HID on 6th Gen
yeah it will be bright, i would stick with 35w. if you dont like them you can always fit some projectors in there and reuse the ballasts. all you would need are the d2s bulbs and conversion cable.
i also recommend wire harness upgrade with relay. stock wiring cant handle the extra power.
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 09-30-2008   #5 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Alright gearbox ima order the 35 wat now. It states their like 3 times the lumen of a 55wat regular bulb so I hope its what I expect. I tried to search the wiring harness on the forum but the search feature never loaded, is there a diagram anywhere on how to make this new harness?
Well I thought mine was the H4 but when I use the site in the ebay auction it comes up with this:
1997 HONDA Civic (Except hatchback)
High & low beam headlamp
9003/HB2
9003SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003XV XtraVision Halogen - The Brighter Light
9003CB Cool Blue Halogen - The Whiter Light
and this
http://www.autozone.com/selectedZip,.../selectZip.htm
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 09-30-2008   #6 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
for my 01-03 civic, i made my own harness using a relay from the auto store and some wiring.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 09-30-2008   #7 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Easy enough but I still havn't ordered it yet because Im confused on which bulb my car actually uses. Your diagram of the H4 bulb is the same type of connection as my bulb(but then again with your wiring harness it seems it really doesn't matter since I am just running my own wire to the original harness so in theory it doesn't matter which kit I get?)
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 09-30-2008   #8 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
it does matter, you need the H4 kit if you have 01-03 civic because the bulb needs to fit inside the headlamp housing. all the bulbs have different sizes so get the kit that matches what halogen bulb you use now.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 09-30-2008   #9 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
But my car is a 97 and the bulb specs for it is 9003 according to autozone.com, but the only two I see are H4 and 9006
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 09-30-2008   #10 (permalink)
01HonderCivic
Re: HID on 6th Gen
9003 is H4. Same thing.
And you have to message him after the sale anyways to let him know the bulb size and what temperature you want the lights. And make sure to give phone number. He ships fast, i got mine in 4 days.
__________________
Old 09-30-2008   #11 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
9003=H4 same thing.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 09-30-2008   #12 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Alright, what temp. do I want the lights to be?
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 09-30-2008   #13 (permalink)
01HonderCivic
Re: HID on 6th Gen
I got 6000K and they're bright as all hell. But I'm very happy with them.
__________________
Old 09-30-2008   #14 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
i would not go higher than 6000k if you want bright. brightest is the 4300k, which is pure white. next brightest is 6000k which alot of people like cause its still pretty bright and has some blue tints in it.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 09-30-2008   #15 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Alright...Had to send the guy a message to see if he has anymore 35wat kits because he no longer has an auction up for them. If not I guess Ill have to go with 50wat which im really not wanting to do.
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-09-2008   #16 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Well I recieved the kit...think there is a problem. I clearly told him H4 and the box is H4 but I think the connector on this is for 9006. Stay posted ima upload pics in a sec.
It might be correct actually the diagrams are a bit confusing in the book.// nvm I think it is correct im just being dumb.
As you can see there are two pins that are blue and black wires, is this correct? The book shows 3 now granted it doesent have a high beam maybe thats why the book does?
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-09-2008   #17 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
lay out the kit so we can see it better. most everything should connect together, except the ballast. usually ballast comes with spade connectors but yours looks like 9006 plug (easily available from auto store) so it might even be easier for you. the ballast and bulb should connect together. and try the bulb in the housing to make sure its the right size.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-09-2008   #18 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Uploading pics again, I think Its right. Bulb size matches perfectly, I guess it only has two wires because the high beam is left out.
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-10-2008   #19 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
yeah that looks right. okay i see whats happening. the spade terminals are power and ground for the ballasts. the + wires both get hooked to your new wire harness (relay pin 30), and the grounds goto a chassis mount point like the stock radiator support spot. everything else seems to be direct plug in and is already connected. the power goes to the silver ballast first, then to the black ignitor which boosts the power, then to the bulb to light it up. so all you need to do is make wire harness like in my pic and attach the harness trigger to your stock 12v wire, then attach the ballast power wires to the new harness and ground the ballast (-) wires. the black should be ground.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-10-2008   #20 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Alright I will start installing them today after class and hopefully be able to post some night pics tonight. Thanks for the help!
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-10-2008   #21 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Done! Took about 3 hours from start to finish including having to make the wiring harness and run all the wires. Really easy, only complaint was I had to take the front bumper off to access the right headlight cause of all the stuff in the way. Expect some night pics later!
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-10-2008   #22 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
nice and installed the right way too. now your stock wires wont burn up lol
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-10-2008   #23 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Yeah but question: Are the ballast suppose to be as loud as they are when they first start up? They are insanely loud for the first few seconds.
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-10-2008   #24 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
yeah they supposed to buzz and then get quieter once warmup is done.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-11-2008   #25 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Wow...these things are amazing. Sorry no pic. tonight its 2am and Im just getting in. I can only imagine what 20 more watts would look like.
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-11-2008   #26 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
Re: HID on 6th Gen
do you get any static on the radio while these are on? my OEM Matsushita ballasts don't affect my radio, but my aftermarket ballasts for my fog make my radio have bad static.
electric130 is offline   Reply With Quote
Old 10-11-2008   #27 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
my aftermarkets are fine with radio.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-11-2008   #28 (permalink)
mdawg
Senior Member
Re: HID on 6th Gen
Nope, radio is fine.
__________________
New Ride:
Current Project:
CarPC
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Old 10-11-2008   #29 (permalink)
gearbox
Super Moderator
Re: HID on 6th Gen
pics?
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-11-2008   #30 (permalink)
supafil25
Senior Member
supafil25's Avatar
supafil25 will become famous soon enough
Re: HID on 6th Gen
i got the same kit works great
supafil25 is offline   Reply With Quote
Tags
55wat , 9003su , ebay , hid , kit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
DIY: Retrofit TSX Projectors
L.E.D's in the door Handle!!!!
who has ebay fog lights?
DIY : Double Neon Angel Lights
My New HID Projector Fogs
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
