Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-02-2006   #46 (permalink)
boxcarracer
Platinum Member
boxcarracer's Avatar
boxcarracer is a jewel in the rough boxcarracer is a jewel in the rough boxcarracer is a jewel in the rough
Send a message via AIM to boxcarracer
this is to a 2002 LX Coupe Replacing Gauge Bulbs But Diskreet says to get 1.5 but diagram says 1.4W
__________________
boxcarracer is offline   Reply With Quote
Sponsored Links
Old 03-02-2006   #47 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
well like i said before, you can't change any of those from the back. the cluster bulbs are clear but the face has a painted color coat. the other indicator lights are LEDS. the ones that you can change the bulb have green or blue color icons. so i fail to see how changing anything in the back will matter.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 03-02-2006   #48 (permalink)
diskreet
diskreet's Avatar
diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold diskreet is a splendid one to behold
You can change anything, but realistically I wouldn't do anything else even with a good electronics knowledge and a steady soldering hand. It is possible, with new leds, but I wouldn't do it.
About the bulbs, it says 1.4W which might mean that they are 1.4 watt bulbs. The wattage of anything tells you how much power it is using, or how many Joules per second it uses.
diskreet is offline   Reply With Quote
Old 03-03-2006   #49 (permalink)
AlienX
Diamond Member
AlienX's Avatar
AlienX will become famous soon enough
Send a message via ICQ to AlienX Send a message via MSN to AlienX
they are all running at 12v.
Best way to connect the LEDs and maintain the dimmer control is to connect to the red for power, and red-black as a switched ground. These are both on the blue plug.
Enjoy.
AlienX is offline   Reply With Quote
Old 03-04-2006   #50 (permalink)
hdave
Super Member
hdave is an unknown quantity at this point
Send a message via MSN to hdave
so to make my cluster blue, i can jsut replace all the bulbs with blue led ones??
i thought i cant do that because of the coloured film or something
__________________
2005 Civic SE
hdave is offline   Reply With Quote
Old 03-04-2006   #51 (permalink)
gearbox
Super Moderator
well before you put leds in there, you have to clear the back of the gauge face with solvent (acetone and q-tip works well).
__________________
www.lubecontrol.com
Member 1025782
Old 03-04-2006   #52 (permalink)
diskreet
diskreet's Avatar
exactly what gearbox said Read the diy I have posted
Old 03-08-2006   #53 (permalink)
utahbmxer
Member
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
Here is a pic of my Gauges. I also did the AC, Def buttons, still need to do the climate control knobs. Its still in the works. This is just Blue LEDs, I haven't removed filter from back of the face yet.
I removed the #74 socket piece and drilled a tiny hole in the back of it. I then cut the Neg side of the led short and connected it inside the socket. The positive lead goes out the hole and then I soldered the resistor on and then to the little copper connector (which contacts the circuit board). Here is a pic to help you visualize cause I didn't take a photo of it when I had it apart.
Still planning to:
-Replace weak LEDs with more intensity (I got 45deg not knowing they were 800mcd, BLAH)
-Remove filter/paint from rear of face
-Sand needles and maybe paint the back of them White for reflection
-Add white LEDs behind needles so they are bright!
__________________
utahbmxer is offline   Reply With Quote
Old 03-08-2006   #54 (permalink)
diskreet
diskreet's Avatar
Looks good utahbmxer!
Old 03-08-2006   #55 (permalink)
gearbox
Super Moderator
i would stay away from using two different led colors in there. for the needles, take em apart and strip the paint off with 90% isopropyl alcohol. then paint only the bottom with white glass paint. you can use leds below the needle or use the light guides to put the leds from the side and they will work.
__________________
www.lubecontrol.com
Member 1025782
Old 03-08-2006   #56 (permalink)
hdave
Super Member
that looks really good utahbmxer
__________________
2005 Civic SE
Old 03-09-2006   #57 (permalink)
utahbmxer
Member
utahbmxer's Avatar
Quote:
Originally Posted by gearbox
...you can use leds below the needle or use the light guides to put the leds from the side and they will work.
Ya, I was planning on using the light guides or something to "channel" the light into the needles so the white light doesn't show up in numbers, etc. I just want to go for a unique look. I haven't really opened the cluster to much, maybe if its possible I will solder some LEDs right to the board and position them behind the needles? I'll have to open it and look inside. I really do like the blue though, it goes well with my Receiver/Deck (Sony 5700, has 7 colors to choose from ).
__________________
Old 03-09-2006   #58 (permalink)
gearbox
Super Moderator
the problem is the needles are designed to light up with bulbs. if you try and use leds, it will be very dim even with white. you could do what i did and clear the needles with isopropyl alcohol and then paint the bottom white. then you can use leds to make it light up any color.
__________________
www.lubecontrol.com
Member 1025782
Old 03-12-2006   #59 (permalink)
utahbmxer
Member
utahbmxer's Avatar
A few things learned, no more guessing.
Ok, so I think I did as much as I'm going to with my dash. A few days ago I posted a pic of my gauges, the needles hadn't been cleared yet and now they are and a I did all the climate controls. I also decided to leave the blueish filter on the back of the faces. I noticed it was thicker in certain areas to eliminate/soften the hotspots. Its still noticable, but I think its not as bad as it would be without the filter stuff.
Here is a pic of the light socket..
Day, lights off..
Day, lights on..
Night, close up..
Night, full dash..
I also found a fool proof way for getting the needles back into position. I got them perfect, first try! (Tach and speed, you're on your own as for the temp and fuel, which was expained earlier) refer to this pic..
1. After you have cleared your needles don't put them back on yet, put the cluster in the dash and plug it in.
2. Turn the igntion to ON, but don't start it.
3. If you look at the magenta mark in the pic, this is the true 0 mark. Its not marked on the face. Look at the orange line. Take the distance from the 20 to the 10 line and then go that same amount from the 10 past the printed 0. This is your True 0, but the needle can't actually go there cause the post (red) stops it.
4. Now that you have found where 0 is, carefully put the needle (green) on while making sure that you keep it lined up with the true 0.
5. Push it on and leave a little space between it and the face, making sure it moves freely.
6. Ok, now its correctly positioned. All you have to do now is turn the needle about 3/4 turn counter-clockwise and let it settle on the post. Do this for the other one as well, same concept.
Sorry I had so many pics. I'm bored
Hope this helps!
__________________
Old 03-12-2006   #60 (permalink)
gearbox
Super Moderator
looks good to me. i've never had a needle problem so long as i put em back in the same position before turning the ignition. its supposed to have an auto calibrate which is the chattering sound the needle makes moving up and down for a few seconds.
__________________
www.lubecontrol.com
Member 1025782
Tags
74 , bulb , bulbs , civic , cluster , dash , diy , gauge , honda , led , needle , needles , orange , remove , s2000 , swap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
DIY: Blue LED gauge and dash lights gearbox Lighting 141 05-15-2007 11:06 AM
DIY: Glowing gauge cluster gearbox Honda Civic DIYs and Civic Tech Chat 10 07-19-2004 05:08 PM
DIY LED Gauge swap Ocelaris Honda Civic DIYs and Civic Tech Chat 49 11-17-2003 03:19 AM
Need a DIY:gauge cluster removal bong Honda Civic DIYs and Civic Tech Chat 2 10-24-2003 10:59 AM
group buy for LED for our gauge cluster ? tcneo Canada West 13 01-21-2003 08:10 PM
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
