Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-25-2006   #91 (permalink)
jdm_veloz
Member
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
Send a message via MSN to jdm_veloz
Quote:
Originally Posted by Hurts2bStock
I know this is a semi-old thread and topic but, I couldn't find the adaptaplug thing.......so I just cut the plug to fit the new socket, it took about 45 seconds per plug and now they fit as good as oem ......
will the cut the plastic work as well? like does is still light up properly?
__________________
Jdm
For Sale:
-KYB AGX STRUT SHOCKS w/ TEIN S TECH SPRINGS
-OEM BLACK FRONT LIP (VELOZ EDITION)
jdm_veloz is offline   Reply With Quote
Sponsored Links
Old 02-27-2006   #92 (permalink)
vietstylez
vietstylez's Avatar
Send a message via AIM to vietstylez
everything lights up like oem, i havent had any problems with socket falling out or anything either.
__________________
vietstylez is offline   Reply With Quote
Old 03-01-2006   #93 (permalink)
Hurts2bStock
Shinier than yours, meatbag
Hurts2bStock's Avatar
Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of Hurts2bStock has much to be proud of
Quote:
Mine works perfect, and the plug will fit very tight.......if your scured....I live in Van if you want some help
__________________
http://www.7thgencivic.com/forums/at...id=49819&stc=1
"Mein bratwurst has a first name, it's F-R-I-T-Z. Mein bratwurst has a second name, it's S-C-H-N-A-C-K-E-N-P-F-E-F-F-E-R-H-A-U-S-E-N."
Confirmed Kills List:
2003 Kia Sedona
2005 Smart Car
10 Speed Bike (uphill)
1993 Ford Festiva
T950 Kenworth B train
City Bus
Hurts2bStock is offline   Reply With Quote
Old 03-20-2006   #94 (permalink)
IrockCivics
IrockCivics's Avatar
IrockCivics is a name known to all IrockCivics is a name known to all IrockCivics is a name known to all IrockCivics is a name known to all IrockCivics is a name known to all IrockCivics is a name known to all IrockCivics is a name known to all
Quote:
Originally Posted by zen_master
<Updated: 10/11/05 -- Now I'm not using this DIY anymore, I replaced the whole wiring to 04/05 wiring >
Hi guys!
This is going to be my first DIY for 7thgencivic.com.
(for complete DIY of the 04 tailight itself, go down...........)
In concern of the other 2004 Civic taillight conversion DIY, I went to Radioshack and was trying to find the required stuffs....like the cables, butt connectors, Y shaped connectors, etc..
However, I got a trouble finding the correct butt connectors that I want to use to connect the wire to the socket. After 30 minutes trying to find the right connector, I was circling around Radioshack to find something else that is simpler and easier to use.
I got this:
1. Adaptaplug 6" Power Leads -- $2.99 from Radioshack.
2. Socket number 33304-S30-003 from Majestic or Honda dealer. $4.55
3. 7443 Bulb from any local auto store (DOUBLE FILAMENT) $5.83
*Taillight DIY: Step1 (Image)*
the wire/adapter that I bought is a "Adaptaplug 6" Power Leads," with the pricetag of $2.99 from Radioshack.
As you can guess, it's absolutely simple to use this wire to accomplish our DIY.
*Taillight DIY: Step2 (Image)*
Installation procedure:
The only thing that you have to remember is the way you install the connector into the socket.
Look at the picture above, as you can see, I plugged the connector not just by simply plugging it into the socket. All you need to do is to plug the two connectors on the wire into the LOWER part of the metal pins inside the T20 socket.
Why do we connect it this way? This way, the Radioshack adapter won't wiggle around. If you plug the adapter straight above the metal pins (so easy), the connector can move around and the bulb won't light up. Instead of doing that, we plug the adapter below the metal pins, so that the adapter won't wiggle anymore.
*Tailight DIY: Step3 (Image)*
Then, you should know the rest of the DIY....It's a simple connection to our wiring harness into the hardened wire of the Radioshack adapter.
Voila! We're finished! Just like that!
*Taillight DIY: Step 4 (Image)*
From the picture below, you should realize how easy it is to do this DIY.
SO.....
here's how to swap your 01-03 "sad" looking tallight into the "happy" looking 04 taillight...
first, take out the fabric cover by unscrewing that plastic tab (use nail or supermarket bonus card)...
this is how my old 01-03 tailllight looks like from behind...
then...we've to unplug all the sockets from the housing....simply by turning the socket anti-clockwise...
the second socket from the left is the old turning light socket that we got a trouble with....how to change it? you can read the DIY above....
simply unscrew the 5mm lug nut by using socket wrench number 8......metric size...
there are total 4 of em on each side....
this is how my car looks like without the taillight....neat, eh? hahaha..
after this step, you just have simply do the DIY above....or another DIY to prepare the T20 socket that fits the 04 taillight...
after everything's ready....just put back the 04 taillight into your civic...and everything should be allright.....make sure to look after the plastic tab on the side of the taillight...don't break em..
on the picture below, this is how my wiring looks like right now...by using the Radioshack Adaptaplug...
i used the green wire clipper to hold the old side market that we won't use no more...
and this is the final picture..
you should see the happines of my car.....and the "sad" look of the old taillight!
notice the happy look of my wal-mart muffler tip?
more pics and more pics for your information...........
This is the one that won't fit:
Enjoy!
<Updated: 10/11/05>
Does this DIY still works for the conversion or is there a new and easier one? and sorry for bringing this thread back from the dead lol
__________________
http://www.myspace.com/gabe7981
If you want to trade your sedan for a coupe let me know, I'm looking for a sedan.
IrockCivics is offline   Reply With Quote
Old 03-21-2006   #95 (permalink)
kingofheartz
Member
kingofheartz will become famous soon enough kingofheartz will become famous soon enough
i think theyre both pretty easy =P
kingofheartz is offline   Reply With Quote
Old 03-23-2006   #96 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
christ someone put this in a DIY section or sticky. ****.
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 03-23-2006   #97 (permalink)
kingofheartz
Member
ive got a pair of 04 lights coming in this weekend, if i can get my car out of the shop in time to put em on before next week, ill post some pix for fun ^^
Old 03-24-2006   #98 (permalink)
IrockCivics
I am doing mines tomorrow, I will post pics when I'm done.
__________________
Old 03-24-2006   #99 (permalink)
kingofheartz
Member
Quote:
looking forward to seeing em
Old 03-25-2006   #100 (permalink)
IrockCivics
Quote:
Here are they took me like 20mins to put them on very easy and yes I know I'm missing a bulb on the right reverse light lol
__________________
Old 04-04-2006   #101 (permalink)
kingofheartz
Member
looks good, i love the look of the 04 tail lights.
Old 04-04-2006   #102 (permalink)
IrockCivics
thanks bro'
__________________
Old 05-25-2006   #103 (permalink)
realitycheck
Super Member
realitycheck's Avatar
realitycheck is an unknown quantity at this point
I have a question what if you took the new socket and cut this part
off could you not just take two wires and solder them to the two little pins that are sticking out??
__________________
A realitycheck is a time in your life where you do a check of your heart. A time you check where your relationship with God is and where it’s going. Then you make a decision as to where your going from here.
So many Struggles, So many Trials, So many reasons for me to Fall, But I have all Strength, And I have all Power, And I will Bury You!
realitycheck is offline   Reply With Quote
Old 05-25-2006   #104 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
Send a message via AIM to zen_master Send a message via MSN to zen_master
hmm...that's also possible...
but the idea of this DIY is "clean" right?
i belive that cutting and soldering will make it UNclean....lol
__________________
2003 Civic EX Sedan
zen_master is offline   Reply With Quote
Old 05-25-2006   #105 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
hey it doesnt matter if noone sees it!
gearbox is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
