Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-29-2004   #1 (permalink)
cthom
Member
cthom is an unknown quantity at this point
Unhappy Headlight experts needed!
Short question - I have an 02 coupe with stock cleared headlights, will I be able to install 02 sedan headlights without problems? Will I need to put the park light and turn signal connectors from the coupe lights into the sedan lights? Will they fit? Any other fitment issues?
I've done the research, so if anyone wants to know, here's the differences:
Coupe:
1) Closed reflector
2) Black sealant
3) Metal clips
4) Wider upper portion
5) Torx screws
6) Smaller park light and turn signal connectors
7) *Hole in tab for hex to pass through for aiming adjustment* - this I've noticed; not
mentioned in previous posts
Sedan:
1) Partially open reflector
2) Grey sealant
3) Plastic tabs
4) Narrower upper portion
5) Phillips screws
6) Larger park light and turn signal connectors
7) *No hole in tab for aiming adjustment; adjuster next to outer tab (closest to fender) facing
directly down* - again, just what I've noticed
Please feel free to comment or correct mistakes, just please answer my question.
Thanks all.
cthom is offline   Reply With Quote
Sponsored Links
Old 01-30-2004   #2 (permalink)
cthom
Member
bump
Old 01-31-2004   #3 (permalink)
ImPulse
ImPulse's Avatar
ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse
oem headlights are different between sedan and coupe....
aftermarket headlights however are fine for both
ImPulse is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
