Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-19-2005   #1 (permalink)
Ramones
Ramones's Avatar
Ramones is an unknown quantity at this point
Question sedan vs coupe headlights....
i remember reading a thread that the 01-03 coupe and sedan headlights were different. Are the mounting points different?
Need .
Ramones is offline   Reply With Quote
Sponsored Links
Old 05-19-2005   #2 (permalink)
rockhound124
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
Send a message via AIM to rockhound124
The only thing different with the lights are the turn signal/parking light sockets. They do not interchange with each other. The coupe version will NOT fit the sedan and vice-versa.
rockhound124 is offline   Reply With Quote
Old 05-19-2005   #3 (permalink)
dirtySAMURAI
Formerly Known as infinite012
dirtySAMURAI's Avatar
dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all
Send a message via AIM to dirtySAMURAI
the insides are different. coupes have up/down adjustability, sedan has up/down, left/right adjustability. coupes have a different turn/parking bulb socket than the sedan. the reflectors are different.
dirtySAMURAI is offline   Reply With Quote
Old 05-19-2005   #4 (permalink)
Ramones
Ramones's Avatar
thanks guys.
Rep points given
Old 05-29-2005   #5 (permalink)
Xenin
Superior Evolutionary Element Destined-factor
Xenin's Avatar
Xenin is an unknown quantity at this point
Send a message via Yahoo to Xenin
is the wiring the same to connect them, like could i use the connector on my coupe and attach to the sockets for sedan?
edit- nevermind, i just realized the wiring harness is the same for coupe/sedan cuz of searching and knowing TYC lights hook up fine for coupe/sedan. now i just have to find out which blacked out replica headlights Robear sent me, the coupe or sedan for my coupe. somehow i think they sent me sedan headlights.
Xenin is offline   Reply With Quote
Old 11-03-2008   #6 (permalink)
jgutka
Member
jgutka is an unknown quantity at this point
Re: sedan vs coupe headlights....
bump from the dead....
are the sedan sockets larger that the coupe?? i try to mount the coupe sockets into my replacement ligths and they are loose and do not cliip into place properly... is this my problem with the sockets???
jgutka is offline   Reply With Quote
Old 11-04-2008   #7 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
no, they're the same. H4 is H4. sounds like your housings are the problem.
electric130 is offline   Reply With Quote
Old 11-04-2008   #8 (permalink)
jgutka
Member
why does it say a few posts above yours the sockets are different for a coupe and sedan? isnt the h4 a bulb...
Old 11-04-2008   #9 (permalink)
electric130
I.C.E. Mod
Quote:
it's not the headlight sockets that are different. yes, H4 is a bulb. H4 socket is where the H4 bulb goes. so H4 socket on a sedan or coupe wouldn't matter as far as bulb fitment. the turn/parking lights mount in plastic socket and those snap into the headlamp. the mounting of the sockets is different. the bulb socket/mount is stationary on the headlamp. not removable like the turn/parking. does that make sense?
Old 11-04-2008   #10 (permalink)
jgutka
Member
ok ill jsut tell you my problem....
i got some headlights over a year ago.. the civic they are going in, was smashed and needed new lights.
i checked and they said they were for a 2002 honda civic lx coupe... however the origninal sockets (peice that clips into headlight housing and clips into electrical wires, not bulb) does not clip securely into the headlight housing...
they are jsut a tad too small or wrong design... (not too sure)
i called the place i purchased them from and they reassured me they are right, however they arnt as they dont clip in securely...
after doing some research ive came across this thread stating the sockets (peice that clips into headlight housing and clips into electrical and holds the bulb) are different for the coupe and sedan...
now beign that mine is a coupe im thinking they jsut messed up and gave me sedan healdights and i jsut need to change the sockets so they clip securely into the headlight housing...
edit: these are the healdights i have recieved:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=250299788570
Old 11-04-2008   #11 (permalink)
electric130
I.C.E. Mod
so you're talking about your turn/park lights, not the headlights?
Old 11-05-2008   #12 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
those are aftermarket lights, ofcourse they will have problems lol. if the park/turn sockets are loose, add another rubber o-ring you can get from auto store. if its the headlight bulb wire clip, you gonna have to play with it by bending, but dont go nuts it will break. you can get some thick wire from the hardware store and make a new one tho so it holds the bulb in tighter.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 11-05-2008   #13 (permalink)
WannaBFast
Prowlin' with a Purpose
WannaBFast's Avatar
WannaBFast will become famous soon enough WannaBFast will become famous soon enough
Send a message via AIM to WannaBFast
LOL sometimes its a different socket.. you can tell because the parking light and signal light sockets on a sedan have 4 tabs whereas a coupe will have 2, both sockets plug into the wire harness
__________________
01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
WannaBFast is offline   Reply With Quote
Old 11-05-2008   #14 (permalink)
jgutka
Member
yes i am talking only about the turn/parking lights...
the socket holding the bulb is not the problem, its the socket clipping into the housign of the turn/park lights.
the housing has 4 tabs to hold the light and socket in place, wheras the coupe sockets only have 2... and buy loose i mean the sockets circumfirence is too small... not by much.
was this one of the differences between a coupe and sedan? turn/park light socket size? (even by a little)
Old 11-05-2008   #15 (permalink)
electric130
I.C.E. Mod
yes.
Tags
01 , 09 , 2002 , 7thgen , civic , coupe , head , headlight , headlights , honda , hook , led , light , lights , park , sedan , si , socket
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
differences between sedan/coupe headlights TuffVietta Other Honda Civic Parts and Products 13 11-07-2003 05:18 PM
quick question Jeff Honda Civic DIYs and Civic Tech Chat 11 03-09-2003 12:44 AM
will coupe lights fit sedan profurious Honda Civic DIYs and Civic Tech Chat 11 01-28-2003 12:18 PM
Clearing Sedan lights? 7GRev Honda Civic DIYs and Civic Tech Chat 7 06-04-2002 04:27 PM
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
