Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-13-2003   #61 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Tin foil for what?
Impulse, I mentioned above that I just used parts from the 01 cluster and moved them onto the 02. I'm still using my 02 cluster on the car--the only difference is it has 01 needles and 01 gauge faces.
I repainted the needles, this time only on the bottom. Now they look white during the day and still seem bright enough at night.
I also ordered some blue bulbs for the backlight. Amber just doesn't look right. I'll just leave the rest of the dash amber. I think this will look good, like I just have some reverse gauges and the rest stock.
gearbox is online now   Reply With Quote
Sponsored Links
Old 12-13-2003   #62 (permalink)
stupidd
Senior Member
stupidd's Avatar
stupidd is on a distinguished road
Send a message via AIM to stupidd
i thought you said something about making light go to a certain area, or make it brighter, i thought maybe tin foil might work.
__________________
Xbox Live Gamertag: Blade Razorr
stupidd is offline   Reply With Quote
Old 12-13-2003   #63 (permalink)
gearbox
Super Moderator
I repositioned the LEDs so that they're sitting below the needles, and this took away that glow around the bezel. I don't know if I'm gonna move them back of not. I'll let you know what happens. It's frustrating cause nothing is working right and one is purple. Ahhhhhh.......
Old 12-13-2003   #64 (permalink)
gearbox
Super Moderator
Nah, I was trying to block the LED light from bleeding onto the backlight. I couldn't, so I'm just getting blue backlight bulbs.
I'm gonna see about getting a new LED tomorrow.
Old 12-13-2003   #65 (permalink)
ImPulse
ImPulse's Avatar
ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse
isnt it annyoing to keep taking the guages out of the car? i personally hate it, its fn annoying
ill wait for u to be done wit everything =] lol
i still dont see why i cant make the WHOLE thing white... i dont see a problem with anything fading in with eachother
ImPulse is offline   Reply With Quote
Old 12-13-2003   #66 (permalink)
Big Baller L
Nugget Garage Since 2004
Big Baller L's Avatar
Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future Big Baller L has a brilliant future
sweet DIY gearbox!!! Love the needles...i think im gonna try this today....everything else is blue in my car except the cluster...nice job!!
Big Baller L is offline   Reply With Quote
Old 12-13-2003   #67 (permalink)
gearbox
Super Moderator
Thank you guys. I just finished soldering in the new LED and it matches thank goodness. I've had my cluster in and out at least 20 times already.
IMPORTANT NEW ADDITIONS:
1) When you shave down the LEDs with sandpaper to get them flat, go from large grain to small. Use very fine paper at the end to smoothen it. Then, you'll want to pick up some Meguiar's clear plastic polish and apply that to the LEDs. This will help make them shinier. I've found that sanding them down makes them alot dimmer than the original. You still need to do this to diffuse the light. The unsanded ones do a great job of focusing the light exactly upwards. Well, the needles have light guides as well, and using unsanded LEDs will cause the needle glow to get brighter and dimmer as the needle moves. You must sand them, even though you'll lose some brightness.
2) I repainted the needles, this time only painting the bottom and using one medium coat. This makes the needles look white during the day instead of clear. Leaving the needles all clear will not light up at all!! You must paint them. Paint only the bottom portion that is exposed. (Not the part under the sheath.)
Old 12-13-2003   #68 (permalink)
gearbox
Super Moderator
Impulse, unless you have bigger bulbs back there, you can't make the backlight hyperwhite. The gauges have some kind of paint on the front that still makes the light amber. I held them up to my halogen light and they were still amber. Then I held them up to my 194 hyperwhite dome light and it lit up white. You really need a brighter light to do this.
If you use colored bulb replacements for the backlight, you may be able to just clear the needles and let the backlight channel through to the needles. LEDs will be brighter, though, especially in blue.
Old 12-13-2003   #69 (permalink)
gearbox
Super Moderator
I would also recommend positioning the LEDs upwards, so they're even with the plastic shield. Don't put them down on the needle base. If you bend the cable up, you should be able to just position the LEDs in the holes without glue.
Old 12-13-2003   #70 (permalink)
ImPulse
ImPulse's Avatar
Here is an example of white LEDs
Old 12-13-2003   #71 (permalink)
ImPulse
ImPulse's Avatar
very bright =]
Old 12-13-2003   #72 (permalink)
gearbox
Super Moderator
I remember that DIY up there. But he used something like 2 for each hole, and I believe it looks blue. That would cost nearly $40 just for LEDs.
I finally finished the needles. If you push them all the way down (but not too far), you won't get that uneven sideglow. Right now I'm just running the needles and no backlight. Looks clean, but hard to see. I'm waiting on blue cluster bulbs I got for only $6 shipped. We'll see how that looks.
Have you thought about the shift indicator light? There is a piece in there that makes the light red and green for the D,R,N... numbers. I first used that red lens repair tape to change them all to red, but now it's off and it lights up a bright amber. I got a blue folder to try, but it didn't give a good blue until I had 8 layers on it, and then the light was too dim to see. I'm thinking to just leave it clear (amber).
If the blue gauge lights work out, I'm just leaving the other dash lights amber. Everything blue may look weird. This way it looks like I have reverse gauges or something and evereything else stock. I'll post pics when they come in.
Old 12-13-2003   #73 (permalink)
gearbox
Super Moderator
If the blue bulbs don't look good, I got some red ones coming, too. That way I can just do the whole dash red as well using that tape.
Old 12-13-2003   #74 (permalink)
gearbox
Super Moderator
Here's the one you were talking about with white light. Looks okay. Maybe you should just follow his diy I guess they have replacement LEDs that fit in the stock bulb holders. You could technically buy 5 LEDs from autolumination and swap them in. Don't know how bright they would be. I would advise on getting the opaque ones, otherwise you're just gonna see bright spots where the LEDs are.
Old 12-13-2003   #75 (permalink)
gearbox
Super Moderator
Here is mine with just the needles turned on. The halo lights up all the numbers, but it's still dim. I hope those blue bulbs work out.
Tags
blue , burn , civic , cluster , curcit , dash , honda , led , lx , make , moon , needles , remove , roof , tachometer , white
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
