Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-03-2003   #1 (permalink)
Whelan
Super Member
Whelan's Avatar
Whelan is an unknown quantity at this point
Send a message via AIM to Whelan
pulling the LED ring off my projector?
I could follow the DIY on clearing your lights to get the housing apart on my projectors. But how would I get that ring off. Is it glued or something? Or would I pretty much have to break it off and glue the new ones on. I am most likely going to do that DIY with the rubber air hose type tubing and some White LEDs. I would do two sets so I can put a set around the high beam as well. Should look hot and very custom, plus my resealing job would be twice as good as the stock one. To remove this ad, register today for free or log in if already registered!
__________________
You know how life goes, sometimes your the bug, othertimes you the windshield...
Whelan is offline   Reply With Quote
Sponsored Links
Old 11-04-2003   #2 (permalink)
Whelan
Super Member
Whelan's Avatar
bump
__________________
Old 11-04-2003   #3 (permalink)
ImPulse
ImPulse's Avatar
ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse
if there is no other way... then pull it off.. If its screwed on somehow then unscrew it... You can always glew it back on..
But be careful on what glue you chose... Some may have fumes that will damage your projector housing.
Are u going to be making your own halos?
ImPulse is offline   Reply With Quote
Old 11-04-2003   #4 (permalink)
Whelan
Super Member
Whelan's Avatar
Im thinking of making my own but I found some from HIDtech.com for like $60 already made. I emailed them about dimensions cause I want to put two sets in and have a set for my high beams.. that way when the projector is on at night you can still se a ring glowing.
__________________
Old 11-04-2003   #5 (permalink)
ImPulse
ImPulse's Avatar
here is something i found that looked amazing... tell me what u think...
Old 11-04-2003   #6 (permalink)
ImPulse
ImPulse's Avatar
here is the link to more pics
http://f1.pg.photos.yahoo.com/ph/seb...ir=/Thialights
view it as a slideshow, loooks cool
"using low beam HID Audi A6 projector incombination with Hella 90mm high beam in Maxima housings. The"angeleyes" are white 12" spaced white LED flexible arrays from www.Radiantz.com. "
i went to that site... but i cant find what they mentioned... plus it looks expensive :x
Old 11-04-2003   #7 (permalink)
Whelan
Super Member
Whelan's Avatar
That does look pricey here is what I found from HID tech
But I got a reply stating that they only sell the rings, not the LEDs, and that I would have to put on a 1/2W LED, 220ohm resistor and basically wire it up myself which isnt hard. I just asked him back if the rings have notches for the LEDs to fit into or if they just sit outside somewhere.
They also have this though.
I thought that was pretty interesting, its $89, looks like two eyes go into one connection. I emailed him for more infor on them as well.
He said the rings are 5" in diameter so I am going to measure mine tonight when I get home to see the fit. They claim they are Hella BMW OEM angel eyes, so I am wondering if they are plastic or glass like BMWs.
__________________
Old 11-04-2003   #8 (permalink)
ImPulse
ImPulse's Avatar
thats a lot of $... Make sure they fit! Haha... Well... I can vouche for them... HIDTech is a great website to go to for HID related products.
I like the "Euro Spec Fiber Optic Light Guiding Cable Set" only thing is... I think both the halos are attached... So, u would have to cut it.. Unless they will both reach into the projector, and high beam area?
would u know how to connect them? Looks weird o_O
Old 11-04-2003   #9 (permalink)
Whelan
Super Member
Whelan's Avatar
yeah it does look a little odd. I might be better off wiring up a LED to the rings themselves they have and putting heatwrap on them for protection with a bit of silicone.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
HID Pic post!!
DIY: blue glow needles!
DIY: Blacking Out 04-05 Headlights _Viper_ Style ( Pics Included)
DIY: Complete 04 taillight conversion!
DIY LED Gauge Cluster II
L.E.D's in the door Handle!!!!
DIY: Retrofit TSX Projectors
who has ebay fog lights?
DIY : Double Neon Angel Lights
***The Ultimate HID Thread*** [FAQ/Information]
Site Supporters
aluminum radiator
Honda car spoilers
