Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-07-2003   #1 (permalink)
SLAMMED01CIV
Diamond Member
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Send a message via AIM to SLAMMED01CIV
Big problem......(headlights)
Ok guys I need help ASAP. I recently returned my car back to stock because I'm trading it in in a week. I have a big problem. My lowbeam headlights don't work. I have checked the bulbs and they are fine. I have even tried replacing them with new ones. Nothing. My highbeams work fine on the other hand. I can't drive my car at night and that is when I do a majority of my driving. I know some of you are going to say, "who cares, you're trading it in anyways." I know this but I also have to drive the car until I trade it in. I was thinking maybe the wire harness. But if it was the harnesses, wouldn't the highbeams not work as well? Oh ya. I have also checked the fuses and they are fine. When I had my HID's in I had to swap out the regular 15amp fuses for 20amp fuses. The 20amp fuses are still in. Do you think maybe this is the reason? Help me out guys. Thanks. To remove this ad, register today for free or log in if already registered!
SLAMMED01CIV is offline   Reply With Quote
Sponsored Links
Old 11-07-2003   #2 (permalink)
ImPulse
ImPulse's Avatar
ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse
just try your fuse idea.. If that doesnt work, then u need a new harness? Doesnt make sense for high beam to work but, low beam no working... Did u check the connection?
ImPulse is offline   Reply With Quote
Old 11-07-2003   #3 (permalink)
SLAMMED01CIV
Diamond Member
Ya I checked all the connections and everything seems intact. This sucks.
Old 11-07-2003   #4 (permalink)
dirtySAMURAI
Formerly Known as infinite012
dirtySAMURAI's Avatar
dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all
Send a message via AIM to dirtySAMURAI
happening to me too...except im basically all stock cept for Impulse's bulbs that I bought. Low beam doesn't work on one light, but high beam works fine. PLZ HELP!! I hate driving with that blue light in my dash
dirtySAMURAI is offline   Reply With Quote
Old 11-07-2003   #5 (permalink)
Samari
Ultimate Member
Samari's Avatar
Send a message via AIM to Samari
go to the dealer and let them check to see if there is power running to the low beam wire.
Samari is offline   Reply With Quote
Old 11-07-2003   #6 (permalink)
Voiceofid
End Bringer
Voiceofid's Avatar
Send a message via AIM to Voiceofid
you guys checked fuses?
Voiceofid is offline   Reply With Quote
Old 11-07-2003   #7 (permalink)
SLAMMED01CIV
Diamond Member
My fuses are fine. They are actually 20amp instead of 15. I had to use the 20's when I had my HID kit in.
Old 11-07-2003   #8 (permalink)
Voiceofid
End Bringer
Voiceofid's Avatar
open your fuse box and try swapping the headlight relays around, the relays may be bad
Old 11-07-2003   #9 (permalink)
ImPulse
ImPulse's Avatar
Quote:
lol, i thought u said u fixed it?
Old 11-07-2003   #10 (permalink)
Jodster
Post Whore General
Jodster's Avatar
Jodster is a jewel in the rough Jodster is a jewel in the rough Jodster is a jewel in the rough Jodster is a jewel in the rough
Send a message via AIM to Jodster
Same thing happened to me. The switch is burned out. You will have to buy a new switch and replace it. If you take your steering wheels column apart and look at the back on your switch, you will see that it burned out. You can take it to your dealer, but take out your aftermarket bulbs first. I'm curious oh how it happened to your guys. For me it happened when I wrecked my car. After the body shop put my fenders on, they pinched a wire. Thats what caused mine to burn out.
Jodster is offline   Reply With Quote
Old 11-08-2003   #11 (permalink)
SLAMMED01CIV
Diamond Member
Thanks Voiceofid and Jodster. This didn't start happening to me until I had my front bumper replaced by a body shop after my boy ran over a high curb with it. I wonder if they fcked it up. That was a while ago though so I don't think I can have them do anything about it. Do you guys think that the dealer will give me sh*t for having cleared headlights?
Old 11-11-2003   #12 (permalink)
Jodster
Post Whore General
Jodster's Avatar
^^^Don't know. Just make sure that you have stock bulbs in and take it to them. They to get them to fix it for free. Don't tell them that the car was in the body shop awhile ago, cause they will just saw that it was the body shops fault. Then you will have to deal with them.
Old 11-11-2003   #13 (permalink)
Quijano187
The Evil Genius
Quijano187's Avatar
Quijano187 is on a distinguished road
Send a message via AIM to Quijano187
this happen to my civic and my boys toyota corrola. we both had piaa lights and i wanted to switch mines to silverstars and the stock bulb wouldnt work. we tried the bulbs im my friends car and then his bulbs got f up. so with the new ones all i did was clean up a little of the guew that goes on the bulbs with the socket that they go in. put them up and still didnt work. untill and fling my finger on the bulb when it was on and it work. we did the same with my friends car and it work. try to clean the sockets a litte bit with a tooth pick and the then fling your finger on the bulb. if it dosent work .. you need a new harness.
Quijano187 is offline   Reply With Quote
Old 11-26-2003   #14 (permalink)
2k3HonCivicEX
Senior Member
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
Send a message via AIM to 2k3HonCivicEX
swap the 15 amp fuses back in, the 15s have a better cutoff point, yes you could have ruined the harness by having too much power flowing through it... the 20 amp fuse can allow more power thus creating problems! switch it, unplug the harness and make sure all metal connectors are clean, maybe some corrosion, plug it all back in and try it.
2k3HonCivicEX is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
