how'd u waterproof the back of the headlight housing? did you just put back on the stock rubber seals?
I did the same retro but my shrouds are really ghetto so i'm gonna redo them when I have some free time. Where'd u get those range covers that curve in so much to cover the sides of the projectors?
how did u open the reflectors on the headlight?? or u cut them while it connected to the headlight?? Cuz im trying to remove the reflectors, so far i remove 2 screws and the third screw where it moves L/R, i can't get it open. any suggestion on that?
um you dont mess with the adjustment screw. headlights have four bolts and two are underneath where you need to remove the bumper to even see em. then you can stick it in an oven on low heat to soften the goo and open the two halves.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
yeah sedan has both adjustment and its as easy as unscrewing them. i think with others you need to make a hole or something idk. just be sure you can put it back so it holds the reflector
__________________
Member 1025782
